3 Replies Latest reply on May 19, 2012 5:59 AM by Peter Spier
    fonts not Embedded
    snegig
      Hi everyone,
      I am using InDesign CS 5.5. We make pdf but my some fonts not embedded. We use all fonts are opentype.
      (1) We use font Agent Pro then same problem appear
      (2) If we place fonts in InDesign Fonts folder again same problem appear in PDF files.
      Kindly suggest what we do thank you so much.
        • 1. Re: fonts not Embedded
          Rhe only font in that image that doesn't say "embedded" -- the one you highlight -- says "embedded subset". That is the SAME as "embedded".
          (Not really of course, but the difference is much less than with what you seemed to think: that if a font status is NOT showing the exact text "embedded", then it must mean it is "not embedded". That is simply not true.)
          • 2. Re: fonts not Embedded
            Steve Werner Adobe Community Professional & MVP
            Jongware is correct. Embedded Subset means that the glyphs you are using in the document are embedded in the PDF file. There's no problem.
            • 3. Re: fonts not Embedded
              You'll notice, too, that it's listed as GothamNarrow-Book, like the one above it, but with a different encoding. It's probably ligatures, or small caps, or other specials.
