6 Replies Latest reply on May 15, 2012 6:38 AM by SAMPATH KUMAR AKIRALA
    Error #1009:  while loading datagrid in to appl
      Below exeption showing while trying to load datagrid in to my application..
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      at mx.controls::DataGrid/createItemEditor()[E:\dev\4.0.0\frameworks\projects\framework\src\m x\controls\DataGrid.as:4325]
      at mx.controls::DataGrid/itemEditorItemEditBeginHandler()[E:\dev\4.0.0\frameworks\projects\f ramework\src\mx\controls\DataGrid.as:5237]
      at flash.events::EventDispatcher/dispatchEventFunction()
      at flash.events::EventDispatcher/dispatchEvent()
      at mx.core::UIComponent/dispatchEvent()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\co re\UIComponent.as:12266]
      at mx.controls::DataGrid/commitEditedItemPosition()[E:\dev\4.0.0\frameworks\projects\framewo rk\src\mx\controls\DataGrid.as:4093]
      at mx.controls::DataGrid/updateDisplayList()[E:\dev\4.0.0\frameworks\projects\framework\src\ mx\controls\DataGrid.as:1804]
      at mx.controls.listClasses::ListBase/validateDisplayList()[E:\dev\4.0.0\frameworks\projects\ framework\src\mx\controls\listClasses\ListBase.as:3962]
      at mx.managers::LayoutManager/validateClient()[E:\dev\4.0.0\frameworks\projects\framework\sr c\mx\managers\LayoutManager.as:932]
      at mx.core::UIComponent/validateNow()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core \UIComponent.as:7631]
      at mx.managers::PopUpManagerImpl/centerPopUp()[E:\dev\4.0.0\frameworks\projects\framework\sr c\mx\managers\PopUpManagerImpl.as:485]
      at mx.managers::PopUpManager$/centerPopUp()[E:\dev\4.0.0\frameworks\projects\framework\src\m x\managers\PopUpManager.as:213]
        • 1. Re: Error #1009:  while loading datagrid in to appl
          luisborlido
          Can you show the code related with the datagrid? Are you assigning some itemRenderer?
          • 2. Re: Error #1009:  while loading datagrid in to appl
            SAMPATH KUMAR AKIRALA Level 1
            this is my code for datagrid... please check..
            <commoncomponents:ListDatagrid id="reportGroupDetailsListDG"
                                                           dataProvider="{ReportGroupDetailsModelLocator.getInstance().reportGroupVO.reportDefinitio nList}"
                                                           width="100%"
                                                           keyDown="{reportGroupDetailsHelper.handleDataGridKeyDown(event,
        Constants.VIEW_REPORT_GROUP,modelLocator.reportGroupVO.reportDefinitionList,ReportGroupDe tailComponent,'EX', -1);}"
                                                           keyUp="{reportGroupDetailsHelper.handleHotKeys(modelLocator.reportGroupVO.reportDefinitio nList,event,
        EventConstants.REPORT_GROUP_EVENT,Constants.LIST_REPORT_GROUP_DETAILS,
        reportGroupDetailsHelper.displayError, Constants.PAGE_REPORT_GROUP, -1);}"
                                <commoncomponents:columns>
                                    <mx:DataGridColumn width="20"
                                                       headerText=""
                                                       dataField="userAction"
                                                       rendererIsEditor="true"
                                                       visible="{(reportGroupDetailsHelperVO.state == Constants.STATE_EDIT ||
                                                       reportGroupDetailsHelperVO.state == Constants.STATE_ADD_NEW) ? true : false}">
                                        <mx:itemRenderer>
                                            <mx:Component>
                                                <commoncomponents:BDCUserActionTextInput height="10"
                                                              width="10"
                                                              fontFamily="Arial"
                                                              fontWeight="bold"
                                                              textAlign="center"
                                                              maxChars="1"
                                                              restrict="XE"
                                                              text="{data.userAction}"
                                                              includeInLayout="{parentDocument.reportGroupDetailsHelperVO.state == Constants.STATE_EDIT ? true : false}">
                                                    <commoncomponents:keyDown>
                                                            <![CDATA[
        ListItemVO(ReportGroupDetailsModelLocator.getInstance().reportGroupVO.reportDefinitionLis t.getItemAt
        (event.currentTarget.document.reportGroupDetailsListDG.selectedIndex)).userAction
        = event.target.text;
                                                    </commoncomponents:keyDown>
                                                <mx:Script>
                                                    <![CDATA[
                                                    import com.bnymellon.bds.bdc.ui.model.reportgroup.ReportGroupDetailsModelLocator;;
                                                    import com.bnymellon.bds.bdc.ui.vos.ListItemVO;
                                                    import com.bnymellon.bds.bdc.ui.utility.Constants;
                                                </mx:Script>
                                                </commoncomponents:BDCUserActionTextInput>
                                            </mx:Component>
                                        </mx:itemRenderer>
                                    </mx:DataGridColumn>
                                    <mx:DataGridColumn editable="false"
                                                       headerText="Report Name"
                                                       dataField="command" width="120">
                                        <mx:itemRenderer>
                                            <mx:Component>
                                                <mx:HBox paddingLeft="5">
                                                    <mx:Text styleName="normalText"
                                                             text="{data.command}"/>
                                                </mx:HBox>
                                            </mx:Component>
                                        </mx:itemRenderer>
                                                       headerText="Access Level Id"
                                                       dataField="accountScopeID" width="150">
                                        <mx:itemRenderer>
                                            <mx:Component>
                                                             text="{data.reportGroupScopeId}"/>
                                                </mx:HBox>
                                            </mx:Component>
                                        </mx:itemRenderer>
                                                       headerText="Security ID"
                                                       dataField="security" width="140">
                                        <mx:itemRenderer>
                                            <mx:Component>
                                                             text="{data.security}"/>
                                                </mx:HBox>
                                            </mx:Component>
                                        </mx:itemRenderer>
                                                       headerText="Qualifier"
                                                       dataField="reportParam">
                                        <mx:itemRenderer>
                                            <mx:Component>
                                                    <mx:Text styleName="normalText" width="100%"
                                                             text="{data.parameter}"/>
                                                </mx:HBox>
                                            </mx:Component>
                                        </mx:itemRenderer>
                                                       headerText="FileType"
                                                       dataField="fileFormat" width="80">
                                        <mx:itemRenderer>
                                            <mx:Component>
                                                             text="{'.' + data.fileFormat}"/>
                                                </mx:HBox>
                                            </mx:Component>
                                        </mx:itemRenderer>
                                </commoncomponents:columns>
                            </commoncomponents:ListDatagrid>
            • 3. Re: Error #1009:  while loading datagrid in to appl
              luisborlido Level 1
              Try to remove this line includeInLayout="{parentDocument.reportGroupDetailsHelperVO.state == Constants.STATE_EDIT ? true : false}". Other than that, I don't see nothing that could be causing the exception, without debbuging the code.
              Sorry if this doesn't help.
              • 5. Re: Error #1009:  while loading datagrid in to appl
                luisborlido Level 1
                What about BDCUserActionTextInput? Did you use it somewhere else? Can you post the code?
                • 6. Re: Error #1009:  while loading datagrid in to appl
                  private function BDCUserActionTextInput()
                  width = 10;
                  height=10;
                  maxChars=1;
                  addEventListener(KeyboardEvent.KEY_DOWN, handleKeyDown);
                  addEventListener(Event.CHANGE, handleChange);
                  addEventListener(ResizeEvent.RESIZE, handleResize);
                  How add item renderers at run time
