6 Replies Latest reply on Jul 30, 2014 2:56 AM by howie3055
    why am I getting an error message "No permission to copy document here"?
    muggersmom@yahoo.com
      why am I getting the error message No permission to copy document here?
        • 1. Re: why am I getting an error message "No permission to copy document here"?
          Because you don't have "permission to copy document here"? Pardon the sarcasm, but you're not telling us anything here - not the program, not the operating system, no nothing. Nobody can help you based on some sentence that merely reflects your frustrated mumbling at the screen...
          Mylenium
          • 2. Re: why am I getting an error message "No permission to copy document here"?
            muggersmom@yahoo.com Level 1
            I thought i was still on the help site cor adobe digital reader not the entire Adobe site. I downloaded books from my local library and cant transfer them to my nook, it says they are documents and i cant copy them. Ive been doing it the same way for 6 months and now i have problems
            • 3. Re: why am I getting an error message "No permission to copy document here"?
              Jeff A Wright Adobe Employee
              Moving this discussion to the Adobe Digital Editions forum.
              • 4. Re: why am I getting an error message "No permission to copy document here"?
                Level 4
                The answer to the question is that either the publisher or the library have
                set the digital rights to those ebooks to prevent you from copying them to
                another device.  You can check this by looking at the ebooks' digital
                rights.  Here's how:
                In ADE Library mode, click on the small arrow next to the ebook's name.  A
                drop-down box will give you some choices - pick Item Info.  About halfway
                down the list is the section that contains the digital rights settings.
                I'm betting the 'copying' setting says no.
                There's no way to fix this - it's the perogative of publishers, writers,
                distributors and libraries.  So if you don't like it, try contacting your
                library and see if they can change the setting.  I'm not hopeful that they
                can or if they can, they will.
                • 5. Re: why am I getting an error message "No permission to copy document here"?
                  Skopin
                  While some publishers do restrict copying titles, the error is actually referring to the transfer of the book, not actually copying. Copy restrictions means just that: you cannot make a copy of the book. This error is typically caused when the NOOK has not been authorized properly. To solve the issue, you need to reset the Adobe credentials on your NOOK.
                  Note: These instructions are for ADE 2.0. Please make sure you're using the most up-to-date version before continuing.
                  What you need
                  Check your Adobe authentication using Windows
                  1. Make sure your computer is properly authorized.
                          In ADE, go to Help > Authorization Information…
                    Screenshot showing Authorization Information highlighted in the ADE Help menu.
                          The authorization window opens and shows you what ID you're currently using for your computer.
                          If your computer isn't yet authorized, please activate it before continuing.
                          Screenshot showing the Adobe ID authorization window.
                  2. Close ADE and wait a few seconds.
                  3. Reset the ADE folder on the NOOK. For this step, you need to close ADE.
                    • Connect your NOOK to your computer (if it's not already connected).
                    • Double-click your NOOK under 'My Computer' or 'Computer'
                  4. Locate the folder .adobe-digital-editions and delete it.
                  5. Open ADE, then try transferring the eBook again.
                  Check your Adobe authentication using a Mac
                    Screenshot showing Authorization Information selected from the ADE Help menu.
                    The authorization window opens and shows you what ID you're currently using on your computer.
                          Screenshot showing the ADE authorization window.
                    • Open your NOOK from Finder.
                    • Press Command + Shift + G.
                    • In the 'Go to Folder' window, type: /nook/.adobe-digital-editions
                    • Make sure the bold section of the path above ('nook') matches the name of your NOOK which is shown on the desktop when you plug it in.
                    • Move the contents of the '.adobe-digital-editions' folder to the trash.
                  4. Open ADE, then try transferring the eBook again.
                  Hope this helps!
                  • 6. Re: why am I getting an error message "No permission to copy document here"?
                    howie3055
                    I have a Kobo touch.  Using either a WIN XP SP3 or WIN7 machine does your procedure apply?
                    I want to double-check with you since the E-reader can be cranky.
                    My basic problem is similar to the original:
                    - Could transfer books some months ago.
                    - After yet another reset some non-Kobo sourced books will now not transfer.
                    - The error message is "No permission to copy here".
                    - The digital rights show "No copying".
                    Two computers are involved, same ADE ID.
                    Regards,
                    Howard
