1 Reply Latest reply on Aug 17, 2006 10:45 AM by CathyM
    what's MessageAgent's destination
    mounte
      i am trying to make the remoteobject work on my mxml. but i got this error
      [RPC Fault faultString="[MessagingError message='The MessageAgent's destination must be set to send messages.']" faultCode="InvokeFailed" faultDetail="Couldn't establish a connection to ''"]
      at mx.rpc::AbstractInvoker/ http://www.adobe.com/2006/flex/mx/internal::invoke()
      at mx.rpc.remoting.mxml::Operation/ http://www.adobe.com/2006/flex/mx/internal::invoke()
      at mx.rpc.remoting::Operation/send()
      at Function/ http://adobe.com/AS3/2006/builtin::apply()
      at mx.rpc.remoting.mxml::Operation/send()
      at mx.rpc::AbstractService/ http://www.adobe.com/2006/actionscript/flash/proxy::callProperty()
      at RALogging1/___Button1_click()
      this is the part of my mxml and the error pops up when the button is clicked. i have a javaclass "LogManager" under WEB-INF\classes\ra\logging. so i think i need to do something on some config xml. what do i need to do?
      ra.logging.LogManager :
      <mx:RemoteObject id="logMgr" source="ra.logging.LogManager" fault="Alert.show(event.fault.faultString, 'Error');">
      <mx:method name="getList"/>
      </mx:RemoteObject>
      <mx:HBox>
      <mx:Button label="Get Log List" click="logMgr.getList()"/>
      </mx:HBox>
        • 1. Re: what's MessageAgent's destination
          CathyM
          The 'source' attribute is only sufficient when using a RemoteObject connection to a resource on a ColdFusion server.
          Please refer to RemoteObject documention -
          http://livedocs.macromedia.com/flex/2/langref/mx/rpc/remoting/mxml/RemoteObject.html
          In all other cases, you'll need to define your RemoteObject destination in the configuration file. The Flex 2 Developer's guide had information on configuring these files. Examples are also available at <fds_install>/resources/config/remoting-config.xml.
          In your case, you'll add the following definition to remoting-config.xml -
          <destination id="LogManagerDestination">
          <properties>
          <source>ra.logging.LogManager</source>
          </properties>
          The code in your mxml file will look like this -
          <mx:RemoteObject id="logMgr" destination="LogManagerDestination" ... etc> </mx:RemoteObject>
          There will be no 'source' attribute in your RemoteObject tag.
