1 Reply Latest reply on Apr 3, 2008 1:32 PM by slaingod
    Release Build issue.
    user341975
      I have an existing app and setup my workstation for development purpose. I have imported existing app. The following is my app structure.
      Application
      --Bin
      --Src
      ----Cfc
      ----Login.mxml
      I made changes to login.mxml and used “project/release build” option to get the executable files. When I place the files on the server, I keep getting an error about .cfc files not found. System was looking for .cfm components at “application\src\cfc” folder. My server structure is as follows
      Application
      --Dev
      ----cfc
      ----login.mxml
      --Test
      ----cfc
      ----login.mxml
      --Prod
      ----cfc
      ----login.mxml
      The code works fine if I create a folder called “Src” directly under application root folder and copy all my .cfc components. Which is a problem as all dev, test and prod environment is looking at “Src” folder. I want each of the folder should have its source so I can keep it separated. I know I am doing some thing wrong. May be there is way where I can specify the path to look for the .cfc components. I am not able to find. Please help
