3 Replies Latest reply on May 14, 2012 5:52 AM by josh_chunick
    Name / Score / Results
    Costas_B Level 1
      On the educational software i'm creating it is important to know the student who is taking the test and also track the score of the students. The software will have 4 sections with 10 or more chapters in each section.
      How can i add the name of the student and keep it till the end? For example: at the beggining of the application to prompt the user to fill his/her name.
      How can i track the score in each section and have a result page with all the scores from the 4 sections?
      Thank you in advance for any help.
      Costas--
        • 1. Re: Name / Score / Results
          josh_chunick Level 1
          Use a Parent script and initialize an instance of it using a global variable. If the sections/chapters are not going to be completed concurrently during any given session then you'll need to save the information which can be done a number of ways depending on if this will be online or offline (on a client computer).
          • 2. Re: Name / Score / Results
            Costas_B Level 1
            Thank you for your answer. It will be offline.
            Could you please give me any examples of the above? Thanks in advance.
            • 3. Re: Name / Score / Results
              After reading your other posts I think a simpler solution is in order. Use a global variable to keep track of scores. If you need to have a score for each section then make 4 global variables. For example:
              -- in a moviescript
              global gScoreSection1
              global gScoreSection2
              global gScoreSection3
              global gScoreSection4
              on startMovie
                gScoreSection1 = 0
                gScoreSection2 = 0
                gScoreSection3 = 0
                gScoreSection4 = 0
              end startMovie
              -- end of moviescript
              then, wherever your code is to add to the score for a correct answer you simply do this:
              gScoreSection1 = gScoreSection1 + 1
              you'll need to keep track of what sections you are in so however you are doing that just change to the appropriate global variable.
              Note: make sure that in each script member where you're using the global variable that you declare it at the top of the script just as in the moviescript example above, ie:
              -- in any script you use that global variable
              on someHandler me
              -- some code here
              end someHandler
              -- end script
              otherwise, if you don't declare it at the top of the script you will get an error stating something like, "Script error: Variable used before assigned a value"
