1. Re: Dynamic LINKED AE Menu is Transcoding every build
Stan Jones May 10, 2012 4:59 AM (in response to dpDesignz)I differentiate "transcoding" from "building." Transcoding is encoding/reencoding an asset to DVD spec (not a formal definition, but you get the idea) while Building is simply muxing the transcoding video/audio into the DVD VOB streams. Menus are a different creature. Even if the motion asset for a menu is transcoded, the menu must still be rendered. I do not understand when Encore insists on re-rendering a menu.
In any event, n your case, I would try to sort out whether the AE DL motion is really re-transocding, or if the menu is rendering.
Try rendering the menu (if it will let you) before the build.
I do not understand why it is taking so long.
I would first take DL out of the equation by exporting the file from AE and importing to EN.
2. Re: Dynamic LINKED AE Menu is Transcoding every build
dpDesignz May 10, 2012 12:23 PM (in response to Stan Jones)Hey Stan
Thanks, but to your first comment, it still has to to transcode a file before burning it, and these were even pre-transcoded, so not sure what was happening.
I rendered the menu about 2 hours after starting the build and an hour later it finished and I was able to burn 10 copies, so just looks like It was getting jammed up.
Thanks for the input.
3. Re: Dynamic LINKED AE Menu is Transcoding every build
Stan Jones May 10, 2012 6:38 PM (in response to dpDesignz)Glad it's working!
