1 Reply Latest reply on May 16, 2012 1:21 PM by Peter Spier
    Using columns to specify English / Latin - HELP!
    ceencha Level 1
      Friends,
      I desire to use COLUMNS to help with layout design.
      As you can see, I need to go BACK AND FORTH between "span column" titles, and double columns:
      http://www.ccwatershed.org/pdfs/212-massive/download/
      In Design CS5.5 has been working great, UNTIL I hit a page turn.
      I can only figure out how to make it function the wrong way:
      http://www.ccwatershed.org/pdfs/213-wrong/download/
      Is there a way to make it function the correct way??
      http://www.ccwatershed.org/pdfs/214-right/download/
      I also tried using tables, but In Design will not split up a cell . . .
      Please help!
        • 1. Re: Using columns to specify English / Latin - HELP!
          This is a pretty complex layout, and I'm not sure span and split columns is the way to go at all.
          We have other users who do a lot of multilingual stuff, and I hope they will weigh in, but I think you are probably going to end up needing to use separtely threaded one-column frames in parallel to each other, and break  the frames to insert new wide frames in those places where a heading needs to span.
