17 Replies Latest reply on May 29, 2012 12:20 AM by ocroquette
    Lightroom processes for ages after withProlongedWriteAccessDo
    ocroquette Level 1
      I am considering a switch from Expression Media to Lightroom, and I wrote for that a Lightroom plugin that imports all my metadata from an EM XML file. Functionaly, it works great.
      However, I have a performance issue problem: if I run the plugin on my whole photo collection (>30.000 items), then Lightroom gets crazy with the CPU and the memory after once my code returns.
      The processing time seems exponential. If I run the plugin with 1.000 items, the return is almost instantaneous. On 5.000 items, it takes several minutes. With 30.000 items, it still wasn't finished after 30min, I killed Lightroom.
      My guess is that Lightroom does some kind of post-processing, or maybe that's because Lightroom prepares the "undo".
      Is that a known problem ?
      Here is the skeleton of my code. Once doStuff2 returns, Lightroom does who knows what, and then doStuff returns too. This time seems exponential with the number of database changes my code causes.
      function doStuff2(context, progress)
           local catalog = LrApplication.activeCatalog()
           local photos = catalog:getTargetPhotos()
           parseXml()
           for completed, photo in ipairs( photos ) do
                if progress:isCanceled() then return end
                photo:addKeyword(...)
                setMetadata(...)
      end
      function doStuff()
           catalog:withProlongedWriteAccessDo(
                     title="Import from Expression Media",
                     func=doStuff2,
                     caption="Initializing plugin",
                     pluginName="Expression Media Import",
                     optionalMessage = "The plugin will first read your Expression Media XML file and then import the data into Lightroom for "
                          .. ( # catalog:getTargetPhotos() ) .. " photos"
      end
      import 'LrTasks'.startAsyncTask( doStuff )
        • 1. Re: Lightroom processes for ages after withProlongedWriteAccessDo
          areohbee Level 6
          Lightroom can really get bogged down when doing large numbers of catalog updates as a single transaction.
          I suggest limiting to 1000 photos a whack. I think Lr4 is worse than Lr3 in this regard, or at least it is for me anyway...
          Rob
          • 2. Re: Lightroom processes for ages after withProlongedWriteAccessDo
            ocroquette Level 1
            Thanks Rob.
            Is there any way for a plugin to force Lightroom to close a transaction during the processing and open a fresh one ?
            • 3. Re: Lightroom processes for ages after withProlongedWriteAccessDo
              areohbee Level 6
              You're welcome ocroquette.
              Only way I know is to return from the "with-do" function, and then go back in...
              Hint: Use withWriteAccessDo instead of the "prolonged" version.
              • 4. Re: Lightroom processes for ages after withProlongedWriteAccessDo
                DawMatt Level 3
                As Rob said the official way to choose the commit point is to close a "with-do", and then start a new one for the next batch of transactions. This technique is useful when batching large numbers of changes to the catalog (as you are) or when making changes that only become visible after a commit (e.g. creation collections or changing their contents).
                Matt
                • 5. Re: Lightroom processes for ages after withProlongedWriteAccessDo
                  ocroquette Level 1
                  Thanks.
                  This performance problem hits me hard. I was almost done, but now I have to refactor my code to process batch of 1.000 files instead of processing the 30000 files at one, and that's not a trivial task
                  • 6. Re: Lightroom processes for ages after withProlongedWriteAccessDo
                    johnrellis Most Valuable Participant
                    While every database technology has various resource issues with long-running, voluminous transactions, I wonder in this case whether the problem might not be with the relational database (SQLite) but rather LR's undo facility.
                    A quick experiment: Try catalog:withPrivateWriteAccessDo() instead. From the SDK:
                    Provides write access to custom fields defined by your plug-in. Use this instead of withWriteAccessDo() if you are only modifying metadata for your plug-in and do not want to add the operation to the undo stack.
                    The documentation is ambiguous, not differentiating between the intended use and actual semantics. But I'd guess that the only difference between withWriteAccessDo() and withPrivateWriteAccessDo() is that the latter doesn't add all the catalog changes to the LR application undo stack.
                    If that quick change doesn't work, then I agree with Rob that breaking up the changes into smaller batches will give much better overall performance.
                    • 7. Re: Lightroom processes for ages after withProlongedWriteAccessDo
                      areohbee Level 6
                      It's a pisser alright, and although not trivial, it's not too difficult either.
                      I've been lobbying with Adobe to remedy this. It's one thing for it to take a long time, but a worse problem is that it can over-consume ram and hang the system.
                      I decided to build the incremental catalog updating into my core methods (not yet released):
                      http://forums.adobe.com/thread/1009149
                      Even splitting the update into chunks, Lightroom gets slower and slower as it goes. For me, it usually makes it through if I leave it run long enough, but it's a mystery why it gets sooooooo slow after a time...
                      Rob
                      • 8. Re: Lightroom processes for ages after withProlongedWriteAccessDo
                        ocroquette Level 1
                        I am done with my transfer now. I have posted my code here:
                        https://ocroquette.wordpress.com/2012/05/23/switching-from-expression-media-to-lightroom/
                        Thanks all for the great input.
                        About the performance, on my system, my plugin is able to process about 100 photos / second at the beginning , but at the end it's down to 40 photos / second, even working with small chunks. I used chunks of 1000 photos, but in the end I don't think it changes much the total time. It just allows to show the progress, which is a must, knowing that the whole process takes 10-15min for my 33.000 pictures.
                        I also realized that fetching the keywords from Lightroom is damn slow, I implemented a cache, that helped, but the cache has to be flushed after each transaction.
