1 Reply Latest reply on May 22, 2012 12:03 PM by tumesch
    Photoshop CS6 very sluggish after assigned RAM is used up
    tumesch
      Hello community,
      during the evaluation of my PS CS6 trial I encountered the following problem. Painting on a layer mask is very, very sluggish once Photoshop CS6 has used up all RAM that has been assigned to it.
      When I am in 100% view and <shift><click> about 10 times in quick succession it takes almost a minute for photoshop to catch up, often the last clicks get lost and the next click draws a line without using <shift>.
      I tried without appreciable improvement:
      - Different brushes (hard, soft, down to 10px)
      - Disable graphics processor
      - Disable layer icons
      The problem seems to be related to virtual memory handling. Does PS CS6 use virtual memory buffering? The Activity Monitor shows still free memory.
      In comparison and on the same system, Photoshop CS4 with default VM Buffering remains quite responsive although the RAM usage of PS CS4 (active + inactive) is much lower than in CS6.
      What can I do to fix the problem? This issue prevents me from upgrading to CS6.
      Thomas
      Image data
      25130 x 9250 px, 16bpc, 95 layers with masks, but 92 of them with non-transparent pixels in only a small area (177 x 236 px)
      System data
      Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x64
      Operating System: Mac OS 10.6.8
      System architecture: Intel CPU Family:6, Model:44, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
      Physical processor count: 6
      Logical processor count: 12
      Processor speed: 3330 MHz
      Built-in memory: 12288 MB
      Free memory: 509 MB
      Memory available to Photoshop: 11625 MB
      Memory used by Photoshop: 70 %
      Image tile size: 1024K
      Image cache levels: 4
      OpenGL Drawing: Enabled.
      OpenGL Drawing Mode: Advanced
      OpenGL Allow Normal Mode: True.
      OpenGL Allow Advanced Mode: True.
      OpenGL Allow Old GPUs: Not Detected.
      OpenGL Version: 2.1 ATI-1.6.36
      OpenCL Version: 1.0 (Dec 23 2010 17:30:26)
      Video Card Vendor: ATI Technologies Inc.
      Video Card Renderer: ATI Radeon HD 5770 OpenGL Engine
      Display: 1
      Main Display
      Display Depth:= 32
      Display Bounds:=  top: 0, left: 0, bottom: 1200, right: 1600
      Video Renderer ID: 16915202
      Video Card Memory: 1013 MB
      Video Rect Texture Size: 16384
      Serial number: Tryout Version
      Application folder: System:Applications:Adobe Photoshop CS6:
      Photoshop scratch has async I/O enabled
      Scratch volume(s):
        Scratch, 232,6G, 217,3G free
      Required Plug-ins folder: System:Applications:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
      Primary Plug-ins folder: System:Applications:Adobe Photoshop CS6:Plug-ins:
      Additional Plug-ins folder: not set
      Installed components:
         adbeape.framework   adbeape   3.3.8.19346   66.1025012
         AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.2.29.18602   66.490082
         adobe_caps.framework   adobe_caps   6.0.29.0   1.276181
         AdobeACE.framework   AdobeACE   2.19.18.19243   66.492997
         AdobeAGM.framework   AdobeAGM   4.26.17.19243   66.492997
         AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
         AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
         AdobeBIB.framework   AdobeBIB   1.2.02.19243   66.492997
         AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   66.492997
         AdobeCoolType.framework   AdobeCoolType   5.10.31.19243   66.492997
         AdobeCrashReporter.framework   AdobeCrashReporter   6.0.20120201
         AdobeExtendScript.framework   AdobeExtendScript   4.2.12.18602   66.490082
         AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
         AdobeLinguistic.framework      17206
         AdobeMPS.framework   AdobeMPS   5.8.0.19463   66.495174
         AdobeOwl.framework   AdobeOwl   4.0.93   66.496052
         AdobePDFL.framework   AdobePDFL   10.0.1.18562   66.419471
         AdobePDFSettings.framework   AdobePDFSettings   1.4
         AdobePIP.framework   AdobePIP   6.0.0.1654
         AdobeScCore.framework   AdobeScCore   4.2.12.18602   66.490082
         AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
         AdobeXMP.framework   AdobeXMPCore   66.145661   66.145661
         AdobeXMPFiles.framework   AdobeXMPFiles   66.145661   66.145661
         AdobeXMPScript.framework   AdobeXMPScript   66.145661   66.145661
         ahclient.framework   ahclient   1.7.0.56
         aif_core.framework   AdobeAIF   3.0.00   62.490293
         aif_ocl.framework   AdobeAIF   3.0.00   62.490293
         aif_ogl.framework   AdobeAIF   3.0.00   62.490293
         AlignmentLib.framework   xcode   1.0.0.1
         amtlib.framework   amtlib   6.0.0.75
         boost_date_time.framework   boost_date_time   6.0.0.0
         boost_signals.framework   boost_signals   6.0.0.0
         boost_system.framework   boost_system   6.0.0.0
         boost_threads.framework   boost_threads   6.0.0.0
         Cg.framework   NVIDIA Cg
         CIT.framework   CIT   2.0.5.19287   145486
         data_flow.framework   AdobeAIF   3.0.00   62.490293
         dvaaudiodevice.framework   dvaaudiodevice   6.0.0.0
         dvacore.framework   dvacore   6.0.0.0
         dvamarshal.framework   dvamarshal   6.0.0.0
         dvamediatypes.framework   dvamediatypes   6.0.0.0
         dvaplayer.framework   dvaplayer   6.0.0.0
         dvatransport.framework   dvatransport   6.0.0.0
         dvaunittesting.framework   dvaunittesting   6.0.0.0
         dynamiclink.framework   dynamiclink   6.0.0.0
         FileInfo.framework   FileInfo   66.145433   66.145433
         filter_graph.framework   AdobeAIF   3.0.00   62.490293
         hydra_filters.framework   AdobeAIF   3.0.00   62.490293
         ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
         ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
         image_compiler.framework   AdobeAIF   3.0.00   62.490293
         image_flow.framework   AdobeAIF   3.0.00   62.490293
         image_runtime.framework   AdobeAIF   3.0.00   62.490293
         LogSession.framework   LogSession   2.1.2.1652
         mediacoreif.framework   mediacoreif   6.0.0.0
         PlugPlug.framework   PlugPlug   3.0.0.383
         UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24   "6.0.0.24"
         wrservices.framework
      Required plug-ins:
         3D Studio 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
         Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
         ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc.  All rights reserved. - from the file “AdobeADM.bundle”
         Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Average 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
         Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Camera Raw 7.0 (308), Copyright © 2012 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
         Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Cineon 13.0 20120315.r.428 2012/03/15:21:00:00  ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
         Clouds 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
         Collada DAE 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
         Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Crop and Straighten Photos 13.0 20120315.r.428 2012/03/15:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
         Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Dicom 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “dicom.plugin”
         Difference Clouds 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
         Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Eazel Acquire 13.0 20120315.r.428 2012/03/15:21:00:00  ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
         Embed Watermark NO VERSION - from the file “DigiSign.plugin”
         Enable Async I/O 13.0 20120315.r.428 2012/03/15:21:00:00  © 2004-2012 Adobe Systems Incorporated - from the file “Enable Async IO.plugin”
         Entropy 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
         Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         FastCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
         Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Flash 3D 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
         Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Google Earth 4 KMZ 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
         Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
         IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         JPEG 2000 13.0 20120315.r.428 2012/03/15:21:00:00  ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
         Kurtosis 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
         Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
         Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
         Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
         Matlab Operation 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
         Maximum 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
         Mean 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
         Measurement Core 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
         Median 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
         Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Minimum 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
         MMXCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
         Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Multiprocessor Support 13.0 20120315.r.428 2012/03/15:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
         Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         NTSC Colors 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
         Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
         OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         PCX 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
         Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Photoshop 3D Engine 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
         Picture Package Filter 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
         Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Pixar 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
         Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Portable Bit Map 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
         Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Radiance 13.0 20120315.r.428 2012/03/15:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
         Range 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
         Read Watermark NO VERSION - from the file “DigiRead.plugin”
         Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
         ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
         Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Skewness 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
         Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Solarize 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
         Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Standard Deviation 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
         Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Summation 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
         Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         U3D 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
         Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
         Variance 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
         Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Wavefront|OBJ 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
         Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Wireless Bitmap 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
         ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
      Optional and third party plug-ins:
         FocalBlade 2.0 FocalBlade 2.01 © 2006-2010 Harald Heim & The Plugin Site - from the file “FocalBlade.plugin”
      Plug-ins that failed to load: NONE
      Flash:
         Mini Bridge
         Kuler
      Installed TWAIN devices: NONE
        • 1. Re: Photoshop CS6 very sluggish after assigned RAM is used up
          tumesch Level 1
          I did a lot of additional testing and made the following observation:
          It happens only when painting on the layer mask, not on the layer itself. After some brush strokes in the swapping state (see above) the program reproducibly behaves like this when trying to make another stroke:
          1. I make a stroke with the mouse
          2. Some seconds later the initial point appears, there is some disk write activity
          3. Then Photoshop's CPU utilization rises to 100% with zero disk activity - it stays there until ...
          4. I click somewhere in the image and immediately a linear stroke from the initial point to the click position is drawn. This final click even works when Photoshop does not currently have the application focus - application switching to Photoshop via the dock icon does not visibly work anyway in this state.
          I can repeat that sequence. If I wait long enough it somehow gets cured, but then it only takes another ~10 strokes to get the strange behaviour back.
          tumesch
