3 Replies Latest reply on May 29, 2012 5:00 AM by Vibhuti Gosavi(InfoCepts)
    Remove thousand seperator in flex 4
    mohamed.ashik
      Flex 4
      In the TextInput thousandSeprator is present. When I click on the button that formatted thousand seperator has to be removed.
      Need result as below ,
      from 1,234 to 1234.
      Please help in getting sorted out.
        • 1. Re: Remove thousand seperator in flex 4
          Vibhuti Gosavi(InfoCepts) Level 3
          Set the property "useThousandsSeparator" as false. Please try following code snippet :
                                           xmlns:mx="library://ns.adobe.com/flex/mx"
                                           minWidth="955" minHeight="600">
                    <fx:Script>
                              <![CDATA[
                                        import mx.events.ValidationResultEvent;
                                        private var result:ValidationResultEvent;
                                        private function checkFormat():void
                                                  result = numValidate.validate();
                                                  if (result.type==ValidationResultEvent.VALID) {
                                                            numval.text= numberFormatter.format(numtxt.text);
                                                  else {
                                                            numval.text= "Invalid Number";
                    </fx:Script>
                    <fx:Declarations>
                              <mx:NumberFormatter id="numberFormatter"
        useThousandsSeparator="false" useNegativeSign="true"/>
                              <mx:NumberValidator id="numValidate" source="{numtxt}" property="text"
        allowNegative="true" domain="real"/>
                    </fx:Declarations>
                    <s:Panel title="NumberValidator Example" width="506">
                              <mx:Form backgroundColor="#096465" width="504">
                                        <mx:FormItem label="Enter number:" color="#FFFFFF" fontFamily="verdana">
                                                  <s:TextInput id="numtxt" text="" width="100%" color="#000000" fontFamily="verdana"/>
                                        </mx:FormItem>
                                        <mx:FormItem label="Formatted Value: " color="#FFFFFF" fontFamily="verdana">
                                                  <s:Label id="numval" color="#FFFFFF" fontFamily="verdana"/>
                                        </mx:FormItem>
                                        <mx:FormItem>
                                                  <s:Button label="Format" click="checkFormat();"/>
                                        </mx:FormItem>
                              </mx:Form>
                    </s:Panel>
          </s:Application>
          Thanks and Regards,
          Vibhuti Gosavi | vgosavi@infocepts.com | www.infocepts.com
          • 2. Re: Remove thousand seperator in flex 4
            mohamed.ashik Level 1
            thanks dude... Many thanks..
            Need another help man.
            While entering in to the same textbox it should change like
            When you type in the text box like 1234 - it should automatically change to 1,234.
            There should not be any button. Only textbox in the page. I am using Flex 4.
            • 3. Re: Remove thousand seperator in flex 4
              Called checkFormat function on change event of text input and set useThousandSeparator property to true
              Here is the code :
                        <fx:Script>
                                  <![CDATA[
        numtxt.text= numberFormatter.format(numtxt.text);
                                                      else {
        numtxt.text= "Invalid Number";
                        </fx:Script>
                        <fx:Declarations>
        useThousandsSeparator="true" useNegativeSign="true"/>
                        </fx:Declarations>
                                                      <s:TextInput id="numtxt" text="" width="100%" color="#000000" fontFamily="verdana" change="checkFormat()"/>
                                            </mx:FormItem>
                </mx:Form>
                        </s:Panel>
              </s:Application>
              Thanks and Regards,
