Thanks for the help! You could be right, it might not even be
possible to use context sensitive help to call a bookmark. However,
I assumed it was since RoboHelp allows you to link a Map ID to a
bookmark. In any case, information on the RH_ShowHelp() function is
here.
I'm calling the function using the following parameters:
RH_ShowHelp(0, 'http://server/project.htm>Window',
HH_HELP_CONTEXT, 29). Map ID #29 is assigned to a bookmark in a
topic, similar to this: topic.htm#bookmark.
I'm not familiar with .ali or .hh files, but here goes....
The .ali file basically lists each topic with its corresponding HTM
file. I don't have a .hh file, however the .h file lists a #define
for each mapped HTM file. One thing I noticed in the .h file is it
looks like the # sign for the bookmark has been replaced with an
underscore. So where it was topic#bookmark, it's now
topic_bookmark. Not sure if that's significant....
Thanks again for you help!
