4 Replies Latest reply on May 19, 2012 2:52 PM by Bobrrseibel
    Including narations once
    Bobrrseibel Level 1
      I have Adobe Premier Elements 10 which includes the Organizer. I use Organizer to add an audio naration to single pictures for a slide show.
      Then when I use Elements to create the DVD, the naration does not follow along with the single picture in the slide show I create.
      I can add narrations again using PE which does get saved and included.
      Question: How can I just record the naration once in the Organizer and have it included along with the picture when I put all the pictures together in one slide show using PE?
        • 1. Re: Including narations once
          the_wine_snob Level 9
          If I understand the question, I would record the narration in PrE, and probably use one of the empty Audio Tracks, as some folk have had issues with the Fixed Narration Track. Then, just Export/Share the Audio ONLY, as a PCM/WAV file @ 48KHz 16-bit. Locate that file, where you wish, and then just Import that into each Project, as needed.
          Good luck, and hope that helps,
          • 2. Re: Including narations once
            Bobrrseibel Level 1
            Thanks Bill… Will do.. I will not use the record feature in the Organizer then.
            Bob
            • 3. Re: Including narations once
              Bob,
              I have never used the Organizer for this, and it might be just what you need? Others can probably direct you there.
              I seldom use Organizer, as I do my file management with other programs, such as Adobe Bridge, from my Production Premium, or ThumbsPlus (Cerious Software). Hence, I am no where near current, or an expert with what Organizer can, and cannot do, or even which features it has.
              For Audio recording, I most often use Adobe Audition, and then Import the Audio file into Premiere for use.
              • 4. Re: Including narations once
                Bobrrseibel Level 1
                Thanks Bill. It is a nice feature in Organizer. Perfect for what I want to do. I just can’t figure out how to get those recordings attached to each picture in Organizer into PE10 when I add those pics into the sceneline.
                Will use your workaround…
                Thanks!
                Bob
