1 2 Previous Next 51 Replies Latest reply on Jan 26, 2016 1:32 PM by RaydarV
    Is there a Flash ActiveX registry cleaner?
    EthanAD Level 1
      Recently it has come to our attention that one of the version 10 Flash Player ActiveX releases caused registry problems that prevented successful upgrades even after the deployment has shown a successful installation via SCCM. The bad version caused a series of registry artifacts, and bad entries in Add/Remove Programs (as many as 8 bad entries from previous upgrades). This is now causing some complaints among users, and investigation has revealed an alarming number of computers with broken Flash Player ActiveX installations.
      The error we see on these computers is "Error 2753. The File 'InstallAX.exe' is not marked for installation."
      Removing the registry entries by product GUID works, however there seems to be sporadic GUIDs, and missing even one of them will fail to solve the problem. Research based on this error has shown very spotty resolutions.
      Is there a known-good script or program out there to fix this problem?
      Thank you!
        • 1. Re: Is there a Flash ActiveX registry cleaner?
          chris.campbell Adobe Employee
          Does it help if you run themost recent stand alone uninstaller first?
          Chris
          • 3. Re: Is there a Flash ActiveX registry cleaner?
            EthanAD Level 1
            Thanks for the response Chris.
            We have tried using the uninstaller and it reports a successful uninstall but all of the old versions are listed in the registry and is still unable to install a Flash ActiveX.package.
            Only after deleting all reg entries with the Flash ActiveX GUIDs in HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\ are we able to install a Flash ActixeX package.
            I would like to avoid trying to use a search and destroy script by keyword in the registries on this many machines. Frankly I have never written anything that complex for the registry and would like to avoid it altogether.
            If there is an existing script that is known to be safe for this function, I'd love to see it.
            • 4. Re: Is there a Flash ActiveX registry cleaner?
              I'm pinging our installer team for their input.  I'll let you know what they say.
              • 5. Re: Is there a Flash ActiveX registry cleaner?
                Ok, we've got a few more questions for you.  Can we get:
                1. What are the exact registry paths which still exist in the registry after running the uninstaller?
                2. The FlashInstall.log from the following locations on a system that exhibits this issue?
                C:\Windows\System32\Macromed\Flash\
                C:\Windows\SysWOW64\Macromed\Flash\
                If you'd prefer sending me the files, please feel free to contact me directly at ccampbel@adobe.com
                Chris
                • 6. Re: Is there a Flash ActiveX registry cleaner?
                  EthanAD Level 1
                  Requested info sent via email.
                  • 7. Re: Is there a Flash ActiveX registry cleaner?
                    Thanks again for sending the information along to us.  Here's what I've heard back.
                    We're not familiar with any of the registry entries or GUIDs (they don’t appear to be product GUIDs), although it’s possible that they are somehow related to our older MSI installer.
                    The entries appear to be part of the Microsoft installation sub-system and are not directly managed by Adobe.
                    I have heard of corruption issues that can occur on Windows which impact MSI upgrades/uninstalls, but such issues are beyond our control. We recommend investigate a fix on Microsoft’s support site.
                    I'm curious if running the Windows installer Fix-It and doing an uninstall via that would help.  It might be worth a try.
                    Microsoft Install and Uninstall Fix It
                    • 8. Re: Is there a Flash ActiveX registry cleaner?
                      We're in the process of investigating this error but need help from community members.  If you're encountering the "...is not marked for installation" issue and would be willing to generate debug logs for us, please see the instructions below:
                      Perform the following steps on an impacted system
                      1. Download the appropriate "Debugging Tools for Windows" MSI installer which is available from:
                      ** For 32 Bit systems: http://msdl.microsoft.com/download/symbols/debuggers/dbg_x86_6.11.1.404.msi
                      ** For 64 Bit systems: http://msdl.microsoft.com/download/symbols/debuggers/dbg_amd64_6.11.1.404.msi
                      Click on Run
                      Click on Next
                      Click on "I agree" for the EULA
                      Click on Next
                      Select the radio button for "Custom"
                      Click on Browse and change the default install path to C:\DEBUGGERS
                      Click on Next
                      Click on Install
                      Click on Finish
                      2. Download the appropriate TTTSetup MSI installer:
                      ** For 32 Bit systems: https://sendnow.acrobat.com/?i=7gBp4PSAtP9lB8UrdqBr6Q
                      ** For 64 Bit systems: https://sendnow.acrobat.com/?i=9SfayRdL7gGV50TeYOpkTg
                      3. Copy the appropriate TTTSetup MSI installer to c:\debuggers
                      Double click on the MSI installer to execute
                      Click on "Next"
                      Click on "I accept" for the EULA
                      Click on "Next"
                      Ensure the install location reads C:\Debuggers\ttt\
                      Click on "Next"
                      Click on "Install"
                      4. Launch task manager and ensure that there are no running instances of msiexec.exe. If there are, end the running instances. This will help us isolate the msiexec.exe process(es) that are associated with the Flash Player MSI.
                      5. Launch the Flash Player 11 MSI installer but do not click on the Install button just yet.
                      6. Locate the msiexec.exe process(es) that appear in task manager after launching the Flash Player MSI. Take note of the PID(s) for msiexec.exe (you will need it later)
                      - If you do not see a PID column in Task Manager, you can add it from the task manager View pulldown menu (View->Select Columns)
                      7. Create the following folder C:\iDNAtrace
                      8. Open a command prompt and navigate to C:\Debuggers\ttt (cd C:\Debuggers\ttt)
                      - If you have two running instances of msiexec.exe, you will need to perform steps 8 - 10 in two separate command prompts in order to capture all MSI activity (one for each PID).
                      - If you are on Windows 7, you will need to launch the command prompt with the "Run As Administrator" command. To do this, click on Start, type cmd in the search field, right click on cmd.exe.
                      9. Type "TTtracer.exe -Initialize" without the quotation marks and then Press Enter.
                      10. Type "TTtracer.exe –dumpfull –maxfile 1024 –ring –out c:\iDNAtrace –attach PID” without the quotation marks, Press Enter. <Replace "PID" with the process ID for msiexec.exe from step 5 above>
                      11. click on the Flash Player 11 MSI Install button. When the Flash Player 11 MSI displays the error message, click on "Exit App" on the iDNA window on the desktop. This will create the .out and .run trace files in the C:\iDNAtrace folder
                      Please send the .run and .out files to ccampbel@adobe.com for further analysis.
                      • 9. Re: Is there a Flash ActiveX registry cleaner?
                        jmorgan12 Level 1
                        The Fixit seems to work, but isn't a very good option for my organization that has 300+ machines choaking on Flash right now. Since this thread went dark in August has there been any solutions to this problem that can be automated across our network?
                        • 10. Re: Is there a Flash ActiveX registry cleaner?
                          EthanAD Level 1
                          It seems to be unsupported. The best I could do has been to locate all of the relevant Flash reg entries I could find and delete them from the registry. This has so far deleted the multiple bad entries from Add/Remove and allowed the update to install without the InstallAX error coming up. Example, if you only have 5 versions to address since they shipped the bug:
                          Windows Registry Editor Version 5.00
                          [-HKEY_CLASSES_ROOT\Installer\Features\087B87245BC6A734ABA6137C9FAF9B08]
                          [-HKEY_CLASSES_ROOT\Installer\Features\5100A42EF37C75B48BFDE58BD4E26958]
                          [-HKEY_CLASSES_ROOT\Installer\Features\70EB3840D062D4E418E57F730C7AE204]
                          [-HKEY_CLASSES_ROOT\Installer\Features\92D60C7EA61B88D49A715524F2BAE4D9]
                          [-HKEY_CLASSES_ROOT\Installer\Features\BB211F0D2097CA34FA05D411719C51E2]
                          [-HKEY_CLASSES_ROOT\Installer\Products\087B87245BC6A734ABA6137C9FAF9B08]
                          [-HKEY_CLASSES_ROOT\Installer\Products\5100A42EF37C75B48BFDE58BD4E26958]
                          [-HKEY_CLASSES_ROOT\Installer\Products\70EB3840D062D4E418E57F730C7AE204]
                          [-HKEY_CLASSES_ROOT\Installer\Products\92D60C7EA61B88D49A715524F2BAE4D9]
                          [-HKEY_CLASSES_ROOT\Installer\Products\BB211F0D2097CA34FA05D411719C51E2]
                          [-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\087B87245BC6A734ABA6137C9FAF9B08]
                          [-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\5100A42EF37C75B48BFDE58BD4E26958]
                          [-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\70EB3840D062D4E418E57F730C7AE204]
                          [-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\92D60C7EA61B88D49A715524F2BAE4D9]
                          [-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\BB211F0D2097CA34FA05D411719C51E2]
                          It is unclear if this covers everything to 100% genuinely solve the problem. We really need Adobe to maintain ownership of registry and file hygiene for changes they make.
                          I hope that helps at all.
                          • 11. Re: Is there a Flash ActiveX registry cleaner?
                            We're looking into making a script that will clean these but I'm attaching a complete list of product codes in case someone gets to it before we do.
                            • 12. Re: Is there a Flash ActiveX registry cleaner?
                              EightFingers Level 1
                              Here's a quick one based on the above product codes. However, Any v11.4+ product codes need to be added.
