Has anyone been able to successfully install ColdFusion 10 on Red Hat Enterprise 6.1?
I have been trying to get it to work, but when I try to load the CF administrator after the installation I get an apache/tomcat error.
http://127.0.0.1:8500/CFIDE/administrator/index.cfm
exception
javax.servlet.ServletException: java.lang.NullPointerException
coldfusion.bootstrap.ClassloaderHelper.initServletClass(ClassloaderHelper.java:129)
coldfusion.bootstrap.BootstrapServlet.init(BootstrapServlet.java:59)
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:928)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:414)
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:987)
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:539)
org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:298)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
java.lang.Thread.run(Thread.java:662)
root cause
coldfusion.CfmServlet.init(CfmServlet.java:82)
coldfusion.bootstrap.ClassloaderHelper.initServletClass(ClassloaderHelper.java:121)
Any suggestions?
Simon
Hi Simon,
The license service makes use of InetAddress.getLocalHost() API and therefore your /etc/hosts file should have an entry for both localhost as well as for your host name.
Your /etc/hosts file should look like
# This is an example of the hosts file
127.0.0.1 localhost
::1 localhost
127.0.0.1 LMCFXD01
Once you have the hosts file corrected, you should be all set.
Check out http://en.wikipedia.org/wiki/Hosts_(file)
Regards,
Rupesh
I'm not sure if this will help. This is the content of coldfusion-error.log from the first time the CF service tried to start
I can browse directories and HTML files using the builtin web server, but as soon as it's a .cfm page I get an error. It didn't work using apache as the web server either so I suspect there is something wrong with tomcat / CF or some permission problem somewhere.
When installing CF on RHEL I put SELinux into passive mode and also created a link to libc.so.6 so the warning when starting the CF installer disappeared.
As an extra test I setup coldfusion to use the nobody user and also root just to see if it would make a difference.
Hope somebody can help.
Simon
May 17, 2012 11:24:23 AM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /opt/coldfusion10/jre/lib/amd64/server:/opt/coldfusion10/jre/lib/amd64:/opt/coldfusion10/jre/../lib/amd64:/opt/coldfusion10/cfusion/lib:/opt/coldfusion10/cfusion/lib/_ilnx21/bin:/opt/coldfusion10/cfusion/lib/international::/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
May 17, 2012 11:24:23 AM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-bio-8500"]
May 17, 2012 11:24:24 AM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["ajp-bio-8012"]
May 17, 2012 11:24:24 AM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
May 17, 2012 11:24:24 AM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.23
May 17, 2012 11:24:29 AM org.apache.catalina.util.SessionIdGenerator createSecureRandom
INFO: Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [5,002] milliseconds.
May 17, 2012 11:24:31 AM org.apache.catalina.core.ApplicationContext log
INFO: ColdFusionStartUpServlet: ColdFusion: Starting application services
INFO: ColdFusionStartUpServlet: ColdFusion: VM version = 20.4-b02
Could not determine local hostname.
