2 Replies Latest reply on May 22, 2012 12:01 PM by lancedolan
    How to consume REST WebService using Axis2 in Adobe CQ5.5
    abhaymish1 Level 1
      Hi All,
          How to consume REST WebService using Axis2 in Adobe CQ5.5 ?
      Please help me with this.Thanks very much for your help.
      Thanks & Regards,
      Kumar
        • 1. Re: How to consume REST WebService using Axis2 in Adobe CQ5.5
          nicolas peltier Adobe Employee
          your question looks ackward...are we talking about REST, or SOAP?
          if you have the choice, use REST that is natively supported by CQ thanks to Apache Sling, and leave Axis2.
          If not, you'll have to deploy Axis2 as an OSGI bundle :
          http://stackoverflow.com/questions/5994323/how-to-make-axis2-run-in-an-osgi-environment
          hope this helps.
          • 2. Re: How to consume REST WebService using Axis2 in Adobe CQ5.5
            lancedolan
            We had enough trouble getting the "osgi compliant" Axis2 library to run in OSGI without spooky failures that we ended up re-writing everything utilizng JAX-WS. JAX-WS is present in the underlying JDK, you just need to create an OSGI fragment bundle that exposes these classes from the JDK. So basically a bundle that just exports:
            com.sun.xml.ws,
                                            com.sun.xml.ws.addressing,
                                            com.sun.xml.ws.addressing.model,
                                            com.sun.xml.ws.addressing.v200408,
                                            com.sun.xml.ws.api,
                                            com.sun.xml.ws.api.addressing,
                                            com.sun.xml.ws.api.client,
                                            com.sun.xml.ws.api.fastinfoset,
                                            com.sun.xml.ws.api.handler,
                                            com.sun.xml.ws.api.message,
                                            com.sun.xml.ws.api.message.stream,
                                            com.sun.xml.ws.api.model,
                                            com.sun.xml.ws.api.model.soap,
                                            com.sun.xml.ws.api.model.wsdl,
                                            com.sun.xml.ws.api.pipe,
                                            com.sun.xml.ws.api.pipe.helper,
                                            com.sun.xml.ws.api.server,
                                            com.sun.xml.ws.api.streaming,
                                            com.sun.xml.ws.api.wsdl.parser,
                                            com.sun.xml.ws.api.wsdl.writer,
                                            com.sun.xml.ws.binding,
                                            com.sun.xml.ws.client,
                                            com.sun.xml.ws.client.dispatch,
                                            com.sun.xml.ws.client.sei,
                                            com.sun.xml.ws.developer,
                                            com.sun.xml.ws.developer.servlet,
                                            com.sun.xml.ws.encoding,
                                            com.sun.xml.ws.encoding.fastinfoset,
                                            com.sun.xml.ws.encoding.soap,
                                            com.sun.xml.ws.encoding.soap.streaming,
                                            com.sun.xml.ws.encoding.xml,
                                            com.sun.xml.ws.fault,
                                            com.sun.xml.ws.handler,
                                            com.sun.xml.ws.message,
                                            com.sun.xml.ws.message.jaxb,
                                            com.sun.xml.ws.message.saaj,
                                            com.sun.xml.ws.message.source,
                                            com.sun.xml.ws.message.stream,
                                            com.sun.xml.ws.model,
                                            com.sun.xml.ws.model.soap,
                                            com.sun.xml.ws.model.wsdl,
                                            com.sun.xml.ws.org.objectweb.asm,
                                            com.sun.xml.ws.protocol.soap,
                                            com.sun.xml.ws.protocol.xml,
                                            com.sun.xml.ws.resources,
                                            com.sun.xml.ws.server,
                                            com.sun.xml.ws.server.provider,
                                            com.sun.xml.ws.server.sei,
                                            com.sun.xml.ws.server.servlet,
                                            com.sun.xml.ws.spi,
                                            com.sun.xml.ws.streaming,
                                            com.sun.xml.ws.transport,
                                            com.sun.xml.ws.transport.http,
                                            com.sun.xml.ws.transport.http.client,
                                            com.sun.xml.ws.transport.http.server,
                                            com.sun.xml.ws.transport.http.servlet,
                                            com.sun.xml.ws.util,
                                            com.sun.xml.ws.util.exception,
                                            com.sun.xml.ws.util.localization,
                                            com.sun.xml.ws.util.pipe,
                                            com.sun.xml.ws.util.xml,
                                            com.sun.xml.ws.wsdl.parser,
                                            com.sun.xml.ws.wsdl.writer,
                                            com.sun.xml.ws.wsdl.writer.document,
