1 Reply Latest reply on May 29, 2012 5:48 AM by singhalkapil
    Using XMLLIST - Enable/Disable Menu Items
    singhalkapil Level 1
      I am using XMLList for creating menu items.
      I want to enable / disable menu items based on the permissions to the user.
      Below is the code snippet:
      <fx:XMLList  id="newData">
                                    <menuitem id="item1" label="{resourceManager.getString('taskmgmt', 'taskmgmt.label.newProject')}" />
                                    <menuitem id="item2" label="{resourceManager.getString('taskmgmt', 'taskmgmt.label.projectFromTemplate')}" enabled="false"/>
                          </fx:XMLList>
      private function ItemClickHandler(event:MenuEvent):void
           if(PermissionManager.isAddPermitted("WTM_PROJECT_PLANNING")){
                                                             ProjectAssignmentModel.projectAssignmentFlag=false;
                                                             if(event.item.@label == resourceManager.getString('taskmgmt', 'taskmgmt.label.newProject')){
        clearModel();
        dispatchEvent(new SwitchViewEvent(SwitchViewEvent.SWITCH_VIEW_EVENT,false));
      protected function newMenuButton_clickHandler(event:MouseEvent):void
                                              if(! PermissionManager.isAddPermitted("WTM_PROJECT_PLANNING")){
                                                        newData.item1.enabled = false;
                                              else
                                                        menuList.dataProvider = newData;
                                                        menuList.show(event.stageX + 5 , event.stageY + 5);
                                                        mode = CREATE;
      Based on the permission, I want to dynamically enable / disable the "New Project" button.
      Can someone provide information how to achieve this ?
      Further update on this, it is giving the following error while running of the application:
      "TypeError: Error #1089: assignment to list with more than one item is not supported"
