5 Replies Latest reply on May 18, 2012 2:49 PM by chris.campbell
    INSTALLED FLASH THREE WEEKS AGO, FLASH UPDATES WORKING IN ACTIVE X  BUT NOT IN OTHER BROWSERS
    mrjohncougar
      Hi I installed flash 11.2.202.233 about three weeks ago. The active x flash verson has updated to the new version 11.2.202.235, but it won'tupdate in the other browsers,firefox and opera. I have windows xp sp3 32 bit. I will copy the flash log so you can tell maybe what's wrong. I would like to fix it however if i need to uninstall all the flash I'd rather just update the other browsers manually since flash is working fine. And do you think it will correct it self by installing the new version? I'm talking about of course about the background updater not working. Thanks.
      =O====== M/10.3.183.10 2011-09-27+18-59-27.046 ========
      0000 [I] 00000010 "C:\DOCUME~1\bailey\LOCALS~1\Temp\2.dir\InstallFlashPlayer.exe" -iv 0
      0001 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
      0002 [W] 00001036 Software\Opera Software/Last CommandLine 2
      0003 [W] 00001036 Software\Opera Software/Last CommandLine 2
      0004 [W] 00001036 Software\Opera Software/Plugin Path 2
      0005 [I] 00000014 C:\WINDOWS\system32\Macromed\Flash\NPSWF32.dll
      0006 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10x_Plugin.exe
      0007 [I] 00000017 C:\WINDOWS\system32\Macromed\Flash
      0008 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
      0009 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
      0010 [W] 00001024 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 183
      =X====== M/10.3.183.10 2011-09-27+18-59-38.171 ========
      =O====== M/10.3.183.10 2011-09-29+15-59-32.265 ========
      0000 [I] 00000010 "C:\Documents and Settings\Howard\Local Settings\Temp\install_flash_player_ax.exe" -dlm -install
      0001 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\Flash10w.ocx 20
      0002 [I] 00000018
      0003 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\Flash10w.ocx 20
      0004 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash10x.ocx
      0005 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10x_ActiveX.exe
      0006 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10x_ActiveX.dll
      0007 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
      0008 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
      0009 [W] 00001024 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 183
      =X====== M/10.3.183.10 2011-09-29+15-59-33.625 ========
      =O====== M/11.0.1.152 2011-10-25+14-04-09.890 ========
      0000 [I] 00000010 "C:\Documents and Settings\Howard\Local Settings\Temp\install_flash_player_ax_32bit.exe" -dlm -install
      0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
      0002 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
      0003 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\Flash10x.ocx 20
      0004 [I] 00000018
      0005 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\Flash10x.ocx 20
      0006 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash11c.ocx
      0007 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_ActiveX.exe
      0008 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_ActiveX.dll
      0009 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
      =X====== M/11.0.1.152 2011-10-25+14-04-11.593 ========
      =O====== M/11.0.1.152 2011-10-25+14-21-57.484 ========
      0000 [I] 00000010 "C:\Documents and Settings\Howard\Local Settings\Temp\install_flash_player_32bit.exe" -dlm -install
      0001 [F] 00001041
      =X====== M/11.0.1.152 2011-10-25+14-21-57.656 ========
      =O====== M/11.0.1.152 2011-10-25+14-22-02.296 ========
      0001 [F] 00001041
      =X====== M/11.0.1.152 2011-10-25+14-22-02.906 ========
      =O====== M/11.0.1.152 2011-10-25+14-22-04.625 ========
      0001 [F] 00001041
      =X====== M/11.0.1.152 2011-10-25+14-22-04.750 ========
      =O====== M/11.0.1.152 2011-10-25+14-23-59.843 ========
      0001 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
      0002 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
      0004 [W] 00001036 Software\Opera Software/Last CommandLine 2
      0005 [W] 00001036 Software\Opera Software/Plugin Path 2
      0006 [I] 00000014 C:\WINDOWS\system32\Macromed\Flash\NPSWF32.dll
      0007 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_Plugin.exe
      0008 [I] 00000017 C:\WINDOWS\system32\Macromed\Flash
      =X====== M/11.0.1.152 2011-10-25+14-24-01.046 ========
      =O====== M/11.0.1.152 2011-10-25+14-26-08.859 ========
      0004 [I] 00000018
      =X====== M/11.0.1.152 2011-10-25+14-26-10.718 ========
      =O====== M/11.1.102.55 2011-11-15+15-10-52.421 ========
      0002 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\Flash11c.ocx 20
      0003 [I] 00000018
      0004 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\Flash11c.ocx 20
      0005 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash11e.ocx
      0006 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11e_ActiveX.exe
      0007 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11e_ActiveX.dll
      =X====== M/11.1.102.55 2011-11-15+15-10-54.250 ========
      =O====== M/11.1.102.55 2011-11-15+15-39-15.656 ========
      0003 [I] 00000018
      =X====== M/11.1.102.55 2011-11-15+15-39-17.703 ========