                              :: Adobe Flash Player ActiveX and Plugin Uninstall Script
                              REM Adobe Flash Player ActiveX ProductCodes
                              REM Adobe Flash Player v. 7.0
                              MsiExec.exe /uninstall {cdf0cc64-4741-4e43-bf97-fef8fa1d6f1c} /quiet /norestart
                              REM Adobe Flash Player v. 7.0.73.0
                              MsiExec.exe /uninstall {1ae3b442-f6e5-49a0-bf8b-0e8d56d7d450} /quiet /norestart
                              REM Adobe Flash Player v. 8.0.0.442 and earlier
                              MsiExec.exe /uninstall {436EE5F2-71F0-4738-B8E7-93741EF4828F} /quiet /norestart
                              MsiExec.exe /uninstall {0B575FB2-30B1-48F2-80A3-977638C2D6BA} /quiet /norestart
                              REM Adobe Flash Player v. 8.0.0.443 -> 8.0.0.453
                              MsiExec.exe /uninstall {F180E599-CC04-4971-8140-3F71F95D7944} /quiet /norestart
                              MsiExec.exe /uninstall {9600BCE2-9DEF-4930-ABF7-FB68ED538BF7} /quiet /norestart
                              REM Adobe Flash Player v. 8.0.0.454 -> 8.0.9.0
                              MsiExec.exe /uninstall {0A28C610-EE06-4A33-BB56-A2155B524916} /quiet /norestart
                              MsiExec.exe /uninstall {0CB2ABF4-BB8D-4F87-9223-50F106B50D95} /quiet /norestart
                              REM Adobe Flash Player v. 8.0.10.0 -> 8.0.22.0
                              MsiExec.exe /uninstall {6815FCDD-401D-481E-BA88-31B4754C2B46} /quiet /norestart
                              MsiExec.exe /uninstall {885A63EA-382B-4DD4-A755-14809B8557D6} /quiet /norestart
                              REM Adobe Flash Player v. 8.0.24.0
                              MsiExec.exe /uninstall {5E8A1B08-0FBD-4543-9646-F2C2D0D05750} /quiet /norestart
                              MsiExec.exe /uninstall {CD5C7EB6-937A-4E39-B847-A8A50568EE9B} /quiet /norestart
                              REM Adobe Flash Player v. 8.0.33.0
                              MsiExec.exe /uninstall {E8590564-FD80-4864-B219-619BD4B3EB83} /quiet /norestart
                              MsiExec.exe /uninstall {E67FAA8D-58E0-433C-833C-6647CDB14AB0} /quiet /norestart
                              REM Adobe Flash Player v. 8.0.34.0
                              MsiExec.exe /uninstall {F7BE8C66-4DFF-4480-A9B6-410E6FE4D399} /quiet /norestart
                              MsiExec.exe /uninstall {0B991365-EB79-40B3-92AE-5E09B4008553} /quiet /norestart
                              REM Adobe Flash Player v. 8.0.35.0
                              MsiExec.exe /uninstall {B0D584DC-3B46-4F6C-B9C3-BDC61304D3CD} /quiet /norestart
                              MsiExec.exe /uninstall {2927FFE6-25C2-4C86-B93C-EDEEA97B7CB7} /quiet /norestart
                              REM Adobe Flash Player v. 8.0.36.0
                              MsiExec.exe /uninstall {6D7EE95D-ADFB-4454-B28B-FAC56F84F186} /quiet /norestart
                              MsiExec.exe /uninstall {8A90EC49-E132-4AA5-BF74-A18CC3C6DF6D} /quiet /norestart
                              REM Adobe Flash Player v. 8.0.39.0
                              MsiExec.exe /uninstall {00C10AC2-32C3-4281-B8EB-011E00B5AE20} /quiet /norestart
                              MsiExec.exe /uninstall {2BBA59AE-9246-4348-8BB8-54EA1182817B} /quiet /norestart
                              REM Adobe Flash Player v. 8.0.42.0
                              MsiExec.exe /uninstall {A3703922-84E3-4318-B0A1-04EFAD449A04} /quiet /norestart
                              MsiExec.exe /uninstall {8A7DC982-6A96-4C3C-BBE1-D5025CD85AF5} /quiet /norestart
                              REM Adobe Flash Player v. 9.0.16.0
                              MsiExec.exe /uninstall {BB65C393-C76E-4F06-9B0C-2124AA8AF97B} /quiet /norestart
                              MsiExec.exe /uninstall {116E6EEC-0CBA-460E-8DEB-55CFF8E28C7D} /quiet /norestart
                              REM Adobe Flash Player v. 9.0.28.0
                              MsiExec.exe /uninstall {685A56F8-75B6-44AD-B3DA-FB0A3266B47C} /quiet /norestart
                              MsiExec.exe /uninstall {D26FEB21-3495-401F-9046-0A39050A9324} /quiet /norestart
                              REM Adobe Flash Player v. 9.0.45.0
                              MsiExec.exe /uninstall {8186E1B9-DDC6-45B6-B9EB-C28947CBC4CF} /quiet /norestart
                              MsiExec.exe /uninstall {6EB45C70-7B6E-456C-8C23-58A8409C0E3D} /quiet /norestart
                              MsiExec.exe /uninstall {BC4F8E84-5E29-49EC-B4E7-E6F9CB50986C} /quiet /norestart
                              REM Adobe Flash Player v.  9.0.XX.0
                              MsiExec.exe /uninstall {786547F9-59BB-4FA3-B2D8-327FF1F14870} /quiet /norestart
                              MsiExec.exe /uninstall {3420E724-6DDB-49C2-BA39-165F543C147C} /quiet /norestart
                              MsiExec.exe /uninstall {8E9DB7EF-5DD3-499E-BA2A-A1F3153A4DF8} /quiet /norestart
                              MsiExec.exe /uninstall {0A621EC5-B98B-45C9-95FE-A7D0DA3150EA} /quiet /norestart
                              REM Adobe Flash Player v.  9.4.XX.0
                              MsiExec.exe /uninstall {58BAA8D0-404E-4585-9FD3-ED1BB72AC2EE} /quiet /norestart
                              MsiExec.exe /uninstall {483CFBDB-5870-41ED-82DC-992D1A2CBA87} /quiet /norestart
                              REM Adobe Flash Player v.  9.0.151.0
                              MsiExec.exe /uninstall {74B3FB8A-2A0F-4CEA-84FD-12C9B03EE377} /quiet /norestart
                              MsiExec.exe /uninstall {693E05C4-15CF-4EC4-8298-AFCC049F4B94} /quiet /norestart
                              MsiExec.exe /uninstall {6FEFB724-6655-492B-9D10-00F530FC39D3} /quiet /norestart
                              MsiExec.exe /uninstall {41FA4099-8AAA-495C-B1F0-E0447F9F4A93} /quiet /norestart
                              REM Adobe Flash Player v.  9.0.246
                              MsiExec.exe /uninstall {9BA8B441-9E83-4307-A582-03EC9A456C72} /quiet /norestart
                              MsiExec.exe /uninstall {03E99F0B-3A02-4821-BD44-70D4463F897B} /quiet /norestart
                              REM Adobe Flash Player v. 9r260
                              MsiExec.exe /uninstall {BB79ADDE-9369-44C4-84DB-221C853ABEDC} /quiet /norestart
                              MsiExec.exe /uninstall {B4D79216-306A-400B-858B-00C05F0B0E80} /quiet /norestart
                              REM Adobe Flash Player v.  9.0.262
                              MsiExec.exe /uninstall {C64CF7F5-92A0-4615-AA2D-A1237AD3F332} /quiet /norestart
                              MsiExec.exe /uninstall {211986FD-3BB6-4B0D-8AAF-C22A6DBC7E36} /quiet /norestart
                              REM Adobe Flash Player v.  9.0.277
                              MsiExec.exe /uninstall {4FB5B082-6906-4764-9486-332393B33C9F} /quiet /norestart
                              MsiExec.exe /uninstall {7EC95A10-14F2-496A-99FA-772454E44566} /quiet /norestart
                              REM Adobe Flash Player v.  9.0.280
                              MsiExec.exe /uninstall {2CB88388-9DFB-46f7-B7F1-862EB29A6FAB} /quiet /norestart
                              MsiExec.exe /uninstall {17EDE3E8-7AF0-4c54-B6E7-0CA4129E9C21} /quiet /norestart
                              REM Adobe Flash Player v.  10.0.2
                              MsiExec.exe /uninstall {3A6829EF-0791-4FDD-9382-C690DD0821B9} /quiet /norestart
                              REM Adobe Flash Player v.  10.0.12
                              MsiExec.exe /uninstall {2BD2FA21-B51D-4F01-94A7-AC16737B2163} /quiet /norestart
                              MsiExec.exe /uninstall {A19AA51E-C145-4323-947E-D0D71EC84E47} /quiet /norestart
                              REM Adobe Flash Player v.  10.0.22
                              MsiExec.exe /uninstall {922E8525-AC7E-4294-ACAA-43712D4423C0} /quiet /norestart
                              MsiExec.exe /uninstall {CECF7500-69B8-4EEE-9A5F-8D2FC2625760} /quiet /norestart
                              REM Adobe Flash Player v.  10.0.32
                              MsiExec.exe /uninstall {B7B3E9B3-FB14-4927-894B-E9124509AF5A} /quiet /norestart
                              MsiExec.exe /uninstall {AFCD87D7-46F9-4923-84F0-987F12D0C28C} /quiet /norestart
                              REM Adobe Flash Player v. 10.0.42
                              MsiExec.exe /uninstall {24762012-C6C8-4AAD-A02D-71A009FA1683} /quiet /norestart
                              MsiExec.exe /uninstall {D4B2F658-FCCC-4C50-952B-A8A5E5BC110F} /quiet /norestart
                              REM Adobe Flash Player v. 10.0.45
                              MsiExec.exe /uninstall {66E3BA00-6B3D-466B-96FA-6309A7F42BB0} /quiet /norestart
                              MsiExec.exe /uninstall {20B3FD5B-A987-406B-A5B5-CDE3CA1EF4E1} /quiet /norestart
                              REM Adobe Flash Player v.  10.1.52
                              MsiExec.exe /uninstall {6E9EF98E-259E-416D-B5F8-0ABDB99942CE} /quiet /norestart
                              MsiExec.exe /uninstall {EFB786FD-D916-416B-A23A-1EBEAF4A9DDC} /quiet /norestart
                              REM Adobe Flash Player v.  10.1.55
                              MsiExec.exe /uninstall {FFB768E4-E427-4553-BC36-A11F5E62A94D} /quiet /norestart
                              MsiExec.exe /uninstall {95A0B13E-F09A-425F-9D5F-E7C5EC470D06} /quiet /norestart
                              REM Adobe Flash Player v. 10.1.82
                              MsiExec.exe /uninstall {406A89D6-09E6-4550-B370-8D376DDB56BE} /quiet /norestart
                              MsiExec.exe /uninstall {03A3CDEE-94D7-49c1-B373-D342653A22E8} /quiet /norestart
                              REM Adobe Flash Player v. 10.1.85
                              MsiExec.exe /uninstall {95468B00-C081-4B27-AC96-0A2A31359E60} /quiet /norestart
                              MsiExec.exe /uninstall {C6C0E5B3-19B9-45D4-B76A-177F500A276C} /quiet /norestart
                              REM Adobe Flash Player v. 10.1.102
                              MsiExec.exe /uninstall {148D9D03-5D23-4D4F-B5D0-BA6030C45DCF} /quiet /norestart
                              MsiExec.exe /uninstall {65EAFCCB-4057-4184-9145-137DED9E0144} /quiet /norestart
                              REM Adobe Flash Player v. 10.2.152
                              MsiExec.exe /uninstall {E5D03B2E-B2D4-477F-A60D-8E1969D821FA} /quiet /norestart
