0 Replies Latest reply on May 22, 2012 4:16 AM by $Nith$
    How to return multiple results from Custom DSC?
    $Nith$ Level 4
      A custom DSC is written which requires two inputs and should return two outputs.
      e.g.
        public void sum(int a,int b)
         int result = a+b;
         boolean success = true;
      The above service implementation should return both variable values.
      How can I update the configuration.xml to have these two variables as output-parameters?
      I tried several other properties such as "binding-type", "attribute" but no luck.
      The service works fine but doesn't return any results.
      Please advise.
      Nith
