1. Re: How to render and export
JSS1138 May 14, 2012 10:06 PM (in response to PaulSahota92)There's the problem with an Unknown Error. I'm afraid we aren't diviners capable of simply "knowing" what the problem is even when the software itself doesn't know.
2. Re: How to render and export
PaulSahota92 May 14, 2012 10:11 PM (in response to JSS1138)This is my second day with prpro cs6. i have spent 4 hours on this project and so frustrated that why did i make this mistake to use prpro cs6 on edius 6.
3. Re: How to render and export
JSS1138 May 14, 2012 10:29 PM (in response to PaulSahota92)Yeah, that really sucks when you get a shiny new toy and it doesn't work right. We've all been there.
Try a few things, like different export settings, a new project, remove the effects, etc. Maybe you can isolate the issue and work around it.
4. Re: How to render and export
John T Smith May 15, 2012 8:17 AM (in response to PaulSahota92)click this link and provided the requested information, someone may have ideas
5. Re: How to render and export
PaulSahota92 May 15, 2012 9:40 PM (in response to John T Smith)1. IM USING VERSION 6.0.0 319 MC:264587 CS6
2. IT IS UPDATED TO LATEST UPDATE
3. WINDOW 7 64 BIT
4. SOURCE FOOTAGE MXF FILES FROM CANON XF 305 CAMERA AT 1920 BY 1080 30P 50MBPS
5.ERROR COMPILING MOVIE - UNKNOWN ERROR
6. I WAS EXPORTING THE PROJECT TO H.264 YOU TUBE UPLOAD
7. NO THIRD PARTY EFFECTS JUST THE ONE FROM PR PRO CS6
8. NO MERCURY PLAYBACK
9 ONLY WHEN EXPORTING
HERE IS THE IMAGE OF MY PROJECT:
6. Re: How to render and export
Jeff Bellune May 21, 2012 1:30 PM (in response to PaulSahota92)Redundant post deleted. If you need to bump your topic, just reply with a post containing the word "bump".
Jeff
7. Re: How to render and export
SAFEHARBOR11 May 21, 2012 1:51 PM (in response to Jeff Bellune)Make sure you don't have a one-frame gap between any clips, these can be invisible until you zoom in closer
Jeff Pulera
Safe Harbor Computers
8. Re: How to render and export
PaulSahota92 May 21, 2012 1:57 PM (in response to SAFEHARBOR11)Hi Jeff
On my last two clips I inserted a video transition and I received a message saying not suffiecnt space frames will be repeated. So I separated the clip with small gap and inserted a transition in the gap. I hope this is causing the issue. Thank you I will try to export it again.
9. Re: How to render and export
JSS1138 May 21, 2012 1:59 PM (in response to PaulSahota92)You went the wrong way. Instead of separating the clips for the transition, you need to overlap them to make it work.
10. Re: How to render and export
SAFEHARBOR11 May 21, 2012 2:01 PM (in response to PaulSahota92)Most likely that it is then. You need to trim the end of first clip and beginning of next clip, then butt them together, so there is "overlap", or extra frames available for the transition between the clips. One way to do this is to put the mouse pointer on the end of the clip and then press CTRL key, bracket will change then you can trim end of clip with a Ripple Edit (everything after moves as you adjust). Quucikly trim ins and outs this way so you can add transition
jeff
11. Re: How to render and export
PaulSahota92 May 21, 2012 3:04 PM (in response to SAFEHARBOR11)Hi Jeff
I overlapped my last two clips and inserted a transition between them. Exporting did go upto 75% and error compiling came again.
12. Re: How to render and export
Bill Hunt May 21, 2012 3:29 PM (in response to PaulSahota92)For those Clips, you have too few Frames, past the Out Point, or before the In Point. Those are called Handles. This ARTICLE will go into more detail.
14. Re: How to render and export
shooternz May 21, 2012 5:11 PM (in response to PaulSahota92)You can not transition between two clips if there are no frames to make the transition with. eg "Handles"
You can not make "handles" but you can make your in and out points on the clips at a different place so as you have spare overlap frames ( which become the handles).
The Transition effect uses these spare frames to build the effect
15. Re: How to render and export
PaulSahota92 May 21, 2012 11:32 PM (in response to shooternz)This is been a week now I'm struggling with this problem. I just cant export it. I even overlapped the clips, no transtiion but same thing is happening error compling movie.
16. Re: How to render and export
PaulSahota92 May 25, 2012 1:59 PM (in response to PaulSahota92)SOULTION for others who are in same situation:
First update your software to the latest update.
I believe you have more than one clip.
At the end and begining of the clip you should have little grey triangle shape.
They are called handles, meaning extra space at end point and at begining. Usaually for transition.
If you dont see it on both clips (as in picture above) then the one clip which is misiing need to be trimed little or more until handles disappear or some time you see full triangle (as in picture).
Do same if there are more.
Then just try to export the ending where clips attach each other.
Set in and out points as I did in the picture above.
Export and make sure to choose sequence in and out setting.
I hope it works. I dont use this software anymore. I had a trail version. Used for two weeks. Every day same problem then finally figured it out and moved back to Edius 6. Thanks
