1 Reply Latest reply on May 18, 2012 6:41 PM by Michael L Hale
    How to Generate Barcode (3of9 Barcode or any of its variations) in a simple text layer?
    apmaui808 Level 1
      Is there a way to get the font names used in a computer (C:\windows\fonts), which can be used in Javascript line? I have the barcode font but I don't know its name for Javascript to recognize.
      see line on myTextRef.font below:
      // make a variable for the active document
      var docRef = activeDocument;
      // Create a text layer at the front
      var myLayerRef = docRef.artLayers.add();
      myLayerRef.kind = LayerKind.TEXT;
      myLayerRef.name = "Filename";
      // this is the real text layer describing it as a text item
      var myTextRef = myLayerRef.textItem;
      // Set font size in Points
      myTextRef.size = 24;
      //Can a text or numbers be converted to a Barcode?
      myTextRef.font = "Arial";
      //Set text colour in RGB values
      var newColor = new SolidColor();
      newColor.rgb.red = 255;
      newColor.rgb.green = 255;
      newColor.rgb.blue = 0;
      myTextRef.color = newColor;
      // Set the position of the text - percentages from left first, then from top.
      myTextRef.position = new Array( 50, 50);
      myTextRef.justification = Justification.CENTER
      // If Bold Font
      myTextRef.style = "BOLD";
      // Set the Blend Mode of the Text Layer. The name must be in CAPITALS - ie change NORMAL to DIFFERENCE.
      myLayerRef.blendMode = BlendMode.NORMAL;
      // select opacity in percentage
      myLayerRef.opacity = 100;
