4 Replies Latest reply on May 23, 2012 4:23 PM by andersen32
    720p video in 1080p timeline has black borders
    andersen32
      Hello,
      I have Premiere Cs6, with Windows 7.
      I want to mix 1080/50p and 720/30p videos, and correctly downsize it to 720/25p in Adobe Media Encoder.
      1. When I choose 720/25p timeline, all the 1080p videos looks like zoomed (the middle of the video image can be seen). The 720p videos are fine
      2. If I choose 1080/25p timeline, the 1080p videos are fine, but the 720p ones has black border on all 4 sides:
      http://img861.imageshack.us/img861/6306/69202278.jpg
      Please help me how to do it correctly, to be able tho get a proper 720/25p video from these sources, without borders.
      Thank you!
        • 1. Re: 720p video in 1080p timeline has black borders
          Jim_Simon Level 8
          Use a 720p/25 sequence and downscale the 1080 stuff.
          • 2. Re: 720p video in 1080p timeline has black borders
            SAFEHARBOR11 Most Valuable Participant
            In Premiere Preferences, there is a checkbox for "Default Scale to Frame Size". If you enable that, when you Import clips they will automatically fit the current editing size. Does not affect clips imported prior to checking the box. On timeline, right-click clip and choose "Scale to Frame Size" to change individual clips.
            As Jim recommended, if your intended delivery format is 720p, don't upscale to 1080 and then back to 720p, will cause unnecessary quality loss from scaling. Edit it all as 720p.
            Jeff Pulera
            Safe Harbor Computers
            • 3. Re: 720p video in 1080p timeline has black borders
              Rallymax-forum Level 3
              The timeline should match the final output so use a 720p25 timeline.
              If you have a 720p as your output you have a 1280x720 canvas. If you drop a 1920x1080 video on it will be too big. Do as SAFEHARBOR11 said....
              ...OR for each clip open up the effects->motion and change the scale of the 1080p footage (1280/1920=66.6666%) - it won't divide nicely so you'll have to do 66 instead of 67% so that you don't get black edges.
              As for output frame rate... do you have to do 25fps? If it's not for broadcast - it is my understanding that most PAL countries have BD players that can understand 24fps as well. I say this because maybe you'd be better off retiming the 50i footage to 48i (a 4% slowdown) and thus 24fps. You do this by right clicking and Interpret Footage-> 24fps instead of its 25fps.
              You can then edit between the two cameras without throwing frames on the floor since the 720p30 will 3:2 pulldown to 24fps too.
              BUT, you only need to do that if the shudder from dropping 1 in 25 frames on the floor has a worse look than slowing down the original footage. It is easier if you're editing back and forth with the two cameras to drop those frames but perhaps slowing down would be better for you.
              Some professionals cringe at the idea of throwing frames on the floor, others that the original is slowed down. It's up to you.
              As some food for thought....
              When I was on the DVD authoring team for the "Dune" release in Australia ('98) the telecine of the original film was sped up from 24 to 25fps. We then sped up and pitch shifted back down the 5.1 audio track to match.
              Another example [I didn't work on] is "The Thomas Crown Affair" release in the USA. The title menus must have been done in the UK (or Oz) and not pitch shifted because it has a 4% higher pitched music vs the film. - it's very noticeable because from the root menu it goes straight to the same piano tune in the film and drops a couple tones. (^dink dink dink^.... ^dunk dunk dunk^) In the film itself you have no idea that the feature was [or was not] stretched 4% to fit to 25fps or 30fps (ie 24fps original 3:2 pullup).
              my 2bits.
              Rallymax
              • 4. Re: 720p video in 1080p timeline has black borders
                andersen32 Level 1
                Rallyemax, Jeff, Jim.
                Thank you!
