3 Replies Latest reply on May 13, 2012 10:04 PM by D Fosse
    B&W photograph for 100K print
    D Fosse Adobe Community Professional & MVP
      I need to produce a press-ready pdf from a b/w photograph. It's a reproduction of an old poster containing a bit of small text. The file is very high resolution, but still I believe it's best printed from a single plate to avoid registration issues.
      How should I prepare this file for placing in InDesign? Should I make a CMYK file with the image in the K channel only, leaving C, M and Y blank? If I place a grayscale image, will this result in a 4C black when I export to pdf?
      The CMYK profile itself is confirmed ISO Coated v2 (eci) 300%. If I place grayscale, is 15% dot gain the right one to use?
        • 1. Re: B&W photograph for 100K print
          No leave it as grayscale. Grayscales always export or print to the blackplate unchanged as long as the output destination is CMYK. If you put it on the black plate in Photoshop you might get the 4-color conversion you are trying to avoid (i.e., if you were to use a conflicting CMYK destination profile on Export or Print).
          In Photoshop the gray profile adjusts the preview, not the output numbers, so if ISO Coated v2 (eci) 300% is the correct profile for CMYK it will also be the one to use for the gray profile. You can load it in PS via Color Settings>Working Space Gray>Load Gray... then choose ISO Coated
          • 2. Re: B&W photograph for 100K print
            I would make the grayscale conversion using the Black Ink channel from your CMYK profile. You can set that as the gray profile by making a custom color settings file in Photoshop and selecting the black ink under Grayscale.
            You can save that directly fom Photoshop as PDF, or Tiff, or any other format your printer will accept. No need for ID at all unless youare adding something else. If you do need to use ID, assign teh ISO profile to the document, then place your grayscale image. As long as you don't convert to some other profile all of your black information will remain as black only and will be unaltered.
            • 3. Re: B&W photograph for 100K print
              That's clear as day . Thank you very much both!
              (Yes, Peter, I'm adding something, that's why I need ID).