                        I think I also found a bug. The following code:
                             local keyword = catalog:createKeyword("Test" , { }, true, nil )
                             local children = keyword:getChildren()
                        Produces the followin error:
                        An internal error has occured
                        bad argument #2 to 'format' (number expected, got string)
                        I have a workaround in my code for this bug, so it's not blocking me, but I would like to report it to Adobe. Do you know the best way to do so ? I am unsure.
                        And does it make sense to complain about the performance issues of big transactions ? If yes, where ?
                        Thanks again for your help. This thread has been very useful to me !
                        Olivier
                        • 9. Re: Lightroom processes for ages after withProlongedWriteAccessDo
                          Just curious -- did you try catalog:withPrivateWriteAccessDo()?
                          • 10. Re: Lightroom processes for ages after withProlongedWriteAccessDo
                            The LrKeyword methods, along with most methods that access objects represented in the catalog, are very slow.  But at least they got about 6 times faster in LR 4 compared to LR 3.  LrPhoto has batch methods for getting metadata from many photos at once, but there's no equivalent for keywords.  I think it's a big deficiency in the SDK.
                            • 11. Re: Lightroom processes for ages after withProlongedWriteAccessDo
                              Adobe wants all bugs and feature suggestions for Lightroom to be posted here:
                              http://feedback.photoshop.com/photoshop_family/products/photoshop_family_photoshop_lightro om
                              Those few of us developers active here generally start the subject lines with "SDK: ".
                              • 12. Re: Lightroom processes for ages after withProlongedWriteAccessDo
                                DawMatt Level 3
                                Hi Olivier,
                                It it possible you will need to close a transaction (i.e. a with...Do call) between the first and second command, as the second one is accessing a change to the catalog that might not have been committed yet. This could be causing the bug you are observing. Does your workaround involve something like this? If so it might not actually be a bug and instead be operating "as designed", but not documented clearly enough to be easily understood by those new to the SDK.
                                Matt
                                • 13. Re: Lightroom processes for ages after withProlongedWriteAccessDo
                                  areohbee Level 6
                                  Very possibly.
                                  I've been really stoked with my new multi-phase catalog accessor - strongly recommend writing something like it for yourselves (see source code in other thread, or contact me for fresh stuff).
                                  Here's an example from my most recent plugin:
                                  local s, m = cat:update( 10, "Assure Folder Collection Set", function( context, phase ) -- 10 is seconds to get in.
                                      -- function can take parameters, but not used here.
                                      if phase == 1 then
                                          set = catalog:createCollectionSet( folder:getName(), parent, true )
                                          return false -- keep going
                                      elseif phase == 2 then
                                          leafPhotos = folder:getPhotos(false)
                                          if #leafPhotos > 0 then
                                              return false
                                          else
                                              return true -- done
                                          end
                                      elseif phase == 3 then
                                          coll = catalog:createCollection( str:fmt( '[^1]', folder:getName() ), set, true )
                                          app:logVerbose( "Created/assured \"Folder Leaf Photos\" collection ^1 in '^2'", folder:getName(), set:getName() )
                                          return false
                                      elseif phase == 4 then
                                          local collPhotos = coll:getPhotos()
                                          if #collPhotos > 0 then
                                              local collPhotoSet = tab:createSet( collPhotos )
                                              for i, photo in ipairs( leafPhotos ) do
                                                  if not collPhotoSet[photo] then
                                                      toAdd[#toAdd + 1] = photo
                                                  end
                                              end
                                          else
                                              toAdd = leafPhotos
                                          end
                                          if #toAdd > 0 then
                                              coll:addPhotos( toAdd )
                                          end
                                          return true
                                      end
                                  end )
                                  Note: each phase is a new transaction.
                                  In your case Oliver:
                                  local keyword
                                  local children
                                  local s, m = cat:update( 10, "Keyword business", function( context, phase )
                                       if phase == 1 then
                                            keyword = catalog:createKeyword( "Test", {}, true, nil )
                                            return false -- continue to 2nd phase.
                                            -- do something to catalog with children
                                            return true -- or nil.
                                       end
                                  end )
                                  This would not make sense if nothing further involved catalog writes (in which case just exiting a simple single-phase with-do method would suffice), but you get the idea, no?
                                  R
                                  • 14. Re: Lightroom processes for ages after withProlongedWriteAccessDo
                                    ocroquette Level 1
                                    I tried quickly. It looked like I could only access the plugin private data in this context.
                                    • 15. Re: Lightroom processes for ages after withProlongedWriteAccessDo
                                      ocroquette Level 1
                                      http://feedback.photoshop.com/photoshop_family/products/photoshop_fami ly_photoshop_lightroom
                                      Thanks ! I have created a dedicate thread: http://feedback.photoshop.com/photoshop_family/topics/sdk_getchildren_returns_an_exception _for_newly_created_lrkeyword
                                      • 16. Re: Lightroom processes for ages after withProlongedWriteAccessDo
                                        ocroquette Level 1
                                        Hi Matt,
                                        yes, it works after the transaction is closed. My workaround is however to avoid calling getChildren() for newly created LrKeyword's and instead use the hard coded empty list. When new children are added, then getChildren() starts working.
                                        I don't know if this is by design, but it must be fixed. I see no reason why getChildren() should not work until the transaction is closed, even from the perspective of the SDK developers. It just looks like a missing initialization of some sort for the new LrKeyword's object, which is fixed by a transaction or the addition of children.
                                        • 17. Re: Lightroom processes for ages after withProlongedWriteAccessDo
                                          ocroquette Level 1
                                          Rob Cole wrote:
                                          Very possibly.
                                          Thanks a lot for sharing your code Rob ! It's very interesting. As far as my case is concerned, I have now transitioned from Expression Media to Lightroom, so I stopped working on this. But your code may come in handy when I write more plugins !
