I am current using a Dell Latitude D820 Laptop that is using Windows 7 (32-bit) running with the current version of Firefox (12, not a beta version) and have just installed the most current version of Adobe Flash Player (11). However I am completely unable to play any of my computers .swf or .flv files.
Whenever I try to open the Swiff player an error message pops up that says and I quote 'Unfortunately, Adobe Flash player ActiveX isn't installed in your system. SWF & FLV player requires this ActiveX control for proper working. Please visit www.adobe.com and install Flash Player ActiveX Control.' (This is the error message to the letter I left out nothing.)
Now I navigated to the website and installed the newest version of flash that the adobe website provided and after looking extensively (see exhaustively) through both the web and the adobe help site for a solution for this problem I have found nothing conclusive.
So I attempted to use Eolsoft Flash Movie Player but it provided the following error message: Flash Movie Player requires the Macromedia Flash Player Plugin, which is not found in this system. Would you like to go to the Macromedia website and install the plugin?
Following the provided link simply leads me to the adobe website where I have both installed and uninstalled the program several times. If anyone knows the solution to these problems I would very much appreciate your help.
After searching more through the internet and my computer I have found in the settings of my flash that it says ActiveX version is not installed. What does that mean? I thought that ActiveX came with the Adobe Flash download.
Flash Player has two components:
Other applications may use one or the other of these components, so you may need to have both installed.
Try downloading and running the offline installers from http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html#install_in_a_firewall_proxy_server_environment - note that no browsers or applications using Flash Player must be running during the install.
If you sti
...Copy link to clipboard
Try downloading and running the offline installers from http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html#install_in_a_... - note that no browsers or applications using Flash Player must be running during the install.
If you still have problems after that, please list what files you have in C:\Windows\system32\Macromed\Flash
Thank you so much for your help! Downloading from Internet Explorer did the trick alright. I was beginning to think my computer was the problem. Thanks again!
SOLUTION:
1) Install Flash Player
2) Install Window Flash Player 14 ActiveX control content debugger (for IE)
unfortunately I pops that thread again. I had the same problem like my friend up here Hexweaver describe.
for opening swf files I'm using Swiff Player - "Whenever I try to open the Swiff player an error message pops up that says and I quote 'Unfortunately, Adobe Flash player ActiveX isn't installed in your system. SWF & FLV player requires this ActiveX control for proper working. Please visit www.adobe.com and install Flash Player ActiveX Control.' (This is the error message to the letter I left out nothing.) "
For the first step - " I navigated to the website and installed the latest version of flash that the adobe website provided " , which thankfully helped open the Swiff Player.
Now every time Im trying opening swf video file the following message appears -
Im not sure but Its seems like a kind of ActiveX file is missing on the computer system, if i could only know which file are necessary for opening SWF video file its would be very useful solving the problem . If anyone saw that kind of message or knows the solution to these problems I would very much appreciate your help.
