3 Replies Latest reply on May 10, 2012 3:56 AM by _spoboyle
    xml question
    WuLink
      var x:XML = <datas>
                          <data id="1" name="a" txt="aa" />
                          <data id="2" name="b" txt="bb" />
                          <data id="3" name="c" txt="cc" />
                </datas>;
      var id:int = 1;
      var name:String = "b";
      trace(x.data.(@id == id).@txt);
      trace(x.data.(@name == name).@txt);
      sdk3.5:
      aa
      bb
      sdk3.6:
      aa
      bb
      sdk4.5:
      aa
      //no output
      sdk4.6:
      aa
      //no output
      any one help me? bug or else?
        • 1. Re: xml question
          _spoboyle Level 4
          can't explain why yet but it's do to with the name of the local variable called name
          in case you haven't seen this yourself the following fixes the issue
          var x:XML = <datas>
                    </datas>;
          var id:int = 1;
          var name_:String = "b";
          trace(x.data.(@name == name_).@txt);
          • 2. Re: xml question
            _spoboyle Level 4
            not sure what this means yet but
                                          var x:XML =   <datas>
                                                    </datas>;
                                          var id:int = 1;
                                          trace(x.data.(@name.indexOf(name)>-1).@txt);
            outputs
            aa
            aabbcc
            • 3. Re: xml question
              _spoboyle Level 4
              ok i think this means that when
              comes to evaluate name, name = "" (the empty string)
              this looks like a bug to me, possible some sort of scoping issue
              the following also give you the output you want confirming that name is being evaluated to the empty string
              var x:XML =   <datas>
                                                      </datas>;
                                            var id:int = 1;
                                            trace(x.data.(@name == (name+"b")).@txt);