                              MsiExec.exe /uninstall {87AE8A8F-6040-42B5-A7E5-644B1EA70163} /quiet /norestart
                              MsiExec.exe /uninstall {18BBF24A-6D04-4CA4-B6B4-1CF372162EEC} /quiet /norestart
                              MsiExec.exe /uninstall {37C80158-721A-440E-8102-8C5B71BFE2DE} /quiet /norestart
                              REM Adobe Flash Player v. 10.2.153
                              MsiExec.exe /uninstall {B001064C-D061-4BAE-9031-416A838D5536} /quiet /norestart
                              MsiExec.exe /uninstall {FFE07581-220F-47B7-8EDE-26059EF9FB26} /quiet /norestart
                              REM Adobe Flash Player v. 10.2.159
                              MsiExec.exe /uninstall {FA1D6742-0515-4A94-AD5D-F0484026E4A2} /quiet /norestart
                              MsiExec.exe /uninstall {9A80D7E7-4C48-484E-9C16-F4E300366F1D} /quiet /norestart
                              REM Adobe Flash Player v. 10.3.181.14
                              MsiExec.exe /uninstall {DCC90D9D-4F8D-4A06-9050-ADDB284FF9FA} /quiet /norestart
                              MsiExec.exe /uninstall {23885D98-F1AF-4579-81FB-C57CA71B7E89} /quiet /norestart
                              REM Adobe Flash Player v. 10.3.181.22
                              MsiExec.exe /uninstall {A6FD09C6-E363-4986-8ABD-2165B4485EEC} /quiet /norestart
                              MsiExec.exe /uninstall {397B615E-7442-4BEA-8098-61BBCF703C74} /quiet /norestart
                              REM Adobe Flash Player v. 10.3.181.23
                              MsiExec.exe /uninstall {88D881EF-0567-443A-9A84-E5AAEF29BB34} /quiet /norestart
                              MsiExec.exe /uninstall {04F9616D-BEB9-40DD-88EA-0D404F67C775} /quiet /norestart
                              REM Adobe Flash Player v. 10.3.181.26
                              MsiExec.exe /uninstall {0483BE07-260D-4E4D-815E-F737C0A72E40} /quiet /norestart
                              MsiExec.exe /uninstall {332FDA1D-0B1E-460C-9961-65515CADB9B7} /quiet /norestart
                              REM Adobe Flash Player v. 10.3.181.34
                              MsiExec.exe /uninstall {48DB5914-8772-472D-B8DF-E2092BE598F6} /quiet /norestart
                              MsiExec.exe /uninstall {EA5AFEE8-17F9-4DC6-AB10-A41C34A35893} /quiet /norestart
                              REM Adobe Flash Player v. 10.3.183.5
                              MsiExec.exe /uninstall {72D4DD4C-0749-4352-B63E-7A7C9286430E} /quiet /norestart
                              MsiExec.exe /uninstall {A3F073DB-01A6-4e24-A0F5-950EAB651355} /quiet /norestart
                              REM Adobe Flash Player v. 10.3.183.6+
                              MsiExec.exe /uninstall {DB093E0B-0934-4183-BA60-5C1ADC9F6424} /quiet /norestart
                              MsiExec.exe /uninstall {C0D8060A-8E3B-458c-9434-FBBE04F823D3} /quiet /norestart
                              REM Adobe Flash Player v. 10.3.230
                              MsiExec.exe /uninstall {E24A0015-C73F-4B57-B8DF-5EB84D2E9685} /quiet /norestart
                              MsiExec.exe /uninstall {39BCE53F-F8C8-4545-A5D8-F210E7608360} /quiet /norestart
                              REM Adobe Flash Player v. 10.3.183.11
                              MsiExec.exe /uninstall {54DAAD16-A57A-4524-9C4F-391500945D14} /quiet /norestart
                              MsiExec.exe /uninstall {A437E1A3-F0AA-4EA2-8E43-845DDC2221D1} /quiet /norestart
                              REM Adobe Flash Player v. 10.3.183.15
                              MsiExec.exe /uninstall {36B194F6-D57F-4E58-B99D-9A4565356A66} /quiet /norestart
                              MsiExec.exe /uninstall {E84F69A8-5357-4C1F-B8AA-63919FA0BDA6} /quiet /norestart
                              REM Adobe Flash Player v. 10.3.183.16
                              MsiExec.exe /uninstall {FEE2740C-D52A-4C76-8857-335E35AB7037} /quiet /norestart
                              MsiExec.exe /uninstall {1D424BAA-E25C-456C-B502-0B9C9F164BDE} /quiet /norestart
                              REM Adobe Flash Player v. 10.3.183.18
                              MsiExec.exe /uninstall {212719F5-89EE-4B3A-A8EB-121D931E5547} /quiet /norestart
                              MsiExec.exe /uninstall {AB36B93A-7B6A-4693-99DE-95143819EE78} /quiet /norestart
                              REM Adobe Flash Player v. 10.3.183.19
                              MsiExec.exe /uninstall {2B2D7C9F-F652-4C9C-86AD-7298D2989D88} /quiet /norestart
                              MsiExec.exe /uninstall {DA69776C-A93F-4077-8874-25DF521EAA8A} /quiet /norestart
                              REM Adobe Flash Player v. 10.3.183.20
                              MsiExec.exe /uninstall {5C017C03-0DCF-47DD-8113-9CDE442C30E7} /quiet /norestart
                              MsiExec.exe /uninstall {C9BDE2F9-88BE-429B-B63B-5D40BA2FCE7F} /quiet /norestart
                              REM Adobe Flash Player v. 10.3.183.23
                              MsiExec.exe /uninstall {35685EF6-CB29-4FDE-8950-F570ED2BACB7} /quiet /norestart
                              MsiExec.exe /uninstall {654BA71A-B93E-4085-ABD7-83BA7DCA6C23} /quiet /norestart
                              REM Adobe Flash Player v. 10.3.183.25
                              MsiExec.exe /uninstall {CBCA1B4E-1DB3-4BBF-BD05-CF3A3F2CC32B} /quiet /norestart
                              MsiExec.exe /uninstall {09343F1F-926F-4DFD-8784-079E67D783DB} /quiet /norestart
                              REM Adobe Flash Player v. 10.3.183.x
                              MsiExec.exe /uninstall {1BB7D2BB-D4EB-4680-A707-FC3D526E90A1} /quiet /norestart
                              MsiExec.exe /uninstall {66C8B9D7-25FF-4BF9-A515-096E8D3B73EF} /quiet /norestart
                              REM Adobe Flash Player v. 11.0.1
                              MsiExec.exe /uninstall {23D79730-EC1A-435E-83F8-AAEBFE5237B0} /quiet /norestart
                              MsiExec.exe /uninstall {726D93B8-C973-4C5B-881B-96FBDE459D39} /quiet /norestart
                              MsiExec.exe /uninstall {A10EE46B-C2E8-4FAB-A8F8-3E80D0662BA9} /quiet /norestart
                              MsiExec.exe /uninstall {6C119C52-528E-4115-A05D-E78893FB01F6} /quiet /norestart
                              REM Adobe Flash Player v. 11.1.102
                              MsiExec.exe /uninstall {4278B780-6CB5-437A-BA6A-31C7F9FAB980} /quiet /norestart
                              MsiExec.exe /uninstall {DBC42D80-FE3F-4F45-91EA-972F0EDC8603} /quiet /norestart
                              MsiExec.exe /uninstall {421976B6-DEC6-4CA5-941F-F0663B3A2B74} /quiet /norestart
                              MsiExec.exe /uninstall {C2840D4B-5DD8-4813-A9D8-C2B72E821226} /quiet /norestart
                              REM Adobe Flash Player v. 11.1.102.62
                              MsiExec.exe /uninstall {D0F112BB-7902-43AC-AF50-4D1117C9152E} /quiet /norestart
                              MsiExec.exe /uninstall {B88C181E-D594-4A3C-9767-07E4794234D6} /quiet /norestart
                              MsiExec.exe /uninstall {62DD0E85-7A25-47A4-8F0F-95D749F9F102} /quiet /norestart
                              MsiExec.exe /uninstall {7DBA4E0E-C43E-4BD8-859E-DA4E8284473E} /quiet /norestart
                              REM Adobe Flash Player v. 11.1.102.63
                              MsiExec.exe /uninstall {8D7DDFA2-3A50-49A4-99C5-6D8BE66FE0B9} /quiet /norestart
                              MsiExec.exe /uninstall {3D093B2E-1E39-4097-A0EF-C70351A16CA6} /quiet /norestart
                              MsiExec.exe /uninstall {E7C06D29-B16A-4D88-A917-55422FAB4E9D} /quiet /norestart
                              MsiExec.exe /uninstall {82833D13-CE67-4DD9-A270-30265F12DCB7} /quiet /norestart
                              REM Adobe Flash Player v. 11.1.102.64
                              MsiExec.exe /uninstall {90790D5D-80D8-4C7E-8BDC-23DBB8C6AEC7} /quiet /norestart
                              MsiExec.exe /uninstall {CF722882-1ED7-4FB9-B98A-589544A15F40} /quiet /norestart
                              MsiExec.exe /uninstall {D3F3D07F-4B4F-440B-9DC9-355848A8103C} /quiet /norestart
                              MsiExec.exe /uninstall {14190A51-2712-42C1-B7DB-011ABEAF33E2} /quiet /norestart
                              REM Adobe Flash Player v. 11.2.202.228
                              MsiExec.exe /uninstall {5C804EBB-475F-4555-A225-1D6573F158BD} /quiet /norestart
                              MsiExec.exe /uninstall {E3C99F7A-60C3-40C4-BC9D-FB6B0C2F2671} /quiet /norestart
                              MsiExec.exe /uninstall {8DB09D25-8E79-4F23-854D-02B95062A5B2} /quiet /norestart
                              MsiExec.exe /uninstall {94B87B26-B746-4AEA-B301-4AB281AF3B7A} /quiet /norestart
                              REM Adobe Flash Player v. 11.2.202.233
                              MsiExec.exe /uninstall {9E25236A-E313-4853-9C8C-DB7015E9F9C4} /quiet /norestart
                              MsiExec.exe /uninstall {0EF12658-CB6B-4A73-923D-2CABE04976A6} /quiet /norestart
                              MsiExec.exe /uninstall {6B393C32-A8CE-4663-9D5B-EA75C8D1233C} /quiet /norestart
                              MsiExec.exe /uninstall {853E9330-9717-4504-BDA2-BB8743D458DD} /quiet /norestart
                              REM Adobe Flash Player v. 11.2.202.x
                              MsiExec.exe /uninstall {F40AC5E5-55AB-469A-BA8B-839CE0146380} /quiet /norestart
                              MsiExec.exe /uninstall {43E79717-8760-480E-8408-98D090DA10A7} /quiet /norestart
                              MsiExec.exe /uninstall {A13AB67F-697F-47DC-AA7B-F70B8B7ACDB8} /quiet /norestart
                              MsiExec.exe /uninstall {628185FB-FA33-49C3-B7AC-A31F30EDDB6E} /quiet /norestart
                              REM Adobe Flash Player v. 11.3.300.257
                              MsiExec.exe /uninstall {DC48E09D-4E5F-4039-B93A-FCED36EFBE55} /quiet /norestart
                              MsiExec.exe /uninstall {F856A189-24F9-4443-A40C-58CC70A1B336} /quiet /norestart
                              REM Adobe Flash Player v. 11.3.300.265
                              MsiExec.exe /uninstall {BEE621F9-F94D-493C-BC45-D1B315DC8839} /quiet /norestart
                              MsiExec.exe /uninstall {1F25D9AF-12DF-4A9D-B190-C6ED384520AF} /quiet /norestart
                              REM Adobe Flash Player v. 11.3.300.268
                              MsiExec.exe /uninstall {98616875-CF30-4BE5-AAED-36EF4AC6EE27} /quiet /norestart
