2 Replies Latest reply on May 23, 2012 10:52 PM by gatimo1
    Flash Player 11.2 Installer Failed Mac 10.6.8
    gatimo1
      The installation runs to about 6% then I get the "Installation Failed" error.
      I've tried everything including cleaning disk permisions but nothing is working.
      Below is my Installer Log.
      Please help. Seems I can't do without Flash Player afterall.
      2012-05-22 15:32:58 +0300 ---------- log start ----------
      2012-05-22 15:32:58 +0300 All install checks pass
      2012-05-22 15:33:10 +0300 User has 1 process that needs to be closed before the Flash Player can be installed.
      2012-05-22 15:33:17 +0300 [install started]
      dyld: Symbol not found: _OBJC_CLASS_$_CWInterfaceManager
        Referenced from: /System/Library/PrivateFrameworks/Install.framework/Frameworks/OSInstall.framework/Versio ns/A/OSInstall
        Expected in: /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
      in /System/Library/PrivateFrameworks/Install.framework/Frameworks/OSInstall.framework/Versio ns/A/OSInstall
      2012-05-22 15:33:18 +0300 [install completed]
      2012-05-22 15:33:18 +0300 [install failed]
      2012-05-22 15:33:25 +0300 ----------  log end  ----------
      2012-05-22 15:33:26 +0300 ---------- log start ----------
      2012-05-22 15:33:26 +0300 All install checks pass
      2012-05-22 15:33:31 +0300 User does not have any processes that need to be closed before the Flash Player can be installed.
      2012-05-22 15:33:31 +0300 [install started]
      2012-05-22 15:33:32 +0300 [install completed]
      2012-05-22 15:33:32 +0300 [install failed]
      2012-05-22 15:33:50 +0300 ----------  log end  ----------
      2012-05-22 15:33:52 +0300 ---------- log start ----------
      2012-05-22 15:33:52 +0300 All install checks pass
      2012-05-22 15:34:05 +0300 User does not have any processes that need to be closed before the Flash Player can be installed.
      2012-05-22 15:34:05 +0300 [install started]
      2012-05-22 15:34:06 +0300 [install completed]
      2012-05-22 15:34:06 +0300 [install failed]
      2012-05-22 15:37:31 +0300 ----------  log end  ----------
      2012-05-22 15:40:19 +0300 ---------- log start ----------
      2012-05-22 15:40:19 +0300 All install checks pass
      2012-05-22 15:40:37 +0300 User does not have any processes that need to be closed before the Flash Player can be installed.
      2012-05-22 15:40:37 +0300 [install started]
      2012-05-22 15:40:38 +0300 [install completed]
      2012-05-22 15:40:38 +0300 [install failed]
      2012-05-22 15:49:09 +0300 ----------  log end  ----------
      2012-05-22 15:49:14 +0300 ---------- log start ----------
      2012-05-22 15:49:14 +0300 All install checks pass
      2012-05-22 15:49:20 +0300 User has 2 processes that need to be closed before the Flash Player can be installed.
      2012-05-22 15:49:28 +0300 [install started]
      2012-05-22 15:49:29 +0300 [install completed]
      2012-05-22 15:49:29 +0300 [install failed]
      2012-05-22 16:03:03 +0300 ----------  log end  ----------
      2012-05-22 16:29:28 +0300 ---------- log start ----------
      2012-05-22 16:29:28 +0300 All install checks pass
      2012-05-22 16:29:38 +0300 User does not have any processes that need to be closed before the Flash Player can be installed.
      2012-05-22 16:29:39 +0300 [install started]
      2012-05-22 16:30:11 +0300 [install completed]
      2012-05-22 16:30:11 +0300 [install failed]
      2012-05-22 16:30:16 +0300 ----------  log end  ----------
      2012-05-22 16:30:26 +0300 ---------- log start ----------
      2012-05-22 16:30:26 +0300 All install checks pass
      2012-05-22 16:30:33 +0300 User does not have any processes that need to be closed before the Flash Player can be installed.
      2012-05-22 16:30:33 +0300 [install started]
      2012-05-22 16:30:34 +0300 [install completed]
      2012-05-22 16:30:34 +0300 [install failed]
      2012-05-22 16:37:33 +0300 ----------  log end  ----------
      2012-05-22 16:51:52 +0300 ---------- log start ----------
      2012-05-22 16:51:52 +0300 All install checks pass
      2012-05-22 16:52:02 +0300 User does not have any processes that need to be closed before the Flash Player can be installed.
      2012-05-22 16:52:02 +0300 [install started]
      2012-05-22 16:52:03 +0300 [install completed]
      2012-05-22 16:52:03 +0300 [install failed]
      2012-05-22 16:52:19 +0300 ----------  log end  ----------
      2012-05-22 17:17:29 +0300 ---------- log start ----------
      2012-05-22 17:17:40 +0300 User has 1 process that needs to be closed before the Flash Player can be uninstalled.
      2012-05-22 17:17:57 +0300 ----------  log end  ----------
      2012-05-22 17:23:41 +0300 ---------- log start ----------
      2012-05-22 17:23:41 +0300 All install checks pass
      2012-05-22 17:23:49 +0300 User does not have any processes that need to be closed before the Flash Player can be installed.
      2012-05-22 17:23:49 +0300 [install started]
      2012-05-22 17:24:06 +0300 [install completed]
      2012-05-22 17:24:06 +0300 [install failed]
      2012-05-22 17:39:26 +0300 ----------  log end  ----------
      2012-05-22 17:41:03 +0300 ---------- log start ----------
      2012-05-22 17:41:03 +0300 All install checks pass
      2012-05-22 17:41:10 +0300 User has 1 process that needs to be closed before the Flash Player can be installed.
      2012-05-22 17:41:16 +0300 [install started]
      2012-05-22 17:41:17 +0300 [install completed]
      2012-05-22 17:41:17 +0300 [install failed]
      2012-05-22 17:41:19 +0300 ----------  log end  ----------
      2012-05-22 17:50:11 +0300 ---------- log start ----------
      2012-05-22 17:50:11 +0300 All install checks pass
      2012-05-22 17:50:19 +0300 User has 1 process that needs to be closed before the Flash Player can be installed.
