5 Replies Latest reply on Jun 28, 2012 2:39 AM by asmudge
    AE CS6 doesnt recognize my ATI Radeon HD 6850 video card GPU
    Corrado Giuliani
      As in the title, it keeps me saying GPU is not enabled while OpenGL 4.1 is supported. Any suggestions?
        • 1. Re: AE CS6 doesnt recognize my ATI Radeon HD 6850 video card GPU
          What exactly does it say? Provide a screenshot of your OpenGL preferences and also your exact system specs. Also have you updated your graphics driver?
          Mylenium
          • 2. Re: AE CS6 doesnt recognize my ATI Radeon HD 6850 video card GPU
            Corrado Giuliani Level 1
            The video driver should be correctly updated, i launched just yesterday a quick AMD app to do that.
            I dont get what screenshot you want, i dont have any OpenGL preferences in Video Card settings, but i do have put below the screenshot of AE OpenGL preferences, evenif the first part is in Italian.
            By the way the productor's specs formy card are (from the site):
            AMD Radeon™ HD 6850 GPU Feature Summary:
            • 775MHz Engine Clock
            • 1GB GDDR5 Memory
            • 1000MHz Memory Clock (GDDR5)
            • 128 Gbps memory bandwidth (maximum)
            • 1.5 TFLOPS compute power
            • Double slot form factor
            • TeraScale 2 Unified Processing Architecture
              • 960 Stream Processors
              • 48 Texture Units
              • 128 Z/Stencil ROP Units
              • 32 Color ROP Units
            • PCI Express® 2.1 x16 bus interface
            • "Eye-Definition" graphics
              • DirectX® 11 support
                • Shader Model 5.0
                • DirectCompute 11
                • Programmable hardware tessellation unit
                • Accelerated multi-threading
                • HDR texture compression
                • Order-independent transparency
              • OpenGL 4.1 support
              • Image quality enhancement technology
                • Up to 24x multi-sample and super-sample anti-aliasing modes
                • Adaptive anti-aliasing
                • Morphological anti-aliasing (MLAA)
                • 16x angle independent anisotropic texture filtering
                • 128-bit floating point HDR rendering
            • AMD Eyefinity multi-display technology1
              • Independent resolutions, refresh rates, color controls, and video overlays
              • Display grouping
                • Combine multiple displays to behave like a single large display
            • AMD App Acceleration2
              • AMD Accelerated Parallel Processing (APP) technology3,4
                • OpenCL 1.1
                • DirectCompute 11
                • Accelerated video encoding, transcoding, and upscaling
              • UVD 3 dedicated video playback accelerator
                • MPEG-4 AVC/H.264
                • VC-1
                • MPEG-2 (SD & HD)
                • Multi-View Codec (MVC)
                • MPEG-4 part 2 (DivX, Xvid)
                • Adobe Flash
              • Enhanced Video Quality features
                • Advanced post-processing and scaling
                • Dynamic contrast enhancement and color correction
                • Brighter whites processing (Blue Stretch)
                • Independent video gamma control
                • Dynamic video range control
              • Dual-stream HD (1080p) playback support
              • DXVA 1.0 & 2.0 support
            • AMD HD3D technology5
              • Stereoscopic 3D display/glasses support
              • Blu-ray 3D support
              • Stereoscopic 3D gaming
              • 3rd party Stereoscopic 3D middleware software support
            • AMD CrossFireX™ multi-GPU technology6
              • Dual GPU scaling
            • Cutting-edge integrated display support
              • DisplayPort 1.2
                • Max resolution: 2560x1600 per display
                • Multi-Stream Transport
                • 21.6 Gbps bandwidth
                • High bit-rate audio
              • HDMI® (With 3D, Deep Color and x.v.Color™)
                • Max resolution: 1920x1200
              • Dual-link DVI with HDCP
              • VGA
                • Max resolution: 2048x1536
            • Integrated HD audio controller
              • Output protected high bit rate 7.1 channel surround sound over HDMI or DisplayPort with no additional cables required
              • Supports AC-3, AAC, Dolby TrueHD and DTS Master Audio formats
            • AMD PowerPlay™ power management technology4
              • Dynamic power management with low power idle state
              • Ultra-low power state support for multi-GPU configurations
            • AMD Catalyst™ graphics and HD video configuration software
              • Unified graphics display drivers
                • Certified for Windows 7, Windows Vista, and Windows XP
              • AMD Catalyst Control Center™
                • Software application and user interface for setup, configuration, and accessing special features of AMD Radeon products
            http://i48.tinypic.com/1zbdxdg.png
            • 3. Re: AE CS6 doesnt recognize my ATI Radeon HD 6850 video card GPU
              Todd_Kopriva Level 8
              What, exactly, is your issue? You showed a screenshot, but I don't know what your question is. The title of your thread says that After Effects doesn't recognize your GPU, but your screenshot shows that it does recognize it and is correctly reporting on such things as its OpenGL capabilities.
              Are you thinking that your card should be providing the GPU-accelerated ray-traced 3D renderer? If so, then you need to read this:
              http://blogs.adobe.com/toddkopriva/2012/05/gpu-cuda-opengl-features-in-after-effects-cs6.h tml
              • 4. Re: AE CS6 doesnt recognize my ATI Radeon HD 6850 video card GPU
                I was just wondering if my card should provide GPU-accelerated ray traced 3d rendering. In the list card i see that Radeon HD-6850 is not supported and i now understand why it renders so slowly.
                By the way this is very disappointing, i was evaluating the trial copy and i was very happy of the new features the company added, but this problem , if cannote be fixed , will quite certainly stop me in advancing in the buying procedure.
                • 5. Re: AE CS6 doesnt recognize my ATI Radeon HD 6850 video card GPU
                  asmudge
                  So, what your page is telling me (and what most of your specifications pages tell me) is that you pretty much only support NVIDIA cards?
                  You do realise, that this is a breach of competition laws. You are intentionally preventing owners of Radeon and FirePro cards from getting similar productivity out of your products.
                  What is stopping you taking advantage of AMD technologies and stream processing?
                  You're excluding a lot of people by not doing so.