                              MsiExec.exe /uninstall {8E55A5FE-A5D2-4791-A725-A8BA275BD3C2} /quiet /norestart
                              REM Adobe Flash Player v. 11.3.300.270
                              MsiExec.exe /uninstall {A02F7026-D635-465C-80D8-FB47AF185934} /quiet /norestart
                              MsiExec.exe /uninstall {0A665F5E-78A3-4BDB-B702-61B56815F91C} /quiet /norestart
                              REM Adobe Flash Player v. 11.3.300.271
                              MsiExec.exe /uninstall {25F2AB39-E3DD-4cd7-8697-E98CF27BA1F1} /quiet /norestart
                              MsiExec.exe /uninstall {98CBB17F-A22C-43e3-8521-99A3F413C882} /quiet /norestart
                              REM Adobe Flash Player v. 11.3.300.272
                              MsiExec.exe /uninstall {CA6C70E3-1878-47c3-97BA-8DB0E2221511} /quiet /norestart
                              MsiExec.exe /uninstall {ABE4FCDC-7D0B-40ea-ACD4-122BABC6E78A} /quiet /norestart
                              REM Adobe Flash Player v. 11.4.402.265
                              MsiExec.exe /uninstall {3F67CDB0-824E-435E-BE14-D7BCA8256E3E} /quiet /norestart
                              MsiExec.exe /uninstall {8A48D60D-7D7F-4C4D-AC92-AC3150BF75FE} /quiet /norestart
                              REM Adobe Flash Player v. 11.4.402.278
                              MsiExec.exe /uninstall {6F702A65-629F-4E5A-B686-1A4826C83AB4} /quiet /norestart
                              MsiExec.exe /uninstall {D488AE94-47DF-443E-8CE7-1A9A919B368A} /quiet /norestart
                              REM Adobe Flash Player v. 11.4.402.287
                              MsiExec.exe /uninstall {D01750A5-49E5-4BF4-92CC-F72F5F20DBEC} /quiet /norestart
                              MsiExec.exe /uninstall {A5FC3413-878E-4A9E-903A-7E32079C70F3} /quiet /norestart
                              REM Flash Player Plug-in ProductCodes
                              REM Adobe Flash Player v.8.0.0.442 and earlier
                              MsiExec.exe /uninstall {F6E23569-A22A-4924-93A4-3F215BEF63D2} /quiet /norestart
                              MsiExec.exe /uninstall {AF6106EF-F27F-4729-922B-FDD56869C9D0} /quiet /norestart
                              REM Adobe Flash Player v.8.0.0.443 -> 8.0.0.453
                              MsiExec.exe /uninstall {B9E91AEF-2A3C-4B48-BF18-456BE6EDF863} /quiet /norestart
                              MsiExec.exe /uninstall {5F2B85E0-66F2-4E61-BA50-12784EFAE696} /quiet /norestart
                              REM Adobe Flash Player v.8.0.0.454 -> 8.0.9.0
                              MsiExec.exe /uninstall {555D21DF-105A-48A7-AFFE-F5B4495F7F1D} /quiet /norestart
                              MsiExec.exe /uninstall {27DCBDC9-00D0-4A57-BDFD-E618820495CB} /quiet /norestart
                              REM Adobe Flash Player v.8.0.10.0 -> 8.0.22.0
                              MsiExec.exe /uninstall {23AEBB83-CB47-4739-8A0C-92CC1E32AA2F} /quiet /norestart
                              MsiExec.exe /uninstall {91057632-CA70-413C-B628-2D3CDBBB906B} /quiet /norestart
                              REM Adobe Flash Player v.8.0.24.0
                              MsiExec.exe /uninstall {E3D278BD-FC97-4F87-BB1F-689AE0CB9122} /quiet /norestart
                              MsiExec.exe /uninstall {13816489-2692-49A2-9615-0F2830E1740D} /quiet /norestart
                              REM Adobe Flash Player v.8.0.33.0
                              MsiExec.exe /uninstall {465B0B1A-06E1-4C99-BB0A-ED23262DF156} /quiet /norestart
                              MsiExec.exe /uninstall {C0C08739-EA05-443C-BE3F-2B4E46D6A74E} /quiet /norestart
                              REM Adobe Flash Player v.8.0.34.0
                              MsiExec.exe /uninstall {7DCC858F-082F-4E01-9DD4-CF3645640F41} /quiet /norestart
                              MsiExec.exe /uninstall {8672D374-FC95-45E0-B85C-BEB639C14F1F} /quiet /norestart
                              REM Adobe Flash Player v.8.0.35.0
                              MsiExec.exe /uninstall {EFEC4901-E9F0-4FB0-87F2-90E3058DA015} /quiet /norestart
                              MsiExec.exe /uninstall {0402AE0D-C6B5-4CBD-9A84-A0C32785D407} /quiet /norestart
                              REM Adobe Flash Player v.8.0.36.0
                              MsiExec.exe /uninstall {D60837D1-6881-4414-AD27-8A2042D043B3} /quiet /norestart
                              MsiExec.exe /uninstall {C1CC20FA-52A7-4F67-BCCC-5E55E9A61C6A} /quiet /norestart
                              REM Adobe Flash Player v.8.0.39.0
                              MsiExec.exe /uninstall {63C0B69C-6630-44F2-B3A4-1F50DDEF6ADD} /quiet /norestart
                              MsiExec.exe /uninstall {E1475528-CAC4-4919-81FD-EDC556097048} /quiet /norestart
                              REM Adobe Flash Player v.8.0.42.0
                              MsiExec.exe /uninstall {48D9A460-9FA3-4E16-9533-2DF1C1F5129F} /quiet /norestart
                              MsiExec.exe /uninstall {E686D1C1-78B5-4E1A-8269-A023B43C2D76} /quiet /norestart
                              REM Adobe Flash Player v.9.0.16.0
                              MsiExec.exe /uninstall {1E37DD02-3E30-49B6-9FF2-F4A3DFF95717} /quiet /norestart
                              MsiExec.exe /uninstall {626CA84A-FFAE-4978-A600-B0196F0F817D} /quiet /norestart
                              REM Adobe Flash Player v.9.0.28.0
                              MsiExec.exe /uninstall {0234731F-1444-4215-BBCE-968CDDB4BCA4} /quiet /norestart
                              MsiExec.exe /uninstall {008F31A9-4B8E-4411-AA19-2CB3C8DD7507} /quiet /norestart
                              MsiExec.exe /uninstall {391474F7-0DF1-445C-8888-34EEA7480927} /quiet /norestart
                              REM Adobe Flash Player v.9.0.45.0
                              MsiExec.exe /uninstall {B91D3B4D-001F-4ABF-B8A5-B5A926DB63AD} /quiet /norestart
                              MsiExec.exe /uninstall {56E0400B-3C4E-4600-A4D7-425EAE09E079} /quiet /norestart
                              MsiExec.exe /uninstall {88D422DB-E9C7-4E16-9D80-2999F4FD6AD9} /quiet /norestart
                              MsiExec.exe /uninstall {04B848BE-8B67-4B44-929D-BC14D9B4FFF4} /quiet /norestart
                              MsiExec.exe /uninstall {3EA70573-43D9-4F0F-B197-6015B404EFB5} /quiet /norestart
                              MsiExec.exe /uninstall {9802AB7D-9BB2-4FC9-A9B6-681696F1E2DA} /quiet /norestart
                              MsiExec.exe /uninstall {5746C6E3-DC6E-4762-9445-F89C50B5E1D2} /quiet /norestart
                              MsiExec.exe /uninstall {61E8B062-51F9-4BBB-B1FC-E2A4A40944F5} /quiet /norestart
                              MsiExec.exe /uninstall {ECF27176-4815-4F75-98DC-3E5568166C97} /quiet /norestart
                              MsiExec.exe /uninstall {84490045-A165-4E48-9513-F9624D2CEBEE} /quiet /norestart
                              MsiExec.exe /uninstall {A03AF447-5F61-43EC-880A-A65ED11C9720} /quiet /norestart
                              MsiExec.exe /uninstall {15769488-ECC7-482D-B222-96281A8C36C7} /quiet /norestart
                              MsiExec.exe /uninstall {3F38C13F-97A6-44B5-AB0F-5013801454B7} /quiet /norestart
                              REM Adobe Flash Player v. 9.0.246.0
                              MsiExec.exe /uninstall {EAC34337-5F49-41FF-86C6-A370DAB69CB2} /quiet /norestart
                              MsiExec.exe /uninstall {AF214EE7-1AF3-498F-918C-581F97B1EE79} /quiet /norestart
                              MsiExec.exe /uninstall {F201F161-D43B-471A-A9E5-C432E1BA196B} /quiet /norestart
                              MsiExec.exe /uninstall {E374CFF5-A81F-4C23-A278-8E19C913C23C} /quiet /norestart
                              REM Adobe Flash Player v. 9r262
                              MsiExec.exe /uninstall {35657C68-91B5-42EC-99E6-0BA43106AF8B} /quiet /norestart
                              MsiExec.exe /uninstall {9D2AA1D9-65D0-49E9-85A3-B73C9224F1F0} /quiet /norestart
                              MsiExec.exe /uninstall {E09CDDD4-060D-4BF4-AB36-C13AD9AD63A3} /quiet /norestart
                              MsiExec.exe /uninstall {AAA3B45B-8FD5-4DD1-86C6-C861EF0BA31C} /quiet /norestart
                              MsiExec.exe /uninstall {22A5BE4F-4A7C-4037-8E30-EAF0E6CB546C} /quiet /norestart
                              MsiExec.exe /uninstall {15F93695-7814-43b7-B078-35855A39B63C} /quiet /norestart
                              REM Adobe Flash Player v. 10.0.1.218
                              MsiExec.exe /uninstall {3F490EB6-7C6C-4208-93FF-6AC925FA64C8} /quiet /norestart
                              MsiExec.exe /uninstall {03DEEAD2-F3B7-45BF-9006-A25D015F00D2} /quiet /norestart
                              MsiExec.exe /uninstall {ECA1A3B6-898F-4DCE-9F04-714CF3BA126B} /quiet /norestart
                              MsiExec.exe /uninstall {5D8E406B-D572-4773-BE82-7B4B33F5167F} /quiet /norestart
                              MsiExec.exe /uninstall {64001313-1B41-4457-B884-049984772E6F} /quiet /norestart
                              MsiExec.exe /uninstall {4B475346-CE49-402C-991E-3DAF7074E337} /quiet /norestart
                              MsiExec.exe /uninstall {0DFB3DE8-65B9-44FF-AA0A-3BECC5A2BFD1} /quiet /norestart
                              MsiExec.exe /uninstall {D6627D6D-E144-49AF-8783-BBEA98B9DC20} /quiet /norestart
                              MsiExec.exe /uninstall {D09E3C22-6573-4723-9962-B3B2ED761754} /quiet /norestart
                              MsiExec.exe /uninstall {B67CE1B7-EDD4-4C70-AB8E-6008D029DD03} /quiet /norestart
                              MsiExec.exe /uninstall {AF36CE1D-FD2C-4BA0-93FA-1196785DD610} /quiet /norestart
                              MsiExec.exe /uninstall {903BE60B-0336-40A0-9024-6D980D1452C2} /quiet /norestart
                              MsiExec.exe /uninstall {BC41C09D-FAA9-4346-9FE6-1E0017BC551A} /quiet /norestart
                              MsiExec.exe /uninstall {359FC4B0-29ED-4CA8-AD66-CF436931F492} /quiet /norestart
                              MsiExec.exe /uninstall {1C5EC8F6-5C5F-421F-85BE-919B5D0CAD4C} /quiet /norestart
                              MsiExec.exe /uninstall {14CAE90A-7395-4DF6-93AD-14AF6E52922B} /quiet /norestart
                              MsiExec.exe /uninstall {012CE096-06BA-4f46-8E89-0B4F900E7479} /quiet /norestart
                              MsiExec.exe /uninstall {A7FCCC54-F5FB-4610-A47D-BB0B236EC0A0} /quiet /norestart
