0 Replies Latest reply on May 18, 2012 5:29 PM by Pham Huy Anh
    Bug of ADEP 4.6 Dataservice JEE ?! - webservice from 1st module, dataservice in 2nd module
    Pham Huy Anh
      Dear support,
      I strugged for the last 3 days for this problem. I think it something is wrong with ADEP 4.6
      Our testModule flex project points to Adobe samples app: C:\ADEP Data Services for Java EE 4.6\tomcat\webapps\dataservices-samples\ which is created to load 2 modules.
      testModule.mxml - Main
      <?xml version="1.0"?>
      <!-- modules/SimpleProgressEventHandler.mxml -->
                     xmlns:mx="library://ns.adobe.com/flex/mx"
                     xmlns:control="ipslib.control.*"
                     implements="flash.events.IEventDispatcher">
          <fx:Declarations>
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
                  import mx.controls.Alert;
                  import mx.events.FlexEvent;
                  import mx.events.ModuleEvent;
                  import mx.modules.*;
                  [Bindable]
                  public var progBar:String = "";
                  [Bindable]
                  public var progMessage:String = "";
                  public function createModule():void {
                      firstLoader.loadModule(moduleTxt.text);
                  public function createModule2():void {
                      secondLoader.loadModule(moduleTxt2.text);
                  public function removeModule():void {
                      firstLoader.unloadModule();
                  public function removeModule2():void {
                      secondLoader.unloadModule();
                  protected function moduleLoader_error(event:ModuleEvent):void
                      Alert.show("error  " + event.errorText);
          </fx:Script>
          <s:VGroup width="100%" height="100%">
              <mx:HBox>
                  <mx:Button label="Load 1st module" click="createModule()"/>
                  <mx:Button label="Unload 1st module" click="removeModule()"/>
                  <mx:TextInput id="moduleTxt" text="Module1.swf"/>
              </mx:HBox>
              <mx:ModuleLoader id="firstLoader" width="100%" height="100%"
                               error="moduleLoader_error(event)"
                               ready="moduleLoader_error(event)"/>
              <mx:HBox>
                  <mx:Button label="Load 2nd module" click="createModule2()"/>
                  <mx:Button label="Unload 2nd module" click="removeModule2()"/>
                  <mx:TextInput id="moduleTxt2" text="Module2.swf"/>
              </mx:HBox>
              <mx:ModuleLoader id="secondLoader" width="100%" height="100%"
                               error="moduleLoader_error(event)"/>
          </s:VGroup>
      </s:Application>
      1st module just has a dummy webservice declared :
      Module1.mxml
      <s:Module xmlns:fx="http://ns.adobe.com/mxml/2009"
                xmlns:mx="library://ns.adobe.com/flex/mx" width="100%" height="100%" creationComplete="init()">
          <fx:Declarations>
              <s:WebService id="fooWs" destination="ws-foo"
                            useProxy= "true"
                            showBusyCursor="true" result="fooWs_resultHandler(event)" fault="fooWs_faultHandler(event)" >
              </s:WebService>
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
                  import mx.data.Conflicts;
                  import mx.data.events.DataConflictEvent;
                  import mx.rpc.events.FaultEvent;
                  import mx.rpc.events.ResultEvent;
                  protected function init():void
                      trace('init do nothing');
                  protected function fooWs_resultHandler(event:ResultEvent):void
                      trace('webserivce result ' +event.message);
                  protected function fooWs_faultHandler(event:FaultEvent):void
                      trace('webserivce fault '+event.message);
          </fx:Script>
          <mx:Panel width="100%" height="100%" title="Doing nothing, a websvice is declared in the background">
          </mx:Panel>
      </s:Module>
      which points to
      proxy-config.xml
      <destination id="ws-foo">
              <properties>
                  <wsdl>http://whatever.com:9090/anything?wsdl</wsdl>
                  <soap>*</soap>
              </properties>
              <adapter ref="soap-proxy" />
          </destination>
      2nd Module: just has a dummy DataSerivce
      Module2.mxml
          <fx:Declarations>
              <mx:DataService id="dsEmployee" destination="crm-employee"
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
          </fx:Script>
          <mx:Panel width="100%" height="100%" title="Doing nothing, a Dataservice is declared in the background">
          </mx:Panel>
      </s:Module>
      which points to crm-employee in data-management-config.xml.
      If you load the 1st module, then you will get this error on 2nd module
      Error
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
          at mx.data::Metadata/applyConfigSettingsForDataService()[C:\depot\DataServices\branches\mile stone\adepds46_rc\frameworks\projects\data\src\mx\data\Metadata.as:2307]
          at mx.data::Metadata/applyConfigSettings()[C:\depot\DataServices\branches\milestone\adepds46 _rc\frameworks\projects\data\src\mx\data\Metadata.as:2402]
          at Function/<anonymous>()[C:\depot\DataServices\branches\milestone\adepds46_rc\frameworks\pr ojects\data\src\mx\data\Metadata.as:119]
          at mx.data::Metadata/initialize()[C:\depot\DataServices\branches\milestone\adepds46_rc\frame works\projects\data\src\mx\data\Metadata.as:181]
          at mx.data::ConcreteDataService()[C:\depot\DataServices\branches\milestone\adepds46_rc\frame works\projects\data\src\mx\data\ConcreteDataService.as:153]
          at mx.data::ConcreteDataService$/getService()[C:\depot\DataServices\branches\milestone\adepd s46_rc\frameworks\projects\data\src\mx\data\ConcreteDataService.as:2206]
          at mx.data.mxml::DataService/set destination()[C:\depot\DataServices\branches\milestone\adepds46_rc\frameworks\projects\da ta\src\mx\data\mxml\DataService.as:136]
          at Module2/_Module2_DataService1_i()[C:\WB_WS\wb_flex_ws2\testModule\src\Module2.mxml:4]
          at Module2()[C:\WB_WS\wb_flex_ws2\testModule\src\Module2.mxml:4]
          at _Module2_mx_core_FlexModuleFactory/create()[_Module2_mx_core_FlexModuleFactory.as:54]
          at mx.modules::ModuleLoader/moduleReadyHandler()[E:\dev\4.y\frameworks\projects\mx\src\mx\mo dules\ModuleLoader.as:545]
          at flash.events::EventDispatcher/dispatchEventFunction()
          at flash.events::EventDispatcher/dispatchEvent()
          at ModuleInfoProxy/moduleEventHandler()[E:\dev\4.y\frameworks\projects\framework\src\mx\modu les\ModuleManager.as:1149]
          at ModuleInfo/readyHandler()[E:\dev\4.y\frameworks\projects\framework\src\mx\modules\ModuleM anager.as:793]
          at mx.core::FlexModuleFactory/update()[E:\dev\4.y\frameworks\projects\framework\src\mx\core\ FlexModuleFactory.as:535]
          at mx.core::FlexModuleFactory/docFrameHandler()[E:\dev\4.y\frameworks\projects\framework\src \mx\core\FlexModuleFactory.as:681]
          at mx.core::FlexModuleFactory/docFrameListener()[E:\dev\4.y\frameworks\projects\framework\sr c\mx\core\FlexModuleFactory.as:131]
      Could you please confirm if it is the same on your workstation?
