4 Replies Latest reply: May 18, 2012 9:19 AM by Bill Hunt RSS
    Making sound come from different places
    Soshman Community Member
      Hello,
      I create Self help DVD's.
      Some of them are made for headphones. In the past i have heard audio that moves around..or it sounds that way.
      Left and right is common but i have heard it made where it sounds as if it is coming from the front or above or the back.
      Ultimitley  i would like it to sound as if i am walking around them ( while talking  to them ) as they sit and listen with thier eyes closed...
      Is it possible to do this with Premiere Pro 5 ( i will be getting 6 soon )
      If not is there any software you might recommend that i could do this and easily add to my Premiere Pro?
      Thanks!
        • 1. Re: Making sound come from different places
          did this get moved?
          • 2. Re: Making sound come from different places
            shooternz Community Member
            did this get moved?
            Only you know where you left it and saw it last.
            • 3. Re: Making sound come from different places
              Hindsight_Productions Community Member
              While I have not done much with Dobly 5.1 surround sound, I believe that you can disburse and assign your sound files to 5 different speakers in a way to make it sound as though someone or something is moving around the listener.
              • 4. Re: Making sound come from different places
                Bill Hunt CommunityMVP
                With DD 5.1 SS, this is very easy, as one has a full sound "stage" to work with. As has been stated, one has five locations to work with. The LFE channel is essentially non-directional, and is seldom located, as the human ear cannot usually differentiate the source, or apparent source of the LFE channel.
                I work with a lot of DD 5.1 SS, and can perceive, to a limited degree, location beyond the common L - R Pan, with my stereo headphones, though my DD 5.1 SS card. This is obviously no where near as sharp a differentiation, as with either 5.1 SS headphones (limited number of those, and some have various "quirks"), or better, a full 5.1 SS system, but with some practice, and listening, one can get a bit of apparent Fade (the F - R term for sound placement in the sound stage).
                To Export to DD 5.1 SS, one will need the Minnetonka Audio SurCode DD 5.1 SS Encoder plug-in, or similar.
                The full and correct playback of a 5.1 SS Audio file will depend on one's system.
                In PrPro, one would set up their Project with a 5.1 Master. If they do not have a DD 5.1 SS Encoder, then that will mix-down to 2-channel.