                              MsiExec.exe /uninstall {343DB62F-891F-45EC-BED3-E2F56CEB1B7C} /quiet /norestart
                              MsiExec.exe /uninstall {4ABE9922-AE51-4B1B-9058-9CD3B61CA28B} /quiet /norestart
                              MsiExec.exe /uninstall {35F7D0BF-08AB-42E3-A403-AF9772AC216A} /quiet /norestart
                              MsiExec.exe /uninstall {D70FE37C-CDB9-4C87-A60C-9619536A1817} /quiet /norestart
                              MsiExec.exe /uninstall {E6725026-A650-449C-897B-D6B7A5EEA058} /quiet /norestart
                              MsiExec.exe /uninstall {EF131455-5740-4A8D-8B58-30895FEA1C41} /quiet /norestart
                              MsiExec.exe /uninstall {FC619975-A025-4B54-873C-FDF000B90261} /quiet /norestart
                              MsiExec.exe /uninstall {FAFBF4A2-0CE2-4A80-908D-9C1B007CA821} /quiet /norestart
                              MsiExec.exe /uninstall {9C542173-96F0-435D-A95C-468CAAC75EA0} /quiet /norestart
                              MsiExec.exe /uninstall {ABD26AA9-1114-4470-8971-E4AF80177DF1} /quiet /norestart
                              MsiExec.exe /uninstall {F473C85C-1FED-4D0A-8155-E97AC7E43C9D} /quiet /norestart
                              MsiExec.exe /uninstall {58083D97-7080-4018-8205-755D57BDCCEE} /quiet /norestart
                              MsiExec.exe /uninstall {B7BDAF22-9647-4846-8EA9-6E0A5B785651} /quiet /norestart
                              MsiExec.exe /uninstall {EE13B869-5ED6-4304-BDAB-97FCD19196BD} /quiet /norestart
                              MsiExec.exe /uninstall {4ED0DB47-769D-4B71-8724-E7A5BFEA1D51} /quiet /norestart
                              MsiExec.exe /uninstall {2B30EEBE-80A5-4EC2-80BF-73B68D497A4A} /quiet /norestart
                              MsiExec.exe /uninstall {53F29A32-7D03-4635-A8B3-839D921F6F96} /quiet /norestart
                              MsiExec.exe /uninstall {E6BF9E13-E356-456B-9FA7-51DB3E0FB4FF} /quiet /norestart
                              MsiExec.exe /uninstall {F9D68131-7490-4448-AC45-7BBFB3392F8F} /quiet /norestart
                              MsiExec.exe /uninstall {1397D1B4-6341-4D7F-AE9A-4AD5D8569865} /quiet /norestart
                              MsiExec.exe /uninstall {8B234375-EFB1-4024-8B53-EA7C745A6687} /quiet /norestart
                              MsiExec.exe /uninstall {C0494ABC-1F71-4a95-A31F-C9DE5510253B} /quiet /norestart
                              MsiExec.exe /uninstall {8FC6B896-6F86-4957-AC1A-077A755C4F08} /quiet /norestart
                              MsiExec.exe /uninstall {D6CF54D5-35D1-4c14-BF01-682012C4A303} /quiet /norestart
                              MsiExec.exe /uninstall {10C35266-87DE-471F-B3C9-9AD0CA0315DE} /quiet /norestart
                              MsiExec.exe /uninstall {F9295F4F-A64E-4560-8934-B0B214A79C1B} /quiet /norestart
                              MsiExec.exe /uninstall {F9D28ACF-D568-4D4C-9601-2ECEE27479A3} /quiet /norestart
                              MsiExec.exe /uninstall {9777D3B0-B104-4337-937F-BD670CA08D3B} /quiet /norestart
                              MsiExec.exe /uninstall {FDBF4291-7DDB-4C5C-B128-332A46CF8FFA} /quiet /norestart
                              MsiExec.exe /uninstall {27B80FE1-E9ED-49D9-8EF4-C58635203EBE} /quiet /norestart
                              MsiExec.exe /uninstall {1B771BDD-6B21-4C61-A458-226910A9C01B} /quiet /norestart
                              MsiExec.exe /uninstall {34C45997-475F-4D02-9F2C-9FFE3880337D} /quiet /norestart
                              MsiExec.exe /uninstall {55D873F4-67F0-4BA8-B735-06A5B99AFFE1} /quiet /norestart
                              MsiExec.exe /uninstall {91522620-E5A9-4B76-856F-5159D18E2737} /quiet /norestart
                              MsiExec.exe /uninstall {1F282E23-66C7-46D3-B23C-70A53342DD4E} /quiet /norestart
                              MsiExec.exe /uninstall {ADF9B3BD-14A4-4A34-8382-9FD5757E950F} /quiet /norestart
                              MsiExec.exe /uninstall {99BEFA2A-9084-437E-BE21-40F850C1CF47} /quiet /norestart
                              MsiExec.exe /uninstall {4C66C92E-56EA-4769-ABD0-FA838A594D53} /quiet /norestart
                              MsiExec.exe /uninstall {F78DFF86-B53D-4D6D-AB2B-573C0A7AA856} /quiet /norestart
                              MsiExec.exe /uninstall {59CCE106-1DF5-4021-9700-FDFA2878ED41} /quiet /norestart
                              MsiExec.exe /uninstall {AB47EA27-9FE1-4775-BEFC-4AAEEE2CB53E} /quiet /norestart
                              MsiExec.exe /uninstall {781B0936-390B-4E1B-BC04-6B17D64E6451} /quiet /norestart
                              MsiExec.exe /uninstall {95758145-3B5B-4874-B062-597C8E450EA7} /quiet /norestart
                              MsiExec.exe /uninstall {73C4CC71-510B-44AD-AAA3-3C373963AED4} /quiet /norestart
                              MsiExec.exe /uninstall {66EE3C89-25FD-4D8F-BC01-B94B25B9D03F} /quiet /norestart
                              MsiExec.exe /uninstall {C4E5725D-2758-4FA3-A595-159BBCC5D42C} /quiet /norestart
                              MsiExec.exe /uninstall {CA6DA0CF-2852-4407-ADE2-CA6281C8CE9D} /quiet /norestart
                              MsiExec.exe /uninstall {C77FD7CE-3E63-4DA2-9EE6-D28F47846DCE} /quiet /norestart
                              MsiExec.exe /uninstall {4ABA8D5B-55F4-4254-905B-ACF8AAFF84EE} /quiet /norestart
                              MsiExec.exe /uninstall {605DFBA7-A719-4F7E-A035-84B2CAA7DD4E} /quiet /norestart
                              MsiExec.exe /uninstall {063C0043-E954-4850-9AA7-F9BC4E920D38} /quiet /norestart
                              MsiExec.exe /uninstall {99798FE8-28DA-421D-9A45-6CFB0C459E5C} /quiet /norestart
                              MsiExec.exe /uninstall {35E1B1BF-D8E5-4B7F-9FD6-87D2E5694015} /quiet /norestart
                              MsiExec.exe /uninstall {E7051553-A13A-437A-9133-11F8E88F21A8} /quiet /norestart
                              MsiExec.exe /uninstall {9243F09B-3319-4A55-8181-9BCEC7391079} /quiet /norestart
                              MsiExec.exe /uninstall {E3DB71DB-C4C8-479A-A8C9-C73EF2499B24} /quiet /norestart
                              MsiExec.exe /uninstall {F7090575-8BDC-4A14-8D00-C0FB2BC914BD} /quiet /norestart
                              MsiExec.exe /uninstall {2239879A-3B8C-4CB8-A98E-5881193A7128} /quiet /norestart
                              MsiExec.exe /uninstall {0F2C43BC-2B06-4684-BC2E-C922056DE90C} /quiet /norestart
                              MsiExec.exe /uninstall {2187F9AC-D040-4B1C-B636-40A5A8E63C54} /quiet /norestart
                              MsiExec.exe /uninstall {E3FB4C86-2BF1-4327-B7D4-60F9A2F0A32F} /quiet /norestart
                              MsiExec.exe /uninstall {9EBB117C-1326-400E-95A1-EF538815334B} /quiet /norestart
                              MsiExec.exe /uninstall {1E75E46A-D67F-44BC-9344-8EAA358E9FB7} /quiet /norestart
                              MsiExec.exe /uninstall {94B0D4F0-F2AC-4FE2-B384-C81507AAAE7C} /quiet /norestart
                              MsiExec.exe /uninstall {F1F9D254-FBB7-4634-9481-BEF1312255FE} /quiet /norestart
                              MsiExec.exe /uninstall {B87883B7-F397-400F-B700-6934464D2316} /quiet /norestart
                              MsiExec.exe /uninstall {12F0097F-68B4-40AB-A968-318D369027EC} /quiet /norestart
                              MsiExec.exe /uninstall {9D2F6D68-14FA-44BF-9137-3AE0EE11E609} /quiet /norestart
                              MsiExec.exe /uninstall {1E4B6678-A507-4B6A-B6C7-FEE55FC0C14C} /quiet /norestart
                              MsiExec.exe /uninstall {9C61F315-7DDF-4481-884C-3AEE83738806} /quiet /norestart
                              MsiExec.exe /uninstall {B2883418-71EB-4F63-97AB-222C67E99358} /quiet /norestart
                              MsiExec.exe /uninstall {EA5FD27F-D7A5-421A-8424-7DC27F62F7C9} /quiet /norestart
                              MsiExec.exe /uninstall {5D8B877C-945B-49F5-AA48-776C81C11B56} /quiet /norestart
                              MsiExec.exe /uninstall {6B9F3B5E-D16C-49A6-9DD4-ACFD69A561BC} /quiet /norestart
                              MsiExec.exe /uninstall {E648FE50-7E0B-45E2-92ED-AB1FD4493293} /quiet /norestart
                              MsiExec.exe /uninstall {7AD8EB38-C7C0-453A-BEC6-D7149EA62EC3} /quiet /norestart
                              MsiExec.exe /uninstall {3D3085B0-BC4D-4559-B0AE-F5C879DEFFC4} /quiet /norestart
                              MsiExec.exe /uninstall {CF753404-1C40-437F-859E-7EA8BEDABC64} /quiet /norestart
                              REM Adobe Flash Player v. 11.3.300.262
                              MsiExec.exe /uninstall {309970D0-D0E2-49AB-B9A2-80F48E22947A} /quiet /norestart
                              MsiExec.exe /uninstall {D13D4F0A-6D90-415B-88A9-3E31EE3A5410} /quiet /norestart
                              MsiExec.exe /uninstall {417EF49A-B315-449F-9652-85C8CB988042} /quiet /norestart
                              MsiExec.exe /uninstall {2BEF1A84-6975-4339-9E06-A70A6EE0CFE8} /quiet /norestart
                              MsiExec.exe /uninstall {9BFB1FAB-8FC4-4FAA-9B2D-2B121834B659} /quiet /norestart
                              MsiExec.exe /uninstall {DEA37712-5F54-4EF8-AD50-35D1181F79BF} /quiet /norestart
                              MsiExec.exe /uninstall {4C85A58E-48BA-4252-90C5-C9CA5E0C83D7} /quiet /norestart
                              MsiExec.exe /uninstall {244137C6-0414-48C9-BEFC-EAABDDB910AA} /quiet /norestart
                              MsiExec.exe /uninstall {05AADFE6-43D6-4c7c-9433-5F6EF02BF44F} /quiet /norestart
                              MsiExec.exe /uninstall {A26798D5-245C-4071-9681-9CE85731A115} /quiet /norestart
                              MsiExec.exe /uninstall {395CFBE7-19F1-4494-8ECF-6392D459CE0A} /quiet /norestart
                              MsiExec.exe /uninstall {84D0FEC8-D375-448e-9CA6-7A00BD1C4519} /quiet /norestart
                              REM Adobe Flash Player v. 11.4.402.256
                              MsiExec.exe /uninstall {97E0DCFB-4CBE-4DA6-955E-B8E4DE37E466} /quiet /norestart
                              MsiExec.exe /uninstall {9B560327-156A-46D3-9055-35B3DC5E656F} /quiet /norestart
                              MsiExec.exe /uninstall {8C27E4F1-9CE6-4C32-ADBB-D51CD226649E} /quiet /norestart
                              MsiExec.exe /uninstall {84B1F33D-5AA3-4669-89BC-CACE194EE877} /quiet /norestart
                              MsiExec.exe /uninstall {709D081A-4E86-43F5-9D67-6EAF47EE585E} /quiet /norestart
