3 Replies Latest reply on May 18, 2012 9:28 PM by Gupthika
    Remove empty object frame
    Gupthika
      How to remove empty object frame.(rectangle without image)
        • 1. Re: Remove empty object frame
          Select it with the black arrow, then press "Delete".
          Is this a scripting question? What language? What version of ID? What have you tried so far, and where do you get stuck?
          Do you need someone to write a script for you? Are you willing to pay for it?
          • 2. Re: Remove empty object frame
            Gupthika Level 1
            I try the below code but it delete tables inside rectangle. i tried in javascript.
            var doc = app.activeDocument;
            var myPages = app.activeDocument.pages;
                for (var p = 0; p < myPages.length; p++)
                                     var myGraphicFrames = app.activeDocument.pages[p].rectangles;
                                     for (j = myGraphicFrames.length - 1; j >= 0; j--)
                                               if (myGraphicFrames[j].graphics.length == 0)
                                                         app.selection = myGraphicFrames[j];
                                                         alert (app.activeWindow.activePage.name);
            • 3. Re: Remove empty object frame
              Gupthika Level 1
              Hi Friends,
              is there any other way to remove empty frame?
              Gupthika
