1 Reply Latest reply on May 11, 2012 9:43 AM by Ned Murphy
    playing multiple flvs - array - listener
    ekora
      I have a custom built flv player, and I'm trying to play a few videos, one after another.  I'm using CS5, AS2...  here is what I have, but it's mostly hacked together based off of other people's code...
      //Create Net Connection object
      var nc:NetConnection = new NetConnection();
      //Tells Flash we're not using Flash Media Server
      nc.connect(null);
      //Create a Net Stream object
      var ns:NetStream = new NetStream(nc);
      //Attach Net Stream to embedded video object
      video.attachVideo(ns);
      //Create a video array to play multiple videos
      var GFYplaylist:Array = new Array();
      GFYplaylist[0] = "BAN15.f4v";
      GFYplaylist[1] = "STW15.f4v";
      //GFYplaylist[2] = "part3.flv";
      var currentlyPlaying:Number = 0;
      //Listener for array or playlist
      //import mx.video.*;  this first line is one that I don't understand - I temporarly have it commented out
      var listenerObject:Object = new Object();
      listenerObject.complete = function(eventObject:Object):Void {
          currentlyPlaying++;
          if (GFYplaylist.length > currentlyPlaying) {  // Resets counter if reaches end of array
              currentlyPlaying = 0;
          ns.play(GFYplaylist[currentlyPlaying]);
      ns.addEventListener("complete", listenerObject);
      //link player to FLV - this is what I had before the array
      ns.play("BAN15.f4v");
      Any thoughts?
      Thanks in advance
        • 1. Re: playing multiple flvs - array - listener
          Here's a different approach using onStatus... due to translating it to your variables, there might be some naming issues, but overall, it should work if you can catch/fix any if there are.
          nc.connect(null);
                   ns.onStatus = function(infoObject:Object) {
                       for (var prop in infoObject) {
                            if(infoObject[prop] == "NetStream.Play.Stop"){
                                ncount += 1;
                                if(currentlyPlaying== GFYplaylist.length){
                                     currentlyPlaying = 0; // to start over from the first
                 // kick things off
                 currentlyPlaying += 1;
