1 Reply Latest reply on May 18, 2012 11:17 PM by Michael Thornburgh
    can not set  multicastRelayMarginDuration
    whwi999
      hello
      i try set the multicastRelayMarginDuration in my p2p application multicast broadcaster
      netStream.multicastWindowDuration = 31;  // change default for everybody
      netStream.multicastPushNeighborLimit = 10; // change default for everybody
      netStream.multicastRelayMarginDuration = 5; // change default for everybody
      netStream.publish("stream");
      netStream.multicastRelayMarginDuration = 5; //test for HD
      //netStream.multicastPushNeighborLimit = 10;
      //netStream.multicastWindowDuration = 30;
      i test with http://osmf.org/dev/1.6gm/setup.html and see the
      multicastWindowDuration is set to 31 sec for everybody this works fine
      the multicastPushNeighborLimit is alwys 4 i think this is ok because its an security limit set this value to more than 4
      but the multicastRelayMarginDuration is alwys 2 sec is this normal? i can not set this value?
      best regards
        • 1. Re: can not set  multicastRelayMarginDuration
          Michael Thornburgh Adobe Employee
          the multicastPushNeighborLimit and multicastRelayMarginDuration are set individually at each member; they are not inherited from the publisher. the defaults are 4 and 2 seconds respectively.
          you can override any of the multicast parameters (including the window duration) at each peer. listen for NetStream.MulticastStream.Reset (which signals (re)attachment of a low-level multicast stream) and set/override the ones you want to change each time.
          the parameters that are inherited from the publisher (but can still be overridden at each peer) are:
             multicastAvailabilitySendToAll
             multicastAvailabilityUpdatePeriod
          also, if multicastPushNeighborLimit is 0, peers will inherit 0. if the publisher has a non-zero multicastPushNeighborLimit, peers will start with the default of 4.
          these parameters are not inherited from the publisher, and have default initial values at each peer:
            multicastFetchPeriod
             multicastPushNeighborLimit (see exception/explanation above)
