3 Replies Latest reply: May 20, 2012 5:50 AM by Howard Hoffman RSS
    Encore exhausts memory
    Howard Hoffman Community Member
      Encore 5.5, Windows 7, 64-bit
      When I import an m4v asset, the system memory usage will keep going up.  Eventually, the system will use up all physical RAM and becomes useless. This is observed in task manager.
      However, there is no process that uses this amount of RAM in process tab.  Encore uses only about 1.5 GB.  There is nothing else using more than 200 MB.
      Once I kill Encore, the system memory usage goes down to about 1.5 GB from 8 GB.
      Normally, when this happens, I just restart Encore and import in another way (drag-drop, right click to import).  A few tries later, I will have a successful import with peak memory usage less than 3 GB.
      However, now I got 1 hour m4v (1 hour) that can't pass no matter what I tries.
      Has anyone seen similar things happening?
        • 1. Re: Encore exhausts memory
          John T Smith CommunityMVP
          I guess the obvious question is... what are the exact parameters of your file?
          IE- what are your export settings from Premiere Pro?
          Simply because I don't care to get into bit budgeting and calculations, I always export DV AVI Widescreen from PPro (I edit AVCHD, but do not have a BluRay burner) and then let Encore do "automatic" encoding to calculate the best fit on a DVD
          I have never had a single problem doing that, with timelines up to, and in one case slightly over, 2 hours
          Post your file details and maybe someone will be able to comment
          • 2. Re: Encore exhausts memory
            Format                           : AVC
            Format/Info                      : Advanced Video Codec
            Format profile                   : Main@L4.1
            Format settings, CABAC           : Yes
            Format settings, ReFrames        : 3 frames
            Bit rate mode                    : Variable
            Maximum bit rate                 : 35.0 Mbps
            Width                            : 1 920 pixels
            Height                           : 1 080 pixels
            Display aspect ratio             : 16:9
            Frame rate                       : 29.970 fps
            Standard                         : NTSC
            Color space                      : YUV
            Chroma subsampling               : 4:2:0
            Bit depth                        : 8 bits
            Scan type                        : Interlaced
            Scan order                       : Top Field First
            Some of these video have problem imported as Encore insisting on transcoding them again.  However, this one belongs to the other half that does not have this problem.
            • 3. Re: Encore exhausts memory
              I'd need to correct my claim.  It does not cause out of memory error by exhausting virtual memory. It just uses up all physical RAM and causes extensive disk activity.  So if I can put up with the long delay with disk activity (nothing else will work), it can import the file successfully.
              The source video are system are on differet a hard drive.  So it's definitely not not b/c reading in the video.
              I wonder if it's matter of miscalculation of available RAM.  It may try to use all the physical memory possible to speed things up.  But it does not do the math right.
