5 Replies Latest reply on May 15, 2012 9:13 AM by Muppet Mark
    Cannot open a file by Applescript
    Alan Shutko Level 1
      With Photoshop CS6, I am getting an error trying to open a file. This breaks a few of my scripts which continue to work with CS5.
      This code, copied almost exactly from the CS6 Applescript Reference, returns
      error "Adobe Photoshop CS6 got an error: File some object wasn’t found." number -43
      Passing myFilePath to Finder works perfectly fine to open the alias.
      tell application "Adobe Photoshop CS6"
                set myFilePath to alias "Macintosh HD:Users:ats:Downloads:Photoshop-CS6-AppleScript-Ref.pdf"
                tell application "Finder"
        open myFilePath
                end tell
        open myFilePath as PDF with options {class:PDF open options, height:pixels 100, width:pixels 200, mode:RGB, resolution:72, use antialias:true, page:1, constrain proportions:false}
      end tell
        • 1. Re: Cannot open a file by Applescript
          Muppet Mark Level 5
          That's from the guide? Hum looks back to front to me… You want Finder or system events to get the file path and Photoshop to open it…
          • 2. Re: Cannot open a file by Applescript
            Alan Shutko Level 1
            Technically, the guide was:
            set myFilePath to alias "Data:docsamples:testfiles:PdfTest.pdf" open myFilePath as PDF with options ¬
            {class:PDF open options, height:pixels 100, width:pixels 200, ¬
            mode:RGB, resolution:72, use antialias:true, page:1, ¬
            end tell
            I modified it to fit my pathname, and added the tell block for Finder to test whether the file alias was openable.
            • 3. Re: Cannot open a file by Applescript
              Muppet Mark Level 5
              Photoshop messed up quite a lot of peoples AppleScripts with CS5 it didn't like Finder alias specifiers it preferred strings… Setting a file as alias should confrim the path existence…
              • 4. Re: Cannot open a file by Applescript
                Alan Shutko Level 1
                Thanks. That hint got me going.  I ended up moving the alias down a line from setting myFilePath to the open command. This works.
                          set myFilePath to "Macintosh HD:Users:ats:Downloads:Photoshop-CS6-AppleScript-Ref.pdf"
                  open alias myFilePath as PDF with options {class:PDF open options, height:pixels 100, width:pixels 200, mode:RGB, resolution:72, use antialias:true, page:1, constrain proportions:false}
                end tell
                • 5. Re: Cannot open a file by Applescript
                  Muppet Mark Level 5
                  Yeah that looks better… I don't have CS6 so I wasn't able to check… With CS5 things changed with using File & Alias I wasn't too sure if it had been swapped back… Untested…
                  set myFilePath to "Macintosh HD:Users:ats:Downloads:Photoshop-CS6-AppleScript-Ref.pdf" -- a string
                  -- then coerce inside tell app block
                  tell application "Adobe Photoshop CS5"
                    open alias myFilePath as PDF with options ¬
                  end tell
                  -- ditto here
                    open file myFilePath as PDF with options ¬
                  end tell
