1 Reply Latest reply on May 21, 2012 1:15 PM by JJMack
    Action File Save
    Jack Deblanc
      Working from Lightroom in PS - trying to record action to simply flatten layers and File Save back to Lightroom.
      PS records specific file path of original image used when action was recorded. Is there a way to eliminate this specific path?
        • 1. Re: Action File Save
          While recording the Action Save As Step do not make any changes to the default path and file names that shows up un the Save As dialog.  Just do the Save as with the defaults you can change the file type in the save as using the file type pull-down menu..  Because you made no changes to the offered folder Path and File Name nothing will be recorded into the Action Step for Folder Path and File Name.  Each image you run the action on will save into the source image folder with the default document name.