                              MsiExec.exe /uninstall {5E076E3C-9C1C-49C7-B53C-6ECE986F073A} /quiet /norestart
                              • 13. Re: Is there a Flash ActiveX registry cleaner?
                                RussR123 Level 1
                                going to bring this back from the dead...
                                we have 1000+ PC's "win7 64" in the company, when we deploy the new flash in sccm 2012, we are getting from a 30 to 50% fail rate on installs
                                whats going on is it "thinks" or sometimes has MULTIPLE versions of older flash installed that WONT uninstall, because its looking for a MSI patch that no longer exists.
                                for us, its versions 16, 17, and now 18
                                i have built a Flash NUKE BAT file that 1st runs the uninstall_flash_player.exe, then
                                taskkill /f /im firefox.exe /t
                                taskkill /f /im palemoon.exe /t
                                taskkill /f /im iexplore.exe /t
                                taskkill /f /im iexplorer.exe /t
                                taskkill /f /im skype.exe /t
                                taskkill /f /im msiexec.exe /t
                                then
                                net stop AdobeARMservice
                                sc delete AdobeARMservice
                                net stop armsvc
                                sc delete armsvc
                                net stop AdobeFlashPlayerUpdateSvc
                                sc delete AdobeFlashPlayerUpdateSvc
                                then
                                RMDIR /S /Q "%appdata%\Adobe\Flash Player"
                                RMDIR /S /Q "%appdata%\Macromedia\Flash Player"
                                del /F /Q "%SystemDrive%\Windows\tasks\Adobe Flash Player Updater.job"
                                then
                                wmic product where "name like 'Adobe Flash Player%%'" call uninstall /nointeractive
                                and even after all of that, there is still registry info left that it thinks it has a old version installed that it cant..
                                the last keys i found in here
                                when i do i search in REG for "Adobe Flash Player" ill find the stray keys and if i deleted them, the installer will work fine.
                                the last key it found was this..
                                [HKEY_CLASSES_ROOT\Installer\Products\4769600BC08DBC8458D288DA63AE0B5A]
                                "Clients"=hex(7):3a,00,00,00,00,00
                                "ProductName"="Adobe Flash Player 18 NPAPI"
                                "PackageCode"="6A58C9D43DBAC79468217A9F04BFE636"
                                "Language"=dword:00000409
                                "Version"=dword:12000000
                                "Assignment"=dword:00000001
                                "AdvertiseFlags"=dword:00000180
                                "ProductIcon"="C:\\Windows\\Installer\\{B0069674-D80C-48CB-852D-88AD36EAB0A5}\\ARPPRODUCTI CON.exe"
                                "InstanceType"=dword:00000000
                                "AuthorizedLUAApp"=dword:00000000
                                "DeploymentFlags"=dword:00000001
                                [HKEY_CLASSES_ROOT\Installer\Products\4769600BC08DBC8458D288DA63AE0B5A\SourceList]
                                "PackageName"="install_flash_player_18_plugin.msi"
                                "LastUsedSource"="n;1;C:\\Windows\\ccmcache\\2\\"
                                [HKEY_CLASSES_ROOT\Installer\Products\4769600BC08DBC8458D288DA63AE0B5A\SourceList\Media]
                                "DiskPrompt"="[1]"
                                "1"="DISK1;1"
                                [HKEY_CLASSES_ROOT\Installer\Products\4769600BC08DBC8458D288DA63AE0B5A\SourceList\Net]
                                "1"=hex(2):43,00,3a,00,5c,00,57,00,69,00,6e,00,64,00,6f,00,77,00,73,00,5c,00,\
                                  63,00,63,00,6d,00,63,00,61,00,63,00,68,00,65,00,5c,00,32,00,5c,00,00,00
                                i need a way to scan the reg for the old, or any flash product codes, NOT the msi GUID's to remove the keys..
                                • 14. Re: Is there a Flash ActiveX registry cleaner?
                                  Carm01 Level 4
                                  So are you saying that you need a way to remove anything with ' adobe flash ' in the following locations except for v18?:
                                  IF so I would need a exported registry file from that location to use for testing, you can change the .reg to .txt and I can work with that.
                                  I would also need to know if once found you want the entire key to be deleted? For example:
                                  Last but not least can you work with an exe? As I would need to compile it.
                                  I will make no promises, but i believe I can pull it off, it seems relatively simple if you want the entire key for that old product deleted.
                                  I wrote something similar so I already have the foundation down and would require some tweaking.
                                  • 15. Re: Is there a Flash ActiveX registry cleaner?
                                    piyush2508 Adobe Employee
                                    Hi RussR123,
                                    Can you try using http://download.macromedia.com/get/flashplayer/current/support/uninstall_flash_player.exe (offline uninstaller) and uninstall using this uninstaller. This uninstaller will uninstall all instances of Flash Player on your system and make your machine a clean machine for any Flash installer.
                                    <PATH_TO_UNINSTALLER> -uninstall
                                    this command will silently uninstall all instances of Flash Player on your system, make sure you are running this command will admin rights. Let me know if this helps.
                                    Piyush
                                    • 17. Re: Is there a Flash ActiveX registry cleaner?
                                      maria__ Adobe Employee
                                      Hi RussR123,
                                      As indicated in reply to your post in a separate thread, I'm reviewing this with the installer engineer.
                                      Maria
                                      • 18. Re: Is there a Flash ActiveX registry cleaner?
                                        RussR123 Level 1
                                        if you read my post, that is the 1st thing i do in my bat file...
                                        • 19. Re: Is there a Flash ActiveX registry cleaner?
                                          RussR123 Level 1
                                          tried.. dont work, also, i need this to run on over 1000 pc's... cant do that with CC
                                          • 20. Re: Is there a Flash ActiveX registry cleaner?
                                            RussR123 Level 1
                                            yes, need the whole key removed...
                                            according to the above post, the location for the keys is..
                                            an exe would work, but a PS1, WMIC or bat file would be better..
                                            the easiest way i can think of is search for this part of the key in those 3 locations
                                            then have it remove the main key...
                                            like this..
                                            batch file - Search and Delete registry keys based on ProductName value - Stack Overflow
                                            or if we had a list of all the product codes, that would work as well
                                            • 21. Re: Is there a Flash ActiveX registry cleaner?
                                              Carm01 Level 4
                                              Well, I got something made that just does the HKEY_CLASSES_ROOT\Installer\Products\ currently, I do it basically by exporting that entire reg location and then read that file to memory then check line by line for ' adobe flash ' Once it finds it it checks to see if it is v18, if so, it keeps reading, if not it deletes the entire key, whatever that random number is. It is easier to do it that way then have it read from a list of hundreds of keys and compare them. I use AutoIT for my programming language, I find its easier to digest.
                                              I can upload what i currently have which is only the first key , but should not take long to do the others as it is just copy/paste, make the necessary changes. its fairly fast as well when i strip the cpu throttling. You would need to PM me as i don't want to post a link up here. I don't have any keys other that 18 on my machines here.
                                              Hopefully Maria can get the engineers to incorporate some additional cleaning into the uninstaller would be nice as well
                                              Just let me know
                                              p.s - the keys are the same across the board for all those locations, this will be gravy with 3 lines extra.
                                              • 22. Re: Is there a Flash ActiveX registry cleaner?
                                                RussR123 Level 1
                                                that should work, buy remember, i need to depoly this to run on remote pc's...
                                                i was trying this.. but..
                                                SET KEY=HKCU\Installer\Products
                                                SET VALUE="Adobe Flash Player"
                                                for /F "tokens=1,*" %%a in ('REG QUERY "%KEY%" ^| findstr /I /C:"%VALUE%"') do (echo REG DELETE "%KEY%" /v %%a)
                                                but i get this output.. %%a was unexpected at this time.
                                                • 23. Re: Is there a Flash ActiveX registry cleaner?
