2 Replies Latest reply on May 18, 2012 1:57 PM by brian01kenney
    problems installing mac flash player
      I have tried repeatedly to uninstall existing Flash Player and install Flash Player 11 ( on a Mac OSX 10.6.8 64-bit system running Safari (64-bit), without success.
      The dialog box says that installation was successful, and if you check Apple / System Preferences / Flash Player / Advanced / Updates, it indicates that "Plug-in version is installed.",
      but if I try to run anything requiring Flash, it does not work, and when I go to
      under Flash Player Help / Find Version / Flash Player
      1. Check if Flash Player is installed on your computer
      I see a blank gray box, indicating that Flash Player is not installed.
      I have followed all of the instructions on Flash Player Help / Installation Problems / Mac OS and uninstalled and reinstalled flash multiple time, with firewalls and antivirus system disabled and everything active force quit, and I get exactly the same results ... Flash appears to be installed, but does not work ... any suggestions?