at coldfusion.sql.Executive.load(Executive.java:258)
at coldfusion.server.ServiceBase.start(ServiceBase.java:59)
at coldfusion.sql.Executive.start(Executive.java:129)
at coldfusion.server.CFService.setupSql(CFService.java:147)
at coldfusion.server.CFService.start(CFService.java:548)
at coldfusion.server.j2ee.CFStartUpServlet.startCFService(CFStartUpServlet.java:110)
at coldfusion.server.j2ee.CFStartUpServlet.init(CFStartUpServlet.java:86)
at javax.servlet.GenericServlet.init(GenericServlet.java:160)
at coldfusion.bootstrap.ClassloaderHelper.initServletClass(ClassloaderHelper.java:121)
at coldfusion.bootstrap.BootstrapServlet.init(BootstrapServlet.java:59)
at org.apache.catalina.core.StandardWrapper.initServlet(StandardWrapper.java:1266)
at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1185)
at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:1080)
at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:5001)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5278)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1525)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1515)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
at coldfusion.runtime.RuntimeServiceImpl.getQueueLimit(RuntimeServiceImpl.java:1957)
at coldfusion.runtime.RuntimeServiceImpl.load(RuntimeServiceImpl.java:399)
at coldfusion.server.j2ee.CFServiceImpl.setupRuntime(CFServiceImpl.java:98)
at coldfusion.server.CFService.start(CFService.java:560)
May 17, 2012 11:24:35 AM org.apache.catalina.core.ApplicationContext log
INFO: CFMxmlServlet: Macromedia Flex Build: 87315.134646
at coldfusion.CfmServlet.init(CfmServlet.java:82)
May 17, 2012 11:24:36 AM org.apache.catalina.core.ApplicationContext log
INFO: failed to load: coldfusion.CfmServlet
May 17, 2012 11:24:36 AM org.apache.catalina.core.StandardContext loadOnStartup
SEVERE: Servlet / threw load() exception
at coldfusion.xml.rpc.CFCServlet.init(CFCServlet.java:120)
May 17, 2012 11:24:37 AM org.apache.catalina.core.ApplicationContext log
INFO: failed to load: coldfusion.xml.rpc.CFCServlet
May 17, 2012 11:24:37 AM org.apache.catalina.core.StandardContext loadOnStartup
coldfusion.server.ServiceFactory$ServiceNotAvailableException: The Runtime service is not available.
at coldfusion.server.ServiceFactory.getRuntimeService(ServiceFactory.java:117)
at coldfusion.cfc.ServerCFCServlet.init(ServerCFCServlet.java:31)
May 17, 2012 11:24:38 AM org.apache.catalina.core.ApplicationContext log
INFO: failed to load: coldfusion.cfc.ServerCFCServlet
May 17, 2012 11:24:38 AM org.apache.catalina.core.StandardContext loadOnStartup
May 17, 2012 11:24:38 AM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-8500"]
INFO: Starting ProtocolHandler ["ajp-bio-8012"]
May 17, 2012 11:24:38 AM com.adobe.coldfusion.launcher.Launcher run
INFO: Server startup in 16359 ms
at org.apache.catalina.core.StandardWrapper.allocate(StandardWrapper.java:857)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:135)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:169)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:928)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:414)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:987)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:539)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:300)
May 17, 2012 11:26:23 AM org.apache.catalina.core.ApplicationContext log
May 17, 2012 11:26:23 AM org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Allocate exception for servlet CfmServlet
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:298)
May 17, 2012 11:35:56 AM org.apache.catalina.core.ApplicationContext log
May 17, 2012 11:35:56 AM org.apache.catalina.core.StandardWrapperValve invoke
May 17, 2012 11:36:01 AM org.apache.catalina.core.ApplicationContext log
May 17, 2012 11:36:01 AM org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Allocate exception for servlet CFCServlet
There seems to be some reason because of which the RuntimeService is not coming up which is causing all other NPEs here. Could you please delete all the log files, restart the server and provide us the errors that you see in coldfusion-out.log, coldfusion-error.log and exception.log file?
You can post the exceptions here or send the log files to me at rukumar at adobe dot com.
Hi Simon,
127.0.0.1 localhost
::1 localhost
127.0.0.1 LMCFXD01
Regards,
Rupesh
Thanks Rupesh!!
For anyone else that stumbles onto this thread there were a couple of lines near the top of the coldfusion-out.log file
May 17, 2012 21:53:15 PM Fatal [pool-2-thread-1] - LMCFXD01: LMCFXD01
May 17, 2012 21:53:15 PM Error [pool-2-thread-1] - Unable to initialise License service: coldfusion.server.ServiceException: LMCFXD01: LMCFXD01
Once I made the changes to the hosts file as per Rupesh's suggestion the errors were all resolved and I am finally able to get into the CF administrator
Thanks again!
Simon
