10 Replies Latest reply on May 13, 2012 8:58 AM by Rasmus.Olsen
    [ScriptUI] edittext fiddle (show/hide and set)
    Rasmus.Olsen
      Cheers,
      I'm writing a small script that does some some find/change stuff. My idea is to output any error info to a edittext field nested in a panel, and only show this textfield if my grep function fails. I've read Peer Kahrels ScriptUI Basics (thank you for that reference ), but I'm still not sure how to update the textfield outside of my create-palette-function.
      Can you help a hopeless newbie?
      showPalette();
      function showPalette() {
          var j_logo = new File("~/Desktop/Jysk_GREP/jysk_logo.png");
          var e_logo = new File("~/Desktop/Jysk_GREP/env_logo.png");
          var myDialog = new Window('palette', 'Jysk Search-Replace');
          var myIconGroup1 = myDialog.add('group', undefined, '');
              myIconGroup1.add('image', undefined, j_logo);
          var myGroup = myDialog.add('group', undefined, '');
          myGroup.orientation = 'row';
              var myPanel1 = myGroup.add('panel', undefined, 'Berthold');
                  myPanel1.margins = [15,20,15,15];
                  var bDK = myPanel1.add('button', undefined, 'DK', {name:'DK'});
                  var bSE = myPanel1.add('button', undefined, 'SE', {name:'SE'});
              var myPanel2 = myGroup.add('panel', undefined, 'Compacta');
                  myPanel2.margins = [15,20,15,15];
                  var cDK = myPanel2.add('button', undefined, 'DK', {name:'DK'});
                  var cSE = myPanel2.add('button', undefined, 'SE', {name:'SE'});
          var myGroup2 = myDialog.add('group', undefined);
                  var myAlertPanel = myGroup2.add('panel', undefined);
                  var list = myAlertPanel.add('edittext', undefined, ["test","test"].toString(), {multiline: true, scrolling: true});
                  list.maximumSize.height = myDialog.maximumSize.height-100;
                  list.maximumSize.width = 204;
          myDialog.show();
      Best wishes,
      Rasmus
        • 1. Re: [ScriptUI] edittext fiddle (show/hide and set)
          Peter Kahrel Adobe Community Professional & MVP
          Rasmus,
          Could explain in some more detail what you want to do?
          Peter
          • 2. Re: [ScriptUI] edittext fiddle (show/hide and set)
            Rasmus.Olsen Level 1
            Cheers Peter,
            Apologies for not beeing specific enough. The script palette lets the user apply some predefined grep commands by calling a runGrep() method via event onClick. If runGrep() catches an error I'd like to return this error to the dialog, show the edittext field and set the error message as content. The idea is to notify of any errors in the script dialog directly instead of having to write error stuff to log files. Is this possible, in your opinion?
                //------- Berthold buttons -------
                        //------- Berthold DK -------
                            //------- event handling -------
                            bDK.onClick = function() {
                                alert("You've clicked on bDK!");
                                var myFolder = Folder.selectDialog ("Choose root");
                                runGrep([Folder(myFolder+"/AllCountries"),Folder(myFolder+"/DK")]);
            function runGrep(array) {
                //grep stuff here
                //return any error message to dialogs edittext field
            • 3. Re: [ScriptUI] edittext fiddle (show/hide and set)
              I guess what you could do is to catch any errors and add them to the palette's edittext control. Something like this (the advanced editor appears to have disappeared):
              try
                  // find something
              catch (e)
                  list.text = e.message
                  // or if you want to add the message to what's aleady there:
                  // list.text = list.text + \r\r + e.message
              Where list is the edittext control in your palette.
              Is that what you're after?
              Peter
              • 4. Re: [ScriptUI] edittext fiddle (show/hide and set)
                Cheers Peter,
                This is what I'm trying to do - but I'd like to set the list.text from my runGrep() method. Can you do that?
                createWindow(params) {
                     var w = new Window ("dialog", "Multiline");
                     var myText = w.add ("edittext", [0, 0, 150, 70], "", {multiline: true});
                     myText.text = "Line 1\rLine 2\rLine 3\rLine 4\rLine 5\rLine 6\r";
                     myText.active = true;
                     w.show ();
                function runGrep(params) {
                     try {
                          //do text change stuff
                     } catch(e) {
                          //set myText.text = e.description;
                BTW. code formatting is availabe if you edit your post
                Best wishes,
                Rasmus
                • 5. Re: [ScriptUI] edittext fiddle (show/hide and set)
                  Ah, like that. The section 'Communication between windows' (in the ScriptUI guide) explains how you could do it, but doesn't make something clear, so here's a summary.
                  First you need to do you window as a palette. And you need to name your edittext control:
                  var myText = w.add ("edittext", [0, 0, 150, 70], "", {multiline: true, name: 'runGrepErrors'});
                  Now you can access that control with any other script:
                       try {
                       } catch(e) {
                            var w = Window.find ('palette', 'Multiline');
                            if (w !== null){
                                 if (!w.visible) w.show();
                                 w.findElement ('runGrepErrors').text = e.message;
                  Rundown: use Window.find() to get a reference to your palette. Make sure the palette is visible, then use findElement() get a reference to the palette's edittext control.
                  Peter
                  • 6. Re: [ScriptUI] edittext fiddle (show/hide and set)
                    John Hawkinson Level 5
                    Peter:
                    You certainly can do it that way, but it's not necessary.
                    You can just use scoping in javascript to make sure the variable that holds the edittext control is avaialble to your function.
                    For instance:
                    var myText;
                    function createWindow(params) {
                    function runGrep() {
                      myText.text = "whatever";
                    That example uses a global variable. Of course you should avoid global variables. Without a little more information it's hard to tell you the best way to avoid it, but it's not the end of the world most likely. One choice is to wrap everything in another function, since variables in JavaScript have function scope.
                    • 7. Re: [ScriptUI] edittext fiddle (show/hide and set)
                      And by using Window.find() and findElement() you do just that, it seems to me.
                      Peter
                      • 8. Re: [ScriptUI] edittext fiddle (show/hide and set)
                        seems to me.
                        Yes, but then you blow two calls to the DOM, which is bad for performance.
                        Better to use a local variable.
                        For instance
                        (function() {
                          var myText;
                          function createWindow() {
                        or alternatively, nest the functions:
                          var myText;
                        or a myriad of other choices.
                        • 9. Re: [ScriptUI] edittext fiddle (show/hide and set)
                          But the point is that the script/function that creates the window is not (necessarily) the same script that writes into the window.
                          • 10. Re: [ScriptUI] edittext fiddle (show/hide and set)
                            Yesss Master Kahrel, this is exactly what I were looking for!
                            Cheers,
                            Rasmus
