3 Replies Latest reply on May 18, 2012 2:19 AM by Iain Robinson
    [JS][CS5.5] Syntax query
    Iain Robinson
      Hi all
      After another long gap I'm coming back to scripting again and I've probably forgotten most of what I learned here before. I'm trying to capture the contents of the first paragraph (which identifies what sort of article it is) so I can then analyse it and do different things depending on what it finds. I think I can do the analysis (famous last words!) but I'm stuck at the first hurdle.
      If I use a para style to identify the first para (which obviously means I'd have to ask the client to style it) it works okay;
      //Find the first para in the story (which contains the article type)
      app.findGrepPreferences.appliedParagraphStyle = "Identifier";
      firstPara = myDoc.findGrep();
      articleType = firstPara[0].contents;
      alert(articleType);
      But if I try to identify the first para using GREP (using app.findGrepPreferences.findWhat  = "\A^.+$";), which would be better as the para wouldn' thave to be styled, I get an "undefined is not an object error". Running a manual GREP search in ID with \A^.+$ finds the first para so it must be the syntax is wrong in my code.
      Can anyone point out where I am going wrong please?
      thanks,
      Iain
