3 Replies Latest reply on May 28, 2012 3:41 AM by M-Bailey
    Colour Management & Dot Gain
    Andy_Baz Level 2
      Im looking for clarification on how i should approach colour management settings when my rip compensates for dot gain for the different paper types.
      I am sending litho plates out via a pdf based workflow utilising a harlequin rip.
      My questions..
      If my workflow (harlequin rip) is calibrated to adjust for dot gain depending on different paper types ( FOGRA Coated/Uncoated) should i then just be sending files to it that are not tagged with profiles/colourmanaged to prevent multiple conversions?
      Should i colour manage pre-rip and allow for dot gain (2 conversions) or is only 1 or the other necessary?
      For example...
      1. I am assigning a FOGRA coated profile to my images in photshop
      2. Then placing my image in my indesign layout and exporting it to pdf using FOGRA coated settings
      3. pdf is then dropped into the workflow
      4. pdf is ripped and dot gain allowance is applied
      5. Plate is then outputted
      Any thoughts please
      Andy barrington
      www.barringtonprint.com
        • 1. Re: Colour Management & Dot Gain
          gator soup Level 4
          it's usually a bad move in Photoshop to Assign a profile unless the source image was created and saved in that colorspace or the correct source profile was first applied and then Converted to that profile and then saved...
          • 2. Re: Colour Management & Dot Gain
            John Danek Level 4
            I'd want to see your InDesign Color Settings.  The RIP should have a choice in its calibration methods whether to honor .icc profiles and application settings.  So, hypothetically if you feed it a PDF job that includes profiles and honors existing application color setups ( PS, Ai, ID, etc., etc. ) and the RIP is set to honor app color settings and profiles, then no duplication of dot gain adjustment will take place.  If the RIP is set to not honoring app color settings and/or profiles, then it will adjust for dot gain.  Look into your RIP's calibration and whether or not it honors application color settings and .icc profiles.  Should it somehow apply a second round of dot gain adjustments, then deselect dot gain adjustments in your desktop applications.  You only need dot gain adjustment done once.
            • 3. Re: Colour Management & Dot Gain
              M-Bailey
              You might get better answers on the Harlequin RIP forum at http://www.harlequinrip.com/community/
              Martin