                                            com.sun.xml.ws.wsdl.writer.document.http,
                                            com.sun.xml.ws.wsdl.writer.document.soap,
                                            com.sun.xml.ws.wsdl.writer.document.soap12,
                                            com.sun.xml.ws.wsdl.writer.document.xsd,
                                            com.sun.xml.internal.bind,
                                            com.sun.xml.internal.bind.v2,
                                            com.sun.xml.internal.ws,
                                            com.sun.xml.internal.ws.addressing,
                                            com.sun.xml.internal.ws.addressing.model,
                                            com.sun.xml.internal.ws.addressing.v200408,
                                            com.sun.xml.internal.ws.api,
                                            com.sun.xml.internal.ws.api.addressing,
                                            com.sun.xml.internal.ws.api.client,
                                            com.sun.xml.internal.ws.api.fastinfoset,
                                            com.sun.xml.internal.ws.api.handler,
                                            com.sun.xml.internal.ws.api.message,
                                            com.sun.xml.internal.ws.api.message.stream,
                                            com.sun.xml.internal.ws.api.model,
                                            com.sun.xml.internal.ws.api.model.soap,
                                            com.sun.xml.internal.ws.api.model.wsdl,
                                            com.sun.xml.internal.ws.api.pipe,
                                            com.sun.xml.internal.ws.api.pipe.helper,
                                            com.sun.xml.internal.ws.api.server,
                                            com.sun.xml.internal.ws.api.streaming,
                                            com.sun.xml.internal.ws.api.wsdl.parser,
                                            com.sun.xml.internal.ws.api.wsdl.writer,
                                            com.sun.xml.internal.ws.binding,
                                            com.sun.xml.internal.ws.client,
                                            com.sun.xml.internal.ws.client.dispatch,
                                            com.sun.xml.internal.ws.client.sei,
                                            com.sun.xml.internal.ws.developer,
                                            com.sun.xml.internal.ws.encoding,
                                            com.sun.xml.internal.ws.encoding.fastinfoset,
                                            com.sun.xml.internal.ws.encoding.soap,
                                            com.sun.xml.internal.ws.encoding.soap.streaming,
                                            com.sun.xml.internal.ws.encoding.xml,
                                            com.sun.xml.internal.ws.fault,
                                            com.sun.xml.internal.ws.handler,
                                            com.sun.xml.internal.ws.message,
                                            com.sun.xml.internal.ws.message.jaxb,
                                            com.sun.xml.internal.ws.message.saaj,
                                            com.sun.xml.internal.ws.message.source,
                                            com.sun.xml.internal.ws.message.stream,
                                            com.sun.xml.internal.ws.model,
                                            com.sun.xml.internal.ws.model.soap,
                                            com.sun.xml.internal.ws.model.wsdl,
                                            com.sun.xml.internal.ws.org.objectweb.asm,
                                            com.sun.xml.internal.ws.protocol.soap,
                                            com.sun.xml.internal.ws.protocol.xml,
                                            com.sun.xml.internal.ws.resources,
                                            com.sun.xml.internal.ws.server,
                                            com.sun.xml.internal.ws.server.provider,
                                            com.sun.xml.internal.ws.server.sei,
                                            com.sun.xml.internal.ws.spi,
                                            com.sun.xml.internal.ws.streaming,
                                            com.sun.xml.internal.ws.transport,
                                            com.sun.xml.internal.ws.transport.http,
                                            com.sun.xml.internal.ws.transport.http.client,
                                            com.sun.xml.internal.ws.transport.http.server,
                                            com.sun.xml.internal.ws.util,
                                            com.sun.xml.internal.ws.util.exception,
                                            com.sun.xml.internal.ws.util.localization,
                                            com.sun.xml.internal.ws.util.pipe,
                                            com.sun.xml.internal.ws.util.xml,
                                            com.sun.xml.internal.ws.wsdl.parser,
                                            com.sun.xml.internal.ws.wsdl.writer,
                                            com.sun.xml.internal.ws.wsdl.writer.document,
                                            com.sun.xml.internal.ws.wsdl.writer.document.http,
                                            com.sun.xml.internal.ws.wsdl.writer.document.soap,
                                            com.sun.xml.internal.ws.wsdl.writer.document.soap12,
                                            com.sun.xml.internal.ws.wsdl.writer.document.xsd,
                                            com.sun.xml.internal.messaging.saaj.soap