      =O====== M/11.1.102.55 2011-11-16+14-51-49.281 ========
      0007 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11e_Plugin.exe
      =X====== M/11.1.102.55 2011-11-16+14-51-50.312 ========
      =O====== M/11.1.102.55 2011-11-16+15-17-42.843 ========
      0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\install_flash_player_11_active_x_32bit.exe"
      0002 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash11e.ocx
      0003 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11e_ActiveX.exe
      0004 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11e_ActiveX.dll
      0005 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
      0006 [W] 00001024 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 183
      =X====== M/11.1.102.55 2011-11-16+15-17-52.640 ========
      =O====== M/11.1.102.63 2012-03-17+14-15-18.406 ========
      0002 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\Flash11e.ocx 20
      0003 [I] 00000018
      0004 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\Flash11e.ocx 20
      0005 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash11g.ocx
      0006 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11g_ActiveX.exe
      0007 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11g_ActiveX.dll
      =X====== M/11.1.102.63 2012-03-17+14-15-20.968 ========
      =O====== M/11.1.102.63 2012-03-17+14-20-08.000 ========
      0000 [I] 00000010 "C:\Documents and Settings\Howard\My Documents\Downloads\install_flash_player_11_plugin_32bit.exe"
      0002 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
      0003 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
      0005 [W] 00001036 Software\Opera Software/Last CommandLine 2
      0006 [W] 00001036 Software\Opera Software/Plugin Path 2
      0007 [I] 00000014 C:\WINDOWS\system32\Macromed\Flash\NPSWF32.dll
      0008 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11g_Plugin.exe
      0009 [I] 00000017 C:\WINDOWS\system32\Macromed\Flash
      0010 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
      0011 [W] 00001024 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 183
      =X====== M/11.1.102.63 2012-03-17+14-20-18.671 ========
      =O====== M/11.1.102.63 2012-04-30+14-56-01.171 ========
      0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil11g_Plugin.exe" -update plugin
      =X====== M/11.1.102.63 2012-04-30+14-56-33.828 ========
      =O====== M/11.2.202.233 2012-05-01+13-59-33.765 ========
      0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_11_2_202_233_ActiveX.exe" -refreshIEElevationPolicies
      =X====== M/11.2.202.233 2012-05-01+13-59-33.937 ========
      =X====== M/11.2.202.233 2012-05-01+13-59-33.984 ========
      =O====== M/11.2.202.233 2012-05-01+13-59-31.359 ========
      0000 [I] 00000010 "C:\Documents and Settings\Howard\Local Settings\Temp\install_flash_player_ax_32bit.exe" -iv 8 -install -au 0
      0002 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\Flash11g.ocx 20
      0003 [I] 00000018
      0004 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\Flash11g.ocx 20
      0005 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash32_11_2_202_233.ocx
      0006 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_11_2_202_233_ActiveX.exe
      0007 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_11_2_202_233_ActiveX.dll
      0010 [I] 00000021 C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe
      0011 [W] 00001102
      0012 [W] 00001106
      0013 [I] 00000012
      =X====== M/11.2.202.233 2012-05-01+13-59-34.187 ========
      =O====== M/11.2.202.233 2012-05-01+14-06-09.343 ========
      0000 [I] 00000010 "C:\Documents and Settings\Howard\Local Settings\Temp\install_flash_player_32bit.exe" -iv 8 -install
      0007 [I] 00000014 C:\WINDOWS\system32\Macromed\Flash\NPSWF32_11_2_202_233.dll
      0008 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_11_2_202_233_Plugin.exe
      0012 [W] 00001024 C:\WINDOWS\system32\FlashPlayerApp.exe 183
      0013 [I] 00000021 C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe
      0014 [W] 00001106
      0015 [W] 00001106
      0016 [W] 00001024 C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
      0017 [I] 00000012
      =X====== M/11.2.202.233 2012-05-01+14-06-10.796 ========
      =O====== M/11.2.202.233 2012-05-02+14-04-07.671 ========
      0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_11_2_202_233_Plugin.exe"
      0001 [E] 00001039
      =X====== M/11.2.202.233 2012-05-02+14-04-12.890 ========
      2012-5-15+15-1-8.93 [error] 1226 1062
      =O====== M/11.2.202.235 2012-05-15+15-01-06.171 ========
      0000 [I] 00000010 FlashPlayerInstaller.exe -install -iv 9
      0002 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash32_11_2_202_235.ocx
      0003 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.exe
      0004 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.dll
      0007 [W] 00001024 C:\WINDOWS\system32\FlashPlayerApp.exe 183
      0008 [I] 00000021 C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe
      0009 [W] 00001106
      0010 [W] 00001106
      0011 [W] 00001024 C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
      0012 [I] 00000012
      =X====== M/11.2.202.235 2012-05-15+15-01-08.125 ========
      Message was edited by: mrjohncougar
