14 Replies Latest reply on May 23, 2012 1:34 PM by timlogochair
    Modify a script help?
    timlogochair Level 1
      I have a script that needs to be tweaked very slightly.  Right now this script is setup to save out files and rename them as follows:
      current document file name + "-" + artboard name + (rename files from .ai to .pdf)
      I need this script tweaked so that the exported file names are as follows:
      artboard name + "-" + current document file name + (rename from .ai to .pdf)
      Here's the script that needs to be tweaked:
      #target illustrator
      function artboardsToPDFs() {
           if (app.documents.length = 0) {
                return;
           } else {
                var docRef = app.activeDocument;
                var docName = docRef.name;
                var baseName = docName.replace(/.ai$/,'');
           var dF = Folder(Folder.desktop + "/AI PDF's");
                if (!dF.exists) dF.create();
                var aB = docRef.artboards;
                var autoNames = Array();
                for (var i = 0; i < aB.length; i++) {
                     var abName = aB[i].name;
                     autoNames.push(baseName + '_' + abName + '.ai');
                if (!docRef.saved) docRef.save();
                var aiOpts = new IllustratorSaveOptions();
                aiOpts.compatibility = Compatibility.ILLUSTRATOR13;
                aiOpts.pdfCompatible = true;
                aiOpts.saveMultipleArtboards = true;
                var saveFile = File(dF.fsName + '/' + docName);
                docRef.saveAs(saveFile, aiOpts);
                docRef.close(SaveOptions.DONOTSAVECHANGES);
                saveFile.remove();
                renameFiles(dF, autoNames);
      artboardsToPDFs();
      function renameFiles(dir, fL) {
           for (var i = 0; i < fL.length; i++) {
                var f = File(dir.fsName + '/' + fL[i]);
                if (f.exists) {
                     var reName = f.name.replace('_','-');
                     f.rename(reName);
                     f = File(dir.fsName + '/' + reName);
                     reName = f.name.replace(/\.ai$/,'.pdf');
                     t = File(dir.fsName + '/' + reName);
                     if (t.exists) t.remove();
                     f.rename(reName);
