6 Replies Latest reply: May 16, 2012 7:30 AM by Syberkitten RSS
    how to know if pRTMP is enabled / working?
    Syberkitten Community Member
      We'v been trying to set up a protected vod stream pRTMP (4.5.2)
      following the official directions presented here:
      http://help.adobe.com/en_US/flashmediaserver/devguide/WSa8864cc5538a7459-62090543133c7eb00 c7-8000.html#WSa8864cc5538a7459f964f76133cc300593-7fff
      And it seems that the pRTMP does not kick in
      as the server is serving media to both player 10 and 11,
      which is weird since pRTMP should work only on flash player 11?
      how can i know that pRTMP is working actually?
      the documentation for it is VERY poor, 1.5 pages
      and no client api or any console info what so ever.
      if protected content is played on normal players feeding
      from VOD, then it means the p inside RTMP is not working, right?
      otherwise the content should be block for clients running low flash
      player version,
      - could this be because we are using the common-key.bin
      which is provided by default?
      - do we need to configure any certificated for pRTMP other then provided in the default installation?
      - does swf verification need be enabled? (yes tried it true and false, same results)
      any help would be appreciated
        • 1. Re: how to know if pRTMP is enabled / working?
          Apurva Udaykumar Adobe Employee
          You can check the application logs to see if pRTMP has been configured. The application logs are here : root_install/logs/_defaultVHost_/<app_name>.
          When pRTMP is configured and the app is loaded, the application logs should contain logs as follows :
          Application level Protected RTMP configuration: ContentProtection[enabled=true, [content id: //_defaultRoot_/_defaultVHost_/vod/_definst_, common key: /opt/adobe/ams/creds/common-key.bin, license server url: http://license_server.fms.adobe.com/, transport cert file: /opt/adobe/ams/creds/static/phds_production_transport.der, license server cert file: /opt/adobe/ams/creds/static/phds_license_server.der, packager credential file: /opt/adobe/ams/creds/static/phds_production_packager.pfx, policy file: /opt/adobe/ams/creds/static/phds_24hr_policy.pol, encrypt audio: 1, encrypt data: 1, encrypt video: 1, video encrypt level: 2, license server credential: /opt/adobe/ams/creds/static/phds_license_server.pfx, share domain certs path: /opt/adobe/ams/creds/sd, update interval: 3600000 swf verification: SWFVerification[enabled=false]]]
          Could you please verify if the logs?
          Apurva
          • 2. Re: how to know if pRTMP is enabled / working?
            thanks for th reference -) this is what i have inside the application.00.log:
            2012-05-1615:24:043441(i)2611173Application level Protected RTMP configuration: ContentProtection[enabled=true, [content id: //_defaultRoot_/_defaultVHost_/vod/_definst_, common key: /opt/adobe/fms/phds/common-key.bin, license server url: http://license_server.fms.adobe.com/, transport cert file: /opt/adobe/fms/phds/static/phds_production_transport.der, license server cert file: /opt/adobe/fms/phds/static/phds_license_server.der, packager credential file: /opt/adobe/fms/phds/static/phds_production_packager.pfx, policy file: /opt/adobe/fms/phds/static/phds_24hr_policy.pol, encrypt audio: 1, encrypt data: 1, encrypt video: 1, video encrypt level: 2, license server credential: /opt/adobe/fms/phds/static/phds_license_server.pfx, share domain certs path: /opt/adobe/fms/phds/sd, update interval: 3600000 swf verification: SWFVerification[enabled=true, whilelist folder: /opt/adobe/fms/applications/vod/swf_whitelist]]]
            would appreciate any further insights
            • 3. Re: how to know if pRTMP is enabled / working?
              Are you using an OSMF based media player?
              • 4. Re: how to know if pRTMP is enabled / working?
                no, we have a custom player which connects to our servers via rtmp
                and requests a media file (VOD scheme)
                the 4.5.2 server in question serves the same files our other 3.5 FMS servers
                serve.
                yet as i mentioned enabling / disabling pRTMP does not change anything.
                we have players running on flash player 10.1 and they are "as if" playing pRTMP
                like nothing is wrong (which means pRTMP is not working imho).
                The whole issue arose from a content provider
                who insists we use HLS, but there are no
                HLS solutions for flash (OSMF or not) which implement
                the AES-128 encrypion that is required.
                i know that the JWPlayer does support HLS but no future
                AES-128 support is planned.
                this all brought us to consider PHDS, but the configuration
                of PHDS is complicated and requires intricate system work
                therefore brought us to check out what seemed a straightforward solution,
                the pRTMP.
                do you think we would have better luck with PHDS?
                • 5. Re: how to know if pRTMP is enabled / working?
                  Are you seeing playback of the stream with pRTMP enabled on Flash player 10 or is it just increase in play time? I'm unable to reproduce this issue on my end.
                  Also, in case you plan to give PHDS a try you'll find relevent information here : http://help.adobe.com/en_US/flashmediaserver/devguide/WS47c0525fe440307e-685173b213221ed70 9a-8000.html.
                  • 6. Re: how to know if pRTMP is enabled / working?
                    yes, we are seeing Normal playback on Flash Player 10 with pRTMP enabled.
                    when you say you are unable to reproduce, what Error or Exception does the flash
                    player or FMS server throw when unauthorized or unsufficient player is trying
                    to access an pRTMP stream?
                    I will send you a private message with our player running on pRTMP
                    (which should not work)
