1 Reply Latest reply on Apr 3, 2008 2:43 AM by Newsgroup_User
    Application on PC with 2 monitors
    Level 7
      Hi
      If some user have a PC with 2 monitors attached, how can I define, on which
      monitor my application will is currently shown?
      It is opened on primary display but the user can move it later to another
      display.
      I need to change resolution on that screen, where application windows is
      positioned at the moment.
      Any help will be appreciated
      game_dev
        • 1. Re: Application on PC with 2 monitors
          Level 7
          Check out 'the desktopRectList'
          It will give you a list of the rect (screen res) of each monitor. Using
          that, you can tell which size monitors are in what location. Mine looks
          like this for example:
          put the desktopRectList
          -- [rect(0,0,1680,1050),rect(-1280,0,0,1024)]
          Which tells you that I have 2 monitors (there are 2 entries). And the
          1st one is the primary screen with a resolution of 1680 x 1050. The 2nd
          screen is to the left of the primary (negative rect[1] value), and it
          has a resolution of 1280x1024.
          If you look at BuddyAPI (www.mods.com.au/budapi), it has a number of
          functions for dealing with multi monitors and screen resolution as well.
