0 Replies Latest reply: May 18, 2012 2:34 PM by whatalotofrubbish RSS
    How do I access the results of a multi dimensional array.
    whatalotofrubbish Community Member
      I created an array from a recordset using the following code copied from a post by David Powers
      $results = array();
      do {
        $results[] = $row_recordsetName;
      } while ($row_recordsetName = mysql_fetch_assoc($recordsetName));
      My recordset has two fields in the $results array, index and name, and the array also seems to generateanother index called whichit uses to reference the rows- in this case, [0] to [2]
      When printed using the print_r function, it shows results like the following:
      Array[0] => Array([index]=>:2[name]=>Microsoft)
      => [1] => Array([index]=>:5[name]=>Facebook)  *
      => [2] => Array([index]=>:6[name]=>Adobe)
      I have another recordset  called employers that has a pointer into the array which holds the same value as the Array[index].
      In this recordset is a row with  a pointer value of 5, and I want to access and print out the Array[ name] whose value =  "Facebook"  from the example array element above*, where Array[index] = 5.
      How would I do it?
      To put it in simulatede SQL, how do I select  $results[name] from $results where $results[index] = $row_employerset[pointer]   and print it?