                                                  Carm01 Level 4
                                                  Give me a sec,
                                                  I am using HKEY_CLASSES_ROOT\Installer\Products\ to get the initial keys and then deleting them across the other two locations, so if there are other key that are in the other locations, and not in the reference location it will not pull them. I will have to add additional subroutines if you want me to check the other locations independently?
                                                  Do you want me to allow you to keep v18 stuff or remove it all?
                                                  • 24. Re: Is there a Flash ActiveX registry cleaner?
                                                    RussR123 Level 1
                                                    remove all, i have seen some broke 18 installs as well..
                                                    • 25. Re: Is there a Flash ActiveX registry cleaner?
                                                      Carm01 Level 4
                                                      Check your mail please.
                                                      sha1:
                                                      1e3f7b6f0769d8c1ad1b3fae9281d1ca39e88d92
                                                      • 26. Re: Is there a Flash ActiveX registry cleaner?
                                                        Carm01 Level 4
                                                        after looking further looks like:
                                                        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Features
                                                        has them in there as well. I made the necessary adjustments and ran it on my machine. The adobe flash keys were successfully removed, nothing else. for all four registry location areas
                                                        I will send you a new link with a 3 at the end of file name
                                                        sha-1
                                                        E5E9DE7CE13056E5DA805BA9C560F90A8FD24FFB
                                                        • 27. Re: Is there a Flash ActiveX registry cleaner?
                                                          RussR123 Level 1
                                                          this is a failed MSI install log
                                                          this is AFTER running the flash uninstaller AND wmic product where "name like 'Adobe Flash Player%%ActiveX'" uninstall /nointeractive
                                                          log file ===>>  http://textuploader.com/ashep
                                                          • 28. Re: Is there a Flash ActiveX registry cleaner?
                                                            Hi RussR123,
                                                            Can you post the corresponding FlashInstall.log file for this same installation attempt?
                                                            The FlashInstall.log file is saved at the following location:
                                                            • 32-bit: C:\Windows\System32\Macromed\Flash
                                                            • 64-bit: C:\Windows\System32\Macromed\Flash AND C:\Windows\SysWOW64\Macromed\Flash
                                                            Thank you.
                                                            Maria
                                                            • 30. Re: Is there a Flash ActiveX registry cleaner?
                                                              RussR123 Level 1
                                                              another.. PC
                                                              RemoveExistingProducts.
                                                              CustomAction  returned actual error code 1612 (note this may not be 100% accurate if translation happened inside sandbox)
                                                              MSI (s) (D0:50) [15:29:32:968]: Product: Adobe Flash Player 18 NPAPI -- Error 1714.The older version of Adobe Flash Player 18 NPAPI cannot be removed.  Contact your technical support group.  System Error 1612.
                                                              MSI (s) (D0:50) [15:29:33:015]: Product: Adobe Flash Player 18 NPAPI -- Error 1714.The older version of Adobe Flash Player 18 NPAPI cannot be removed.  Contact your technical support group.  System Error 1612.
                                                              MSI LOG===> http://textuploader.com/asxxr
                                                              FLASH LOG===>64 http://textuploader.com/asxxz
                                                              32 http://textuploader.com/asxgt
                                                              • 31. Re: Is there a Flash ActiveX registry cleaner?
        RussR123 Level 1
        found some more spots after logging a flash install
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Features\
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\UpgradeCodes
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\C omponents\
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\
        HKEY_USERS\S-1-5-21-2138466744-1268662106-1780572237-10545\Software\Macromedia\FlashPlayer
        HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia\FlashPlayerPluginReleaseType
        • 32. Re: Is there a Flash ActiveX registry cleaner?
        Carm01 Level 4
        maria__
        I am going to bring Maria into this as well, since I don't have any old versions on my machines, does the current uninstaller address these registry keys? Last time I tested the most current uninstaller it removed the keys; but that was the current version of FP
        RussR123
        You stated a few days ago that you were successful with a test machine for the script I provided; I guess some machines have addition reg entries that are preventing the install?
        I can add the registry deletes in there, that will take a bit more time to modify the script esp for HKEY_USERS then and random SID under there, and remove anything adobe flash for those keys assuming I have them as well. I just need to know IF in your testing by removing those solves the problem?
        • 33. Re: Is there a Flash ActiveX registry cleaner?
        RussR123 Level 1
        yes, i have a few PC that flash is just "stuck" on... example..
        this PC thinks it has 5 versions of NPAPI installed, and wont install the new .209
        if i call the uninstaller, it says it uninstalls "ReturnValue = 0"
        but if i re-call it again, it still see's all 5 still on there...
        C:\Users\xx>psexec \\xx -s wmic product where "name like 'Adobe Flash Player%%NPAPI'" uninstall /nointeract
        ive
        PsExec v1.94 - Execute processes remotely
        Copyright (C) 2001-2008 Mark Russinovich
        Sysinternals - www.sysinternals.com
        Executing (\\xx\ROOT\CIMV2:Win32_Product.IdentifyingNumber="{76CF5170-31B4-490F-89CE-5820EF416822}" ,Name="Adob
        e Flash Player 18 NPAPI",Version="18.0.0.203")->Uninstall()
        Method execution successful.
        Out Parameters:
        instance of __PARAMETERS
        ReturnValue = 0;
        Executing (\\xx\ROOT\CIMV2:Win32_Product.IdentifyingNumber="{B0069674-D80C-48CB-852D-88AD36EAB0A5}" ,Name="Adob
        e Flash Player 18 NPAPI",Version="18.0.0.194")->Uninstall()
        Out Parameters:
        ReturnValue = 0;
        Executing (\\xx\ROOT\CIMV2:Win32_Product.IdentifyingNumber="{2448A347-6E10-4FDE-AD25-74804743D184}" ,Name="Adob
        e Flash Player 18 NPAPI",Version="18.0.0.160")->Uninstall()
        Out Parameters:
        ReturnValue = 0;
        Executing (\\xx\ROOT\CIMV2:Win32_Product.IdentifyingNumber="{44C61B0B-3700-4AA6-AC7C-EE8F0BA9A907}" ,Name="Adob
        e Flash Player 17 NPAPI",Version="17.0.0.169")->Uninstall()
        Out Parameters:
        ReturnValue = 0;
        Executing (\\xx\ROOT\CIMV2:Win32_Product.IdentifyingNumber="{448D7DEC-36F1-4091-B419-C5487BDEB867}" ,Name="Adob
        e Flash Player 18 NPAPI",Version="18.0.0.209")->Uninstall()
        Out Parameters:
        ReturnValue = 0;
        wmic exited on xx with error code 0.
        • 34. Re: Is there a Flash ActiveX registry cleaner?
        Carm01 Level 4
        Can you try pushing the latest version of the Adobe flash uninstaller:
        See if this resolves this maybe?
        • 35. Re: Is there a Flash ActiveX registry cleaner?
        RussR123 Level 1
        Yes, I am using the latest version of the adobe UnInstaller as well. The current appointment pushes the adobe UnInstaller first after that runs then your file Ron's to clean up registry stuff, then the two new versions Flash installer run.
        Sent from my iPhone
        • 36. Re: Is there a Flash ActiveX registry cleaner?
        Carm01 Level 4
        Alright, I am working on the other entries now.
        Also, On my machine when I search under: HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\UpgradeCodes
        All I see are entries like this on my machine for example, I see nothing 'Adobe Flash' or " flash " :
        IFlashBroker3
        I can yank them, however I have no clue what they are for though
        • 37. Re: Is there a Flash ActiveX registry cleaner?
        RussR123 Level 1
        thats the problem, and why i asked adobe for codes... the numbers will be different for each vir.
        example..
        UpgradeCode = {D85A1A59-DC52-4D13-9445-EF3F379D4DB5}
        Property(S): ProductCode = {448D7DEC-36F1-4091-B419-C5487BDEB867}
        PackageCode = {43119FA4-269D-407D-91EC-09322DD9DC33}
        = 95A1A58D25CD31D44954FEF373D9D45B
        = CED7D8441F6319044B915C84B7ED8B76
        this is a log of the full install...
