1 Reply Latest reply on May 16, 2012 11:07 PM by kglad
    XML string to Array?
    raylaur Level 1
      I want this XML code to become an array in AS2  (code is a snipet of large code)
      <ViewTitles><![CDATA[Front View,  Back View, Left View, Right View, Internal View]]></ViewTitles>
      The XML loads correctly.  The following code yields the expected string:
      var vTitles=UInode.childNodes[1].childNodes[0];
      trace(vTitles)
      Flash Output: Front View,  Back View, Left View, Right View, Internal View
      I then use the following to turn it ino an array:
      viewTitles=vTitles.split(", ");
      trace(viewTitles[0])
      Flash Output: undefined
      It seems vTitles=UInode.childNodes[1].childNodes[0] is not recognized as a string.
      I've tried vTitles.toString();  before using split() but no luck.
      What is the best way to convert a string from XML to an array.  Am I not using the correct syntax?
