4 Replies Latest reply on May 13, 2012 2:18 PM by ash_vir1
    help: how do i stop sound when i leave the frame?
    ash_vir1
      how do i stop a puppetsound when i  go to another frame .
      i have created a button and attached the script below to play the sound
      on mousedown
        puppetsound "abc song"
        end
      but i want the music to stop when i leave the frame
      at the moment the music is still playing when i leave the frame.
      any help
      thanx
        • 1. Re: help: how do i stop sound when i leave the frame?
          Sean_Wilson Adobe Community Professional
          You should use syntax like:
            sound(channel).play( member("name") )
          instead of the obsolete puppetSound command, and then you can use
            sound(channel).stop()
          when you leave (#endSprite)
          • 2. Re: help: how do i stop sound when i leave the frame?
            ash_vir1 Level 1
            hi sean_wilson
            i'm quite new to lingo so please excuse me for not understanding.
            i have changed it to
            on mousedown
              sound(5).play( member("abc song") )
            end
            for the stop command do i need to create another behaviour and attach it to the sprite e.g
            on frame exit
            sound(5).stop()
            end
            thanx.
            • 3. Re: help: how do i stop sound when i leave the frame?
              You are nearly correct. However, I don't think you want to respond to an #exitFrame message and stop your sound (depending on where you have the code attached). Rather, use the #endSprite message (issued when the playhead leaves a sprite's span in the score):
              on mouseDown me
              end
              on endSprite me
                sound(5).stop()
              end
              • 4. Re: help: how do i stop sound when i leave the frame?
                ash_vir1 Level 1
                i was hoping you could maybe help me further with the sound.
                i have a sound in stage channel 1 which i want to play as soon as the movies starts. and the user is able to control by pressing the pause button
                property pPaused
                on beginSprite me
                pPaused = 0
                end
                on mouseUp me
                if pPaused then sound(1).play()
                else sound(1).pause()
                pPaused = not pPaused
                end
                i have added other sound in songs (2 sounds ) and nursery rhymes (4 sounds ) with the behaviour added to the buttons as below
                on mouseDown me
                  sound(5).play( member("ABCSong") )
                end
                on endSprite me
                  sound(5).stop()
                end
                this stop the sound playing when i leave the frame but doesn't stop the sound in the stage channel 1.
                i only want to play 1 sound at a time perferly when the button is pressed and stop
                could you please advise of how to solve this problem. only using intermediate/basic lingo as i need to understand it.
                your help is much appreciated
                thank you