        KeyOperationValueDataTypeOld Data
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Features\CED7D8441F6319044B915C84B7ED8B76Created
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Features\CED7D8441F6319044B915C84B7ED8B76SetFlashPlayerAXInstallerREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76Created
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76SetProductNameAdobe Flash Player 18 NPAPIREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76SetPackageCode4AF91134D962D70419CE9023D29DCD33REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76SetLanguage1033REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76SetVersion301989888REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76SetAssignment1REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76SetAdvertiseFlags388REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76SetProductIconC:\Windows\Installer\{448D7DEC-36F1-4091-B419-C5487BDEB867}\ARPPRODUCTICON.exeREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76SetInstanceType0REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76SetAuthorizedLUAApp0REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76SetDeploymentFlags3REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76SetClients:REG_MULTI_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76\So urceListCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76\So urceListSetPackageNameinstall_flash_player_18_plugin.msiREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76\So urceListSetLastUsedSourcen;1;C:\Users\Public\Documents\Admin Arsenal\PDQ Deploy\Repository\Adobe\flash_player\FlashNuke\REG_EXPAND_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76\So urceList\MediaCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76\So urceList\MediaSetDiskPrompt[1]REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76\So urceList\MediaSet1DISK1;1REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76\So urceList\NetCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\CED7D8441F6319044B915C84B7ED8B76\So urceList\NetSet1C:\Users\Public\Documents\Admin Arsenal\PDQ Deploy\Repository\Adobe\flash_player\FlashNuke\REG_EXPAND_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\UpgradeCodes\95A1A58D25CD31D44954FEF373D9D45 BCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\UpgradeCodes\95A1A58D25CD31D44954FEF373D9D45 BSetCED7D8441F6319044B915C84B7ED8B76REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia\FlashPlayerPluginCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia\FlashPlayerPluginSetVersion18.0.0.209REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia\FlashPlayerPluginSetPlayerPathC:\Windows\system32\Macromed\Flash\NPSWF64_18_0_0_209.dllREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia\FlashPlayerPluginSetUninstallerPathC:\Windows\system32\Macromed\Flash\FlashUtil64_18_0_0_209_Plugin.exeREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia\FlashPlayerPluginSetisScriptDebugger0REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia\FlashPlayerPluginReleaseTypeCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia\FlashPlayerPluginReleaseTypeSetRelease1REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\BITSSetStateIndex0REG_DWORD1
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.CategorySetC:\Windows\system32\FlashPlayerCPLApp.cpl10REG_DWORD10
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Diagnostics\PerfTrack\Scenari oOccurrences\20SetOccurrencesLessThanOrEqualTo25ScaledTPI8342REG_DWORD8338
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Diagnostics\PerfTrack\Scenari oOccurrences\20SetTotalOccurrences8810REG_DWORD8806
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Diagnostics\PerfTrack\Scenari oOccurrences\20SetAverageScaledTpi1REG_DWORD1
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\FoldersDeletedC:\Config.Msi\REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\FoldersSetC:\Windows\Installer\{448D7DEC-36F1-4091-B419-C5487BDEB867}\REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\InProgressDeletedDefault ValueREG_NONEC:\Windows\Installer\47f6d2.ipi
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\95A1A5 8D25CD31D44954FEF373D9D45BCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\95A1A5 8D25CD31D44954FEF373D9D45BSetCED7D8441F6319044B915C84B7ED8B76REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\C omponents\5E8B1F381BB60934C9712D391F430FEBCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\C omponents\5E8B1F381BB60934C9712D391F430FEBSetCED7D8441F6319044B915C84B7ED8B76C:\Windows\SysWOW64\Macromed\Flash\REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\C omponents\C0242696EF5671F4B8FAE863CF58FEF6SetCED7D8441F6319044B915C84B7ED8B76C?\Users\rring\AppData\Local\Temp\InstallPlugin_18_0_0_209.exeREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76Created
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\FeaturesCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\FeaturesSetFlashPlayerAXInstaller8QXJRo+ke9B?ASWS~6GfBJ{rIH]cKA!~MU5`Kz{KREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetRegOwnerLicensed UserREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetRegCompanyVitamixREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetProductIDnoneREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetLocalPackageC:\Windows\Installer\47f6d4.msiREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetAuthorizedCDFPrefixREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetCommentsREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetContactREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetDisplayVersion18.0.0.209REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetHelpLinkhttp://www.adobe.com/go/flashplayer_support/REG_EXPAND_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetHelpTelephoneREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetInstallDate20150714REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetInstallLocationC:\Windows\SysWOW64\Macromed\Flash\REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetInstallSourceC:\Users\Public\Documents\Admin Arsenal\PDQ Deploy\Repository\Adobe\flash_player\FlashNuke\REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetModifyPathMsiExec.exe /X{448D7DEC-36F1-4091-B419-C5487BDEB867}REG_EXPAND_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetNoModify1REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetPublisherAdobe Systems IncorporatedREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetReadmeREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetSizeREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetEstimatedSize18077REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetUninstallStringMsiExec.exe /X{448D7DEC-36F1-4091-B419-C5487BDEB867}REG_EXPAND_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetURLInfoAbouthttp://www.adobe.comREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetURLUpdateInfohttp://www.adobe.com/go/getflashplayerREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetVersionMajor18REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetVersionMinor0REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetWindowsInstaller1REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetVersion301989888REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetLanguage1033REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\InstallPropertiesSetDisplayNameAdobe Flash Player 18 NPAPIREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\PatchesCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\PatchesSetAllPatchesREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\P roducts\CED7D8441F6319044B915C84B7ED8B76\UsageCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMapDeletedProxyBypassREG_NONE
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMapDeletedIntranetNameREG_NONE
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FlashPlayerApp.exeSetDisableExceptionChainValidation0REG_DWORD0
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FlashPlayerPlugin_18_0_0_209.exeCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FlashPlayerPlugin_18_0_0_209.exeSetDisableExceptionChainValidation0REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FlashPlayerUpdateService.exeSetDisableExceptionChainValidation0REG_DWORD0
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FlashUtil32_18_0_0_209_Plugin.exeCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FlashUtil32_18_0_0_209_Plugin.exeSetDisableExceptionChainValidation0REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FlashUtil64_18_0_0_209_Plugin.exeCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FlashUtil64_18_0_0_209_Plugin.exeSetDisableExceptionChainValidation0REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\CompatibilityAdapter\SignaturesSetAdobe Flash Player Updater.job92288bd4f4eda1c6880d497f27c466d608be3c1a6b4285d4d74c5927dfb4f6f592696254aa83b544754c97acee bd9b68222596aa99be831eea8f1818b24dREG_BINARY3c8bdb7770f832a017b0159d423223c1e78c95359c85de28214ea19863efdd886d46774c64839148e78429b9ab ed7fd21cab677120bba16221eac6ce988aa170
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\CompatibilityAdapter\SignaturesSetAdobe Flash Player Updater.job.fp2371952361REG_DWORD234823786
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{B560A276-F29F-4D6A-8B21-5A5DC8CC5455}SetHashe6d4579aa205a428dfcf712fffcac0a0fe82535ab7e34eb815940756bef2dREG_BINARYe6d4579aa205a428dfcf712fffcac0a0fe82535ab7e34eb815940756bef2d
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{B560A276-F29F-4D6A-8B21-5A5DC8CC5455}SetTriggers15000000013dfb100000822273c453bf103dfb10000ffffffffffffffff2821620484848481df225c948484848 048484848484848048484848484848500048484848c00048484848110000051200048484848000048484848380 00484848485820010e0080f430ffffffff9000000000000000000000000000000000000000dddd00000013dfb1 00000822273c453bf10000000000000000000000000000000010e00805110ffffffff100010000000010010000 0000000REG_BINARY15000000013dfb100000822273c453bf103dfb10000ffffffffffffffff2821620484848481df225c948484848 048484848484848048484848484848500048484848c00048484848110000051200048484848000048484848380 00484848485820010e0080f430ffffffff9000000000000000000000000000000000000000dddd00000013dfb1 00000822273c453bf10000000000000000000000000000000010e00805110ffffffff100010000000010010000 0000000
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Adobe Flash Player UpdaterSetIndex3REG_DWORD3
        HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayerCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayerSetPathC:\Windows\system32\Macromed\Flash\NPSWF64_18_0_0_209.dllREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayerSetProductNameAdobe® Flash® Player 18.0.0.209 PluginREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayerSetVendorAdobe Systems IncorporatedREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayerSetDescriptionAdobe® Flash® Player 18.0.0.209 PluginREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayerSetVersion18.0.0.209REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayerPluginCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayerPluginSetVersion18.0.0.209REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayerPluginSetPlayerPathC:\Windows\SysWOW64\Macromed\Flash\NPSWF32_18_0_0_209.dllREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayerPluginSetUninstallerPathC:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_18_0_0_209_Plugin.exeREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayerPluginSetisScriptDebugger0REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayerPluginReleaseTypeCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayerPluginReleaseTypeSetRelease1REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayerSAUSetUpdateAttempts0REG_DWORD0
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayerSAUSetLastUpdateCheck0REG_QWORD0
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayerSAUSetCheckFrequency1REG_DWORD1
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.CategorySetC:\Windows\SysWOW64\FlashPlayerCPLApp.cpl10REG_DWORD10
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMapDeletedProxyBypassREG_NONE
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMapDeletedIntranetNameREG_NONE
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\SharedDLLsSetC:\Users\rring\AppData\Local\Temp\InstallPlugin_18_0_0_209.exe1REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}Created
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetAuthorizedCDFPrefixREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetCommentsREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetContactREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetDisplayVersion18.0.0.209REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetHelpLinkhttp://www.adobe.com/go/flashplayer_support/REG_EXPAND_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetHelpTelephoneREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetInstallDate20150714REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetInstallLocationC:\Windows\SysWOW64\Macromed\Flash\REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetInstallSourceC:\Users\Public\Documents\Admin Arsenal\PDQ Deploy\Repository\Adobe\flash_player\FlashNuke\REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetModifyPathMsiExec.exe /X{448D7DEC-36F1-4091-B419-C5487BDEB867}REG_EXPAND_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetNoModify1REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetPublisherAdobe Systems IncorporatedREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetReadmeREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetSizeREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetEstimatedSize18077REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetUninstallStringMsiExec.exe /X{448D7DEC-36F1-4091-B419-C5487BDEB867}REG_EXPAND_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetURLInfoAbouthttp://www.adobe.comREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetURLUpdateInfohttp://www.adobe.com/go/getflashplayerREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetVersionMajor18REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetVersionMinor0REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetWindowsInstaller1REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetVersion301989888REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetLanguage1033REG_DWORD
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{448D7D EC-36F1-4091-B419-C5487BDEB867}SetDisplayNameAdobe Flash Player 18 NPAPIREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\MozillaPlugins\@adobe.com/FlashPlayerCreated
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\MozillaPlugins\@adobe.com/FlashPlayerSetPathC:\Windows\SysWOW64\Macromed\Flash\NPSWF32_18_0_0_209.dllREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\MozillaPlugins\@adobe.com/FlashPlayerSetProductNameAdobe® Flash® Player 18.0.0.209 PluginREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\MozillaPlugins\@adobe.com/FlashPlayerSetVendorAdobe Systems IncorporatedREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\MozillaPlugins\@adobe.com/FlashPlayerSetDescriptionAdobe® Flash® Player 18.0.0.209 PluginREG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\MozillaPlugins\@adobe.com/FlashPlayerSetVersion18.0.0.209REG_SZ
        HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\MozillaPlugins\@adobe.com/FlashPlayerSetXPTPathC:\Windows\SysWOW64\Macromed\Flash\flashplayer.xptREG_SZ
        HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\MUI\StringCacheSettingsSetStringCacheGeneration1152REG_DWORD1151
        HKEY_USERS\.DEFAULT\Software\Macromedia\FlashPlayerDeletedConflictingProcsREG_NONE
        HKEY_USERS\.DEFAULT\Software\Macromedia\FlashPlayerDeletedRerunInUIModeREG_NONE
        HKEY_USERS\.DEFAULT\Software\Macromedia\FlashPlayerSetFlashPlayerVersion18.0.0.209~installVector=2REG_SZ18.0.0.209~installVector=2
        HKEY_USERS\.DEFAULT\Software\Microsoft\Direct3D\MostRecentApplicationSetNameInstallFlashPlayer.exeREG_SZInstallFlashPlayer.exe
        HKEY_USERS\S-1-5-21-2138466744-1268662106-1780572237-10545\Software\Macromedia\FlashPlayerSetDefault ValueREG_SZ
        HKEY_USERS\S-1-5-21-2138466744-1268662106-1780572237-10545\Software\Macromedia\FlashPlayerSetFlashPlayerVersion18.0.0.209~installVector=2REG_SZ18.0.0.209~installVector=2
        HKEY_USERS\S-1-5-21-2138466744-1268662106-1780572237-10545_CLASSES\Local Settings\MuiCache\47F\52C64B7ESetLanguageListen-US enREG_MULTI_SZen-US en
        • 38. Re: Is there a Flash ActiveX registry cleaner?
        Carm01 Level 4
        did you try deleting the :
        and the
        folders out on the target machines ?
        • 39. Re: Is there a Flash ActiveX registry cleaner?
        Carm01 Level 4
        Also, I am going to send you a link to something in your PM, its something that might solve all this without all the reg edits.
        1 2 Previous Next
