2 Replies Latest reply on May 22, 2012 11:41 AM by Pharther Phurther
    Mac Users: Does your "Console" App Log These Errors?
    Pharther Phurther Level 1
      Thank you for your time.
      I am using a 12 Core 2.93 GHZ with 32 GB RAAM and a NVidia GTX 285.
      Mac OS X 10.7.4
      Adobe Master Suite 5.5
      The Apple "Console" app logs a whole lot of these three Adobe related errors:
      1. 5/18/12 2:10:16.260 AM aeselflink: CFURLCreateWithString was passed this invalid URL string: '/System/Library/Frameworks/System.framework' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
      2.) 5/18/12 2:10:16.331 AM aeselflink: -[NSMenu menuID]: unrecognized selector sent to instance 0x1183100e0
      5/18/12 2:10:17.333 AM aeselflink: -[NSMenu menuID]: unrecognized selector sent to instance 0x115625740
      3.) 5/18/12 2:11:18.596 AM [0x0-0x9b09b].com.adobe.aerendercore: You have at least one output module template that refers to a missing output plug-in.  Please check your Output Module Templates.
      If you have the time please look to confirn. The app is in the "Utilities" Folder .. inside the Applications Folder
      If you are running CS 6 .. could you please check to see if these error are also there?
      I may be having file system errors with my RAID due to the "URL" error.
      I'm trying to work with the tech support at Areca with discovery.
