1 Reply Latest reply on May 17, 2012 12:57 AM by Maximist
    “ld: absolute addressing” ERROR when compile imported ane file inside new project in Flash Builder
    Maximist Level 1
      I'm coding an extension (ANE) for iPhone that read the contact list. I receive an error when add the .ane to my Flash Builder Project and compile it. I compiled the Objective-c code in a *.a lib without problems. I compiled the .ane without errors.
      This is the error when i add the .ane at the main Flex Project:
      Error occurred while packaging the application:
      ld
      : absolute addressing (perhaps -mdynamic-no-pic) used in _getContatti from
      /var/folders/j9/j9OzOTqhGJGpr2m87bnYEU+++TQ/-Tmp-/888e0e80-9ef5-4d2a-9e34-
      c01545b25bfc
      /mylib.library.com.a(ExtensionMyLibIOSNative.o)
      not allowed in slidable image
      . Use '-read_only_relocs suppress' to enable text
      relocs
      Compilation failed while executing : ld64
      In Xcode i have already set "Enable Linking With Shared Libraries" to "NO" in Build Settings. This is the Objective-c code that cause the error:
      FREObject getContatti(FREContext ctx, void* funcData, uint32_t argc, FREObject argv[]) {
      FREObject nome_visualizzato;
      FREObject nome_visualizzatoPrimario;
      FREObject nome_visualizzatoAlternativo;
      ABAddressBookRef addressBook = ABAddressBookCreate( );
      CFArrayRef allPeople = ABAddressBookCopyArrayOfAllPeople( addressBook );
      CFIndex nPeople = ABAddressBookGetPersonCount( addressBook );
      FREObject arrayContatti;
      FRENewObject((const uint8_t*)"Vector.<extension.MyLibrary.entity.Contatto>", 0, NULL, &arrayContatti, NULL);
      FRESetArrayLength(arrayContatti, nPeople);
      for ( int i = 0; i < nPeople; i++ )
      ABRecordRef ref = CFArrayGetValueAtIndex( allPeople, i );
      CFStringRef first = ABRecordCopyValue(ref, kABPersonFirstNameProperty);
      CFStringRef last = ABRecordCopyValue(ref, kABPersonLastNameProperty);
      CFStringRef company = ABRecordCopyValue(ref, kABPersonOrganizationProperty);
      -- DO SOMETHING --
      return result;
      It works if i comment\remove the lines:
      I would apprecciate any kind of help.
      Thx
      Max
