Hello,
I work for an HP software partner and I have a customer who has upgraded to Flash 11 several weeks ago. In their testing environment, they utilize HP's Functional Testing solution QuickTest Professional to automate their application.
I wanted to know if Flash 11 support will be rolled-out for QTP soon? If possible, it would be great to know an approximate timeframe when the support will be available?
I have tried calling Adobe Help at 1888-833-6687 but haven't been able to find a response. I have also inquired about this with HP many times but they've asked me to post a question here or contact support as the add-in for QuickTest is developed by Adobe: http://help.adobe.com/en_US/Flex/4.0/TestingQTP/flex_4.0_testingqtp.pd f
Your advise would highly appreciated.
Anshoo
PS. I opened a thread here: http://forums.adobe.com/message/4392010#4392010 but not sure if I am in the correct place. I do not have access to post in the Flash 11.0 forum.
Hi Anshoo9,
I'm not familiar with this product, but it sounds like this question should be posed to HP as they maintain QTP. Is there a reason you believe Adobe should be responsible for this task?
Chris
Chris, Thanks for your response.
To answer your question, I did contact HP first but I was told that since the SDK is developed by Adobe (and so is the QTP toolkit), I must contact Adobe for this. Below is HP's response:
There is actually a Flex Add-in, we don’t have documentation if this support Flash 11 since this Add-in was developed by Adobe. That is a third party add-in, because of that we don’t provide support for that Add-in.
If you want to request a new release support in this case (Flash 11) You can Contact Adobe and request it, since they are in charge of the development of the flex add-in.
Here is a link related to testing ADOBE® FLEX® 4 Applications withHP QuickTest Professional
http://help.adobe.com/en_US/Flex/4.0/TestingQTP/flex_4.0_testingqtp.pdf
I have been trying to get in touch with someone but to no avail. I called Adobe's customer service and they ensured me a call back with the details but its been many days, no response yet.
Thanks. I'll ask around and see if I can get a contact internally that knows about this.
Chris
Hello,
I manage the Adobe Flex SDK. The QTP Automation support is built via the Flex SDK and is supported for all Flex SDKs that are supported on Flash Player 11 or newer. You can find the system requirements for Flex SDK at http://www.adobe.com/products/flex/tech-specs.html.
Is there a specific issue that you are seeing or do you just need a statement of support?
Arijit
Chris and Arijit, thanks for the response. I am going to forward this information to my customer and request them to install the most recent SDK and test against Flash. I will update you soon, however I am hoping from your statement that this should work.
-Anshoo
