0 Replies Latest reply on Mar 28, 2008 9:19 AM by kaygeebee
    Type Coercion Error
    kaygeebee
      Hello,
      I have a webservice that operates on a datamodel, as shown in the xsd given below(part of it):-
      <complexType name="PersonNameType">
      <sequence>
      <choice maxOccurs="unbounded">
      <element name="GivenName" type="mpeg7:NameComponentType" />
      <element minOccurs="0" name="LinkingName" type="mpeg7:NameComponentType" />
      <element minOccurs="0" name="FamilyName" type="mpeg7:NameComponentType" />
      <element minOccurs="0" name="Title" type="mpeg7:NameComponentType" />
      <element minOccurs="0" name="Salutation" type="mpeg7:NameComponentType" />
      <element minOccurs="0" name="Numeration" type="string" />
      </choice>
      </sequence>
      </complexType>
      <complexType name="NameComponentType">
      <simpleContent>
      <extension base="mpeg7:TextualBaseType">
      <attribute name="initial" type="string" use="optional" />
      <attribute name="abbrev" type="string" use="optional" />
      </extension>
      </simpleContent>
      </complexType>
      While invoking webservice from flex using AS3
      Setting values in the givenname of NameComponentType throws the following Exception:
      Error #1034: Type Coercion failed: cannot convert tva.mpeg7._2005::NameComponentType@30acc69 to QName.
      Somehow it is not able to identify the NameComponent Type, the moment i try to create and initialize its values, i get the above error.
      Kindly advice as to what might be happening ...
      Thanks in advance,
      KayGeeBee
