1 Reply Latest reply on May 10, 2012 4:59 PM by Dave Knarr
    My capture screen is black won't let me capture cs5 premiere help
    Bertholomeu
      I'm farely new to premiere pro cs5, im trying to capture a dv tape from a deck and ive used it before but now it seems that its black screen when i pull up the capture tool, im able to fast forward and play and stop (deck control) but it just wont give me a picture. i have an external preview monitor (client monitor) and it shows the picture form the tape on there but on the capture tool there is nothing. Ive looked at the preferances and settings and it seems like everything is good but still nothing. what am i doing wrong?
        • 1. Re: My capture screen is black won't let me capture cs5 premiere help
          Dave Knarr Level 1
          Are you trying to capute via Firewire?   If so, this may help you:
          Try replacing the 1394 driver with the Legacy driver that comes with Windows 7.
          Below is the step by step instructions on how to install the Legacy driver.  This fixes caputer problems with Premiere.
          Click Start
          Then click on Control Panel
          Click on Device Manager
          Note: If you don’t see Device Manager listed, click on View By: Category on the top right side of the
               Control Panel Window.
               Then Click on Large Icons
               You should now have a list of items in the Control Panel and click on Device Manager.
          Under the Device Manager, look down the list for IEEE 1394 Bus Host Controllers and Double Click on it.
          It should display something like - 1394 OHCI Compliant Host Controller
             Note: If it has the word (Legacy) behind it, you are already setup and you can just exit out.
          Next, double click on the 1394 OHCI Compliant Host Controller
          A window will popup saying 1394 OHCI Compliant Host Controller Properties
          Click on the Driver Tab
          Then look down in the widow and click on Update Driver
          Then select - Browse my computer for driver software
          Next select - Let me pick from a list of device drivers on my computer
          It will bring up a list of drivers.
          Click on 1394 OHCI Compliant Host Controller (Legacy)
              NOTE: It is important that you select the one with (Legacy) after it, just like shown above.
          Then click Next
          Once it installs the 1394 OHCI Compliant Host Controller (Legacy),
          it will say Windows has successfully updated your driver software.
          Click on the Close button and exit out of all of the other windows.
          Then Reboot your computer.
          You will now be able to import video via the Firewire port on your computer.
          If you are still having a problem importing video after you have switched the Firewire driver to Legacy, then the problem may be with the Firewire port.  This is a common problem.  The Firewire port will work with an external driver, but it won't let you import video from your video camera.  Most people report this problem with Dell computer, but it does happen with other brands, even brand new computers.  This problem is usually with the Firewire port that is built into the motherboard.
          The fix is simple:
          1.  Install a Firewire card into one of the open slots in the computer
          2.  Using the instructions above, set the drive to Legacy.
          3.  Reboot the computer.
          4.  Then connect the Firewire cable from the video camera, into the new Firewire port that you just added.
          This fixes the problem 99% of the time.  Firewire cards are not the expensive, they run from $10 and up, depending on any extra features the card may have.
          NOTE:  We have noticed that when Microsoft has issued certain updates, it can cause Windows 7 to switch back to use the original 1394 OHCI Compliant Host Controller driver.  If you notice the Firewire device is transferring slowly again just repeat the above steps and reinstall the Legacy driver.
          Hope this helps.
          Dave
